 *	Hardware specific definitions
 * FileName:        HardwareProfile_xxx.h
 * Dependencies:    None
 * Processor:       PIC24F, PIC24H, dsPIC, PIC32
 * Compiler:        Microchip C32 v1.00 or higher
 *					Microchip C30 v3.01 or higher
 * Company:         Microchip Technology, Inc.
 * Software License Agreement
 * Copyright © 2002-2009 Microchip Technology Inc.  All rights 
 * reserved.
 * Microchip licenses to you the right to use, modify, copy, and 
 * distribute: 
 * (i)  the Software when embedded on a Microchip microcontroller or 
 *      digital signal controller product (“Device”) which is 
 *      integrated into Licensee’s product; or
 * (ii) ONLY the Software driver source files ENC28J60.c and 
 *      ENC28J60.h ported to a non-Microchip device used in 
 *      conjunction with a Microchip ethernet controller for the 
 *      sole purpose of interfacing with the ethernet controller. 
 * You should refer to the license agreement accompanying this 
 * Software for additional information regarding your rights and 
 * obligations.
 * THE SOFTWARE AND DOCUMENTATION ARE PROVIDED “AS IS” WITHOUT 
 * WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT 
 * LIMITATION, ANY WARRANTY OF MERCHANTABILITY, FITNESS FOR A 
 * PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT. IN NO EVENT SHALL 
 * MICROCHIP BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR 
 * CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF 
 * PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS 
 * BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE 
 * THEREOF), ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER 
 * SIMILAR COSTS, WHETHER ASSERTED ON THE BASIS OF CONTRACT, TORT 
 * (INCLUDING NEGLIGENCE), BREACH OF WARRANTY, OR OTHERWISE.
 * Author               Date		Comment
 * Howard Schlunder		10/03/06	Original, copied from Compiler.h
 * Jayanth Murthy       06/25/09    dsPIC & PIC24H support 
 * Pradeep Budagutta	15 Sep 2009 Added PIC24FJ256DA210 Development Board Support
 * PAT                  04/07/10    Removed GRAPHICS_HARDWARE_PLATFORM 
 *                                  Added MMB support
#ifndef __HARDWARE_PROFILE_H
    #define __HARDWARE_PROFILE_H
* GetSystemClock() returns system clock frequency.
* GetPeripheralClock() returns peripheral clock frequency.
* GetInstructionClock() returns instruction clock frequency.
* Macro: #define	GetSystemClock() 
* Overview: This macro returns the system clock frequency in Hertz.
*			* value is 8 MHz x 4 PLL for PIC24
*			* value is 8 MHz/2 x 18 PLL for PIC32
    #if defined(__PIC24F__)
        #define GetSystemClock()    (32000000ul)
    #elif defined(__PIC32MX__)
        #define GetSystemClock()    (80000000ul)
    #elif defined(__dsPIC33F__) || defined(__PIC24H__)
    #endif
* Macro: #define	GetPeripheralClock() 
* Overview: This macro returns the peripheral clock frequency 
*			used in Hertz.
*			* value for PIC24 is <PRE>(GetSystemClock()/2) </PRE> 
*			* value for PIC32 is <PRE>(GetSystemClock()/(1<<OSCCONbits.PBDIV)) </PRE>
    #if defined(__PIC24F__) || defined(__PIC24H__) || defined(__dsPIC33F__)
        #define GetPeripheralClock()    (GetSystemClock() / 2)
        #define GetPeripheralClock()    (GetSystemClock() / (1 << OSCCONbits.PBDIV))
    #endif
* Macro: #define	GetInstructionClock() 
* Overview: This macro returns instruction clock frequency 
*			used in Hertz.
*			* value for PIC32 is <PRE>(GetSystemClock()) </PRE> 
        #define GetInstructionClock()   (GetSystemClock() / 2)
        #define GetInstructionClock()   (GetSystemClock())
    #endif
* UART SETTINGS
	#define BAUDRATE2               115200UL
    #define BRG_DIV2                4
    #define BRGH2                   1
* START OF GRAPHICS RELATED MACROS
* AUTO GENERATED CODE 
//Auto Generated Code
#define GFX_PICTAIL_V3
#define EXPLORER_16
#define USE_8BIT_PMP
#define PIC32_GP_SK_DM320001
#define DISPLAY_CONTROLLER SSD1926
#define DISPLAY_PANEL TFT_G240320LTSW_118W_E
#define COLOR_DEPTH 16
//End Auto Generated Code
* END OF AUTO GENERATED CODE 
#ifdef _GRAPHICS_H
* ERROR CHECKING
#if !defined (GFX_PICTAIL_V3) && !defined (GFX_PICTAIL_V2) && !defined (PIC24FJ256DA210_DEV_BOARD) && !defined(MULTI_MEDIA_BOARD_DM00123)
	#error "Error: Graphics Hardware Platform is not defined! One of the three (GFX_PICTAIL_V3, GFX_PICTAIL_V2, PIC24FJ256DA210_DEV_BOARD) must be defined.
