 * Copyright 2007,2008 Microchip Technology, all rights reserved
 * This file defines useful exports from libpic30.a
 * Not all functions defined in libpic30.a can be usefully called by
 * the user, most are helper functions for the standard C library, libc.a
#ifndef __LIBPIC30_H
#define __LIBPIC30_H
 * The following two functions allow the programmer to attach a file to
 * standard input, and later close the file.  The functions are only useful
 * if the executable will be simulated.
 * With these functions input from the file will be read on-demmand, otherwise
 * the programmer should use the message based stimulus (information on this
 * can be found within MPLAB IDE's help pages).
extern int __attach_input_file(const char *f);
void __close_input_file(void);
 * __C30_UART selects the default UART port that read() and write() will use.  
 * read() is called by fscanf and family, while write() is called by printf 
 * and family.  The default setting (as shipped) is 1, which is suitable for 
 * the dsPICdem 1.1(tm) board.   Modifying this to another value will select
 * UART 2, suitable for the explorer 16(tm) board.
extern int __C30_UART;
 * __delay32() provides a 32-bit delay routine which will delay for the number
 * of cycles denoted by its argument.  The minimum delay is 12 cycles
 * including call and return statements.  With this function only the time
 * required for argument transmission is not accounted for.  Requests for
 * less than 12 cycles of delay will cause an 12 cycle delay.
extern void __delay32(unsigned long cycles);
 * __delay_ms() and __delay_us() are defined as macros. They depend
 * on a user-supplied definition of FCY. If FCY is defined, the argument
 * is converted and passed to __delay32(). Otherwise, the functions
 * are declared external.
 * For example, to declare FCY for a 10 MHz instruction rate:
 * #define FCY 10000000UL
#if !defined(FCY)
	extern void __delay_ms(unsigned long);
	extern void __delay_us(unsigned long);
#else
	#define __delay_ms(d) __delay32( (unsigned long long) (d)*(FCY)/1000)
	#define __delay_us(d) __delay32( (unsigned long long) (d)*(FCY)/1000000)
	#define __delay_s(d) __delay32( (unsigned long) (d)*(FCY))
#endif
 * _PROGRAM_END is a symbol in program memory that marks the highest
 * address used by a CODE or PSV section. It should be referenced
 * with the address operator (&) in a built-in function call that
 * accepts the address of an object in program memory.
 * For example:
 *  __builtin_tblpage(&_PROGRAM_END)
 *  __builtin_tbloffset(&_PROGRAM_END)
 *  _prog_addressT big_addr;
 *  big_addr = __builtin_tbladdress(&_PROGRAM_END)
extern __attribute__((space(prog))) int _PROGRAM_END;
 * _dump_heap_info()
 * Writes a summary of heap memory usage to stderr,
 * including address range info and a list of
 * allocated and free memory blocks.
 * For diagnostic use only. The output format may
 * may change in future versions.
extern void _dump_heap_info(void);
 * _memcpy_helper() - not a user-callable function
 * Copies data from program memory to data memory. It does
 * not require the Program Space Visibility (PSV) window. However, it
 * does change the value of TBLPAG during execution.
 * The source address in program memory is specified by a tbl_offset,
 * tbl_page pair. Flags indicate whether the upper byte should be
 * copied, and whether to terminate early after a NULL byte.
 * The return value is an updated source address pair.
 * The number of bytes copied may be even or odd. The source address
 * is always even and is always aligned to the start of the next
 * program memory word.
typedef unsigned long _prog_addressT;
extern _prog_addressT _memcpy_helper(_prog_addressT src, void *dst,
                                     unsigned int len, int flags);
 * Initialize a variable of type _prog_addressT.
 * These variables are not equivalent to C pointers,
 * since each source address corresponds to 2 or 3 chars.
#define _init_prog_address(a,b)  (a = __builtin_tbladdress(&b))
 * _memcpy_p2d16() copies 16 bits of data from each address
 * in program memory to data memory. The source address is
 * specified as type _prog_addressT; the next unused address
 * is returned.
_prog_addressT _memcpy_p2d16(void *dest, _prog_addressT src,
                             unsigned int len);
#define _memcpy_p2d16(dest, src, len)  _memcpy_helper(src, dest, len, 0) 
 * _memcpy_p2d24() copies 24 bits of data from each address
 * is returned.