#endif
#if defined (__PIC24FJ128GA010__) || defined (__PIC24FJ256GA110__) ||	\
	defined (__PIC24FJ256GB110__) || defined (__dsPIC33F__)        ||   \
	defined (__PIC24HJ128GP504__)
	#if defined (USE_16BIT_PMP)	
		#error "The device selected does not support 16 bit PMP interface."
	#endif
#endif
#ifndef DISPLAY_CONTROLLER
	#error "Error: DISPLAY_CONTROLLER not defined"
#endif
#if (defined (GFX_PICTAIL_V3) || defined (PIC24FJ256DA210_DEV_BOARD)) && !defined(DISPLAY_PANEL)
	#error "Error: DISPLAY_PANEL not defined"
#endif
* SETTINGS FOR DISPLAY DRIVER FEATURE for PIC24FJ256DA210  Family of
* display controller
	#ifdef USE_DOUBLE_BUFFERING
		#ifdef GFX_DISPLAY_BUFFER_START_ADDRESS
			#undef GFX_DISPLAY_BUFFER_START_ADDRESS
			volatile extern  DWORD _drawbuffer;
			#define GFX_DISPLAY_BUFFER_START_ADDRESS _drawbuffer
		#endif
		#define GFX_BUFFER1 0x00020000ul
		#define GFX_BUFFER2 0x00050000ul
	#endif
* DISPLAY PARALLEL INTERFACE
	// EPMP is exclusive to GB210 devices and PMP to some devices
	#if defined (__PIC24FJ256DA210__)
		// EPMP is used by graphics controller
	#elif defined (__PIC24FJ256GB210__)
		#define USE_GFX_EPMP
	#else
		#define USE_GFX_PMP
	#endif
* DISPLAY SETTINGS 
// For SMART DISPLAYS
// Using LGDP4531 Display Controller
	#if (DISPLAY_CONTROLLER == LGDP4531)
		#define DISP_ORIENTATION    90
        #define DISP_HOR_RESOLUTION 240
        #define DISP_VER_RESOLUTION 320
		#define DISPLAY_PANEL -1
	#endif // #if (DISPLAY_CONTROLLER == LGDP4531)
// Using S6D0129 Display Controller
	#if (DISPLAY_CONTROLLER == S6D0129)
	#endif // #if (DISPLAY_CONTROLLER == S6D0129)
// For SMART RGB GLASS
// check if DISPLAY_PANEL is not defined set it to -1 to skip the rest
// of the display panel settings.
#if !defined (DISPLAY_PANEL)
#endif	
// Using TFT_G240320LTSW_118W_E, TFT2N0369_E, DT032TFT_TS, DT032TFT  Display Panel.
// These panels uses Solomon Systech SSD1289 as their controller. 
	#if (DISPLAY_PANEL == TFT_G240320LTSW_118W_E)	|| (DISPLAY_PANEL == TFT2N0369_E) ||		\
		(DISPLAY_PANEL == DT032TFT_TS)				|| (DISPLAY_PANEL == DT032TFT)
		/* note: For SSD1289 
			tHBP (horizontal back porch)= DISP_HOR_BACK_PORCH + DISP_HOR_PULSE_WIDTH
			tVBP (vertical back porch)  = DISP_VER_BACK_PORCH + DISP_VER_PULSE_WIDTH
			Horizontal Cycle (280) = tHBP + DISP_HOR_FRONT_PORCH + DISP_HOR_RESOLUTION
			Vertical Cycle (326)   = tVBP + DISP_VER_FRONT_PORCH + DISP_VER_RESOLUTION
			In summary, the DISP_HOR_PULSE_WIDTH should not exceed tHBP and 
			the DISP_VER_PULSE_WIDTH should not exceed tVBP. See SSD1289 data sheet for 
			details.
        #define DISP_DATA_WIDTH			18
        #define DISP_INV_LSHIFT
        #define DISP_HOR_PULSE_WIDTH    25
        #define DISP_HOR_BACK_PORCH     5
        #define DISP_HOR_FRONT_PORCH    10
        #define DISP_VER_PULSE_WIDTH    4
        #define DISP_VER_BACK_PORCH     0
        #define DISP_VER_FRONT_PORCH    2
		#if (DISPLAY_CONTROLLER == MCHP_DA210)
			#define GFX_LCD_TYPE                        GFX_LCD_TFT
            #define GFX_DISPLAYENABLE_ENABLE
            #define GFX_HSYNC_ENABLE
            #define GFX_VSYNC_ENABLE
            #define GFX_DISPLAYPOWER_ENABLE
            #define GFX_CLOCK_POLARITY                  GFX_ACTIVE_HIGH
            #define GFX_DISPLAYENABLE_POLARITY          GFX_ACTIVE_HIGH
            #define GFX_HSYNC_POLARITY                  GFX_ACTIVE_LOW
            #define GFX_VSYNC_POLARITY                  GFX_ACTIVE_LOW
            #define GFX_DISPLAYPOWER_POLARITY           GFX_ACTIVE_HIGH
        #endif
	#endif // #if (DISPLAY_PANEL == TFT_G240320LTSW_118W_E) || (DISPLAY_PANEL == TFT2N0369_E) ||....
// Using TFT_G320240DTSW_69W_TP_E Display Panel
	#if (DISPLAY_PANEL == TFT_G320240DTSW_69W_TP_E) || (DISPLAY_PANEL == _35QVW0T)  
		#define DISP_ORIENTATION		0
        #define DISP_HOR_RESOLUTION		320
        #define DISP_VER_RESOLUTION		240
        #define DISP_HOR_BACK_PORCH     8
        #define DISP_HOR_FRONT_PORCH    8
        #define DISP_VER_PULSE_WIDTH    8
        #define DISP_VER_BACK_PORCH     7
        #define DISP_VER_FRONT_PORCH    5
	#endif // #if (DISPLAY_PANEL == TFT_G320240DTSW_69W_TP_E) || (DISPLAY_PANEL == _35QVW0T) 
// Using PH480272T_005_I06Q Display Panel
	#if (DISPLAY_PANEL == PH480272T_005_I06Q) 
        #define DISP_HOR_RESOLUTION		480
        #define DISP_VER_RESOLUTION		272
        #define DISP_DATA_WIDTH			24
        #define DISP_HOR_PULSE_WIDTH    41
        #define DISP_HOR_BACK_PORCH     2
        #define DISP_HOR_FRONT_PORCH    2
        #define DISP_VER_PULSE_WIDTH    10
        #define DISP_VER_BACK_PORCH     2
            #define GFX_CLOCK_POLARITY                  GFX_ACTIVE_LOW
        #endif
	#endif // #if (DISPLAY_PANEL == PH480272T_005_I06Q)
// Using PH480272T_005_I11Q Display Panel
	#if (DISPLAY_PANEL == PH480272T_005_I11Q) 
        #endif
	#endif // #if (DISPLAY_PANEL == PH480272T_005_I11Q)
* IOS FOR THE DISPLAY CONTROLLER
#if defined (GFX_PICTAIL_V1)
	// Definitions for reset pin
	#define RST_TRIS_BIT    TRISCbits.TRISC1
    #define RST_LAT_BIT     LATCbits.LATC1
	// Definitions for RS pin
    #define RS_TRIS_BIT TRISBbits.TRISB15
    #define RS_LAT_BIT  LATBbits.LATB15
	// Definitions for CS pin
    #define CS_TRIS_BIT TRISDbits.TRISD8
    #define CS_LAT_BIT  LATDbits.LATD8
	// Definitions for FLASH CS pin
    #define CS_FLASH_LAT_BIT    LATDbits.LATD9
    #define CS_FLASH_TRIS_BIT   TRISDbits.TRISD9
#elif defined (GFX_PICTAIL_V2)
        #if defined(__dsPIC33FJ128GP804__) || defined(__PIC24HJ128GP504__)
            #define RST_TRIS_BIT    TRISAbits.TRISA4
            #define RST_LAT_BIT     LATAbits.LATA4
            #define RS_TRIS_BIT TRISAbits.TRISA1
            #define RS_LAT_BIT  LATAbits.LATA1
            #define CS_TRIS_BIT TRISBbits.TRISB15
            #define CS_LAT_BIT  LATBbits.LATB15
            #define CS_FLASH_LAT_BIT    LATAbits.LATA8
            #define CS_FLASH_TRIS_BIT   TRISAbits.TRISA8
			// Definitions for POWER ON pin
            #define POWERON_LAT_BIT     LATAbits.LATA10
            #define POWERON_TRIS_BIT    TRISAbits.TRISA10
        #else
            #define RS_TRIS_BIT TRISCbits.TRISC2
            #define RS_LAT_BIT  LATCbits.LATC2
            #define CS_TRIS_BIT TRISDbits.TRISD10
            #define CS_LAT_BIT  LATDbits.LATD10
            #define CS_FLASH_LAT_BIT    LATDbits.LATD1
            #define CS_FLASH_TRIS_BIT   TRISDbits.TRISD1
            #define POWERON_LAT_BIT     LATCbits.LATC3
            #define POWERON_TRIS_BIT    TRISCbits.TRISC3
        #endif
    #elif (DISPLAY_CONTROLLER == SSD1906)
		// Definitions for reset line
		// Definitions for RS line
		// Definitions for CS line
		// Definitions for A0 line
        #define A0_LAT_BIT  LATDbits.LATD3
        #define A0_TRIS_BIT TRISDbits.TRISD3
		// Definitions for A17 line
        #define A17_LAT_BIT     LATGbits.LATG14
        #define A17_TRIS_BIT    TRISGbits.TRISG14
    #else
        #error GRAPHICS CONTROLLER IS NOT SUPPORTED
    #endif // (DISPLAY_CONTROLLER == ...