_prog_addressT _memcpy_p2d24(void *dest, _prog_addressT src,
                             unsigned int len);
#define _memcpy_p2d24(dest, src, len)  _memcpy_helper(src, dest, len, 1) 
 * _strncpy_p2d16() copies 16 bits of data from each address
 * in program memory to data memory. The operation terminates
 * early if a NULL char is copied. The source address is
 * is returned.
_prog_addressT _strncpy_p2d16(char *dest, _prog_addressT src,
                              unsigned int len);
#define _strncpy_p2d16(dest, src, len)  _memcpy_helper(src, dest, len, 2) 
 * _strncpy_p2d24() copies 24 bits of data from each address
 * is returned.
_prog_addressT _strncpy_p2d24(char *dest, _prog_addressT src,
                              unsigned int len);
#define _strncpy_p2d24(dest, src, len)  _memcpy_helper(src, dest, len, 3) 
 *        Constants for FLASH & EEDATA Functions          *
 * Lengths in EEDATA memory = bytes
 * Lengths in FLASH memory = words
 *  (1 word = 3 bytes = 2 PC address units)
/* constants for 30F devices */
#ifdef __dsPIC30F__
#define _FLASH_ERASE_CODE                 0x4041
#define _FLASH_WRITE_ROW_CODE             0x4001
#define _EE_ERASE_WORD_CODE               0x4044
#define _EE_ERASE_ROW_CODE                0x4045
#define _EE_ERASE_ALL_CODE                0x4046
#define _EE_WORD_WRITE_CODE               0x4004
#define _EE_ROW_WRITE_CODE                0x4005
#define _FLASH_PAGE     32
#define _FLASH_ROW      32
#define _EE_WORD         2
#define _EE_ROW         32
/* constants for 33F devices */
#elif defined(__dsPIC33F__) 
#define _FLASH_ERASE_CODE                 0x4042
#define _FLASH_ERASE_GENERAL_SEGMENT_CODE 0x404D
#define _FLASH_ERASE_SECURE_SEGMENT_CODE  0x404C
#define _FLASH_WRITE_WORD_CODE            0x4003
#define _FLASH_PAGE   512
#define _FLASH_ROW     64
/* constants for 24H devices */
#elif defined(__PIC24H__)
/* constants for 24F devices */
#elif defined(__PIC24F__)
/* constants for 24FK devices */
#elif defined(__PIC24FK__)
#define _FLASH_ERASE_ROW_CODE             0x4058
#define _FLASH_ERASE_2ROW_CODE            0x4059
#define _FLASH_ERASE_4ROW_CODE            0x405A
#define _FLASH_WRITE_ROW_CODE             0x4004
#define _FLASH_ERASE_GENERAL_SEGMENT_CODE 0x404C
#define _FLASH_ERASE_BOOT_SEGMENT_CODE    0x4068
#define _EE_ERASE_WORD_CODE               0x4058
#define _EE_ERASE_4WORDS_CODE             0x4059
#define _EE_ERASE_8WORDS_CODE             0x405A
#define _EE_ERASE_ALL_CODE                0x4050
#define _EE_WRITE_WORD_CODE               0x4004
#define _FLASH_2ROWS   64
#define _FLASH_4ROWS  128
#define _EE_WORD        2
#define _EE_4WORDS      8
#define _EE_8WORDS     16
#endif
 * The following helper functions are not user-callable,
 * and may change in the future. The purpose of these
 * functions is to provide an abstraction layer where
 * device or family specific parameters can be specified.
extern void _eedata_helper1(_prog_addressT dst, int len);
extern void _eedata_helper2(void);
extern void _eedata_helper3(_prog_addressT dst, int dat);
extern void _eedata_helper4(_prog_addressT dst, int *src);
extern void _eedata_helper5(_prog_addressT dst, int len);
extern void _eedata_helper6(void);
extern void _eedata_helper7(_prog_addressT dst, int dat);
extern void _flash_helper1 (_prog_addressT dst, int code);
extern void _flash_helper2 (_prog_addressT dst, int *src, int len);
extern void _flash_helper3 (_prog_addressT dst, long *src, int len);
extern void _flash_helper4 (_prog_addressT dst, int dat);
extern void _flash_helper5 (_prog_addressT dst, long dat);
extern void _flash_helper6 (int code);
extern void _flash_helper7(_prog_addressT dst, int len);
extern void _flash_helper8 (_prog_addressT dst, int *src, int len);
extern void _flash_helper9 (_prog_addressT dst, long *src, int len);
 *        EEDATA Functions for dsPIC30F Devices           *
#ifdef __dsPIC30F__
 * _erase_eedata() erases a word or a row of
 * eedata memory on 30F devices. The address is
 * specified with type _prog_addressT. The length
 * may be _EE_WORD or _EE_ROW (bytes).
void _erase_eedata(_prog_addressT dst, int len);
#define _erase_eedata  _eedata_helper1
 * _erase_eedata_all() erases the entire
 * range of eedata memory on 30F devices.
void _erase_eedata_all(void);
#define _erase_eedata_all  _eedata_helper2
 * _wait_eedata() waits for an erase
 * or write operation to complete.
void _wait_eedata(void);
#define _wait_eedata() { while (NVMCONbits.WR); }
 * _write_eedata_word() writes 16 bits of
void _write_eedata_word(_prog_addressT dst, int dat);
#define _write_eedata_word  _eedata_helper3
 * _write_eedata_row() writes __EE_ROW bytes
 * of eedata memory on 30F devices. The address is
void _write_eedata_row(_prog_addressT dst, int *src);
#define _write_eedata_row  _eedata_helper4
#endif
 *       EEDATA Functions for PIC24FxxK Devices           *
#ifdef __PIC24FK__
 * _erase_eedata() erases eedata memory on 24FK devices. 
 * The address is specified with type _prog_addressT. 
 * The length may be _EE_WORD, _EE_4WORDS, or _EE_8WORDS.
#define _erase_eedata  _eedata_helper5
 * range of eedata memory on 24FK devices.
#define _erase_eedata_all  _eedata_helper6
 * eedata memory on 24FK devices. The address is
#define _write_eedata_word  _eedata_helper7
#endif
 *  FLASH Functions for PIC24F, PIC24H, and dsPIC Devices *
#if defined(__dsPIC33F__) || defined(__PIC24H__) || defined(__dsPIC30F__) || defined(__PIC24F__)
 * _erase_flash() erases a page of FLASH memory.
 * The page address is specified with type
 * _prog_addressT.
void _erase_flash(_prog_addressT dst);
#define _erase_flash(dst)  _flash_helper1(dst, _FLASH_ERASE_CODE)
 * _write_flash16() writes a row of FLASH memory
 * with 16-bit data. The row address is specified with
 * type _prog_addressT. The source address is an
 * array of type int, with _FLASH_ROW elements.
 * Note that the row must be erased before
 * any write can be successful.
 * This function includes a workaround for the Device ID errata as 
 * described in DS-80444, DS-80446, or DS-80447 (#32).
void _write_flash16(_prog_addressT dst, int *src);
#define _write_flash16(dst, src)  _flash_helper2(dst, src, _FLASH_ROW)
 * _write_flash24() writes a row of FLASH memory
 * with 24-bit data. The row address is specified with
 * array of type long, with _FLASH_ROW elements.
void _write_flash24(_prog_addressT dst, long *src);
#define _write_flash24(dst, src)  _flash_helper3(dst, src, _FLASH_ROW);
#endif
#if defined(__dsPIC33F__) || defined(__PIC24H__) || defined(__PIC24F__)
 * _write_flash_word16() writes a word of FLASH memory
 * with 16 bits of data. Word writes are supported on
 * 33F, 24H, and 24F devices. The row address is specified
 * with type _prog_addressT. Note that the location must
 * be erased before any write can be successful.
 * This function is currently disable for devices subject to the 
 * Device ID errata as described in DS-80444, DS-80446, or DS-80447 (#32).
#if defined(__PIC24F__)
void _write_flash_word16(_prog_addressT dst, int dat);
#define _write_flash_word16  _flash_helper4
#endif
 * _write_flash_word24() writes a word of FLASH memory
 * with 24-bits of data.  Word writes are supported on
void _write_flash_word24(_prog_addressT dst, long dat);
#define _write_flash_word24  _flash_helper5
#endif
#endif
 *        FLASH Functions for PIC24FxxK Devices           *
#if defined(__PIC24FK__)
 * _erase_flash erases rows of FLASH memory.
 * The first row address is specified with type
 * _prog_addressT. The length may be _FLASH_ROW,
 * _FLASH_2ROWS, or _FLASH_4ROWS.
void _erase_flash(_prog_addressT dst, int len);
#define _erase_flash  _flash_helper7
#define _write_flash16(dst, src)  _flash_helper8(dst, src, _FLASH_ROW)
#define _write_flash24(dst, src)  _flash_helper9(dst, src, _FLASH_ROW);
#endif
#endif