#elif defined (GFX_PICTAIL_V3)
    #else
    #endif
#elif defined (MULTI_MEDIA_BOARD_DM00123)
	#define RST_TRIS_BIT       TRISAbits.TRISA10
	#define RST_LAT_BIT        LATAbits.LATA10
	#define RS_TRIS_BIT        AD1PCFGbits.PCFG10 = 1, TRISBbits.TRISB10
	#define RS_LAT_BIT         LATBbits.LATB10
	#define CS_TRIS_BIT        TRISGbits.TRISG13
	#define CS_LAT_BIT         LATGbits.LATG13
	#define SetWaitDirection()  //(PORTSetPinsDigitalIn(IOPORT_B, BIT_15))
	#define WaitDataTx()        //while(!PORTReadBits(IOPORT_B, BIT_15))
#elif defined (PIC24FJ256DA210_DEV_BOARD)
	// Definitions for DISPLAY POWER ON pin
	#define POWERON_LAT_BIT     LATAbits.LATA5
    #define POWERON_TRIS_BIT    TRISAbits.TRISA5
	#if defined (GFX_EPMP_CS1_BASE_ADDRESS)
		#define EPMPCS1_CS_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS1_WR_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS1_RD_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS1_BE_POLARITY	GFX_ACTIVE_LOW
		// macros to define the access timing of the parallel device in EPMP CS1
		#define EPMPCS1_DWAITB		0		// chip select 1 data set up before read/write strobe
		#define EPMPCS1_DWAITM		0		// chip select 1 read/write strobe wait states
		#define EPMPCS1_DWAITE		0		// chip select 1 data hold after read/write strobe
		#define EPMPCS1_AMWAIT		0		// chip select 1 Alternate Master wait state 
	#endif
	#if defined (GFX_EPMP_CS2_BASE_ADDRESS)
		#define EPMPCS2_CS_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS2_WR_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS2_RD_POLARITY	GFX_ACTIVE_LOW
		#define EPMPCS2_BE_POLARITY	GFX_ACTIVE_LOW
		// macros to define the access timing of the parallel device in EPMP CS2
		#define EPMPCS2_DWAITB		0		// chip select 2 data set up before read/write strobe
		#define EPMPCS2_DWAITM		4		// chip select 2 read/write strobe wait states
		#define EPMPCS2_DWAITE		0		// chip select 2 data hold after read/write strobe
		#define EPMPCS2_AMWAIT		3		// chip select 2 Alternate Master wait state 
	#endif
#endif //  defined (GFX_PICTAIL_V1)...
* IO FOR THE BEEPER
#if defined (GFX_PICTAIL_V2) || defined (GFX_PICTAIL_V1)
		#define BEEP_TRIS_BIT   TRISBbits.TRISB4
		#define BEEP_LAT_BIT    LATBbits.LATB4
	#else
		#define BEEP_TRIS_BIT   TRISDbits.TRISD0
		#define BEEP_LAT_BIT    LATDbits.LATD0
	#endif
#elif defined (GFX_PICTAIL_V3) || defined (PIC24FJ256DA210_DEV_BOARD)
#endif // #if defined (GFX_PICTAIL_V2)
* IOS FOR THE FLASH/EEPROM SPI
	#define USE_SST25_SPI2
            #define EEPROM_CS_TRIS  TRISAbits.TRISA0
            #define EEPROM_CS_LAT   LATAbits.LATA0
        #elif defined(__PIC24FJ256GB110__)
			// This PIM has RD12 rerouted to RG0
            #define EEPROM_CS_TRIS  TRISGbits.TRISG0
            #define EEPROM_CS_LAT   LATGbits.LATG0
        #else
            #define EEPROM_CS_TRIS  TRISDbits.TRISD12
            #define EEPROM_CS_LAT   LATDbits.LATD12
        #endif
    #endif
        #define EEPROM_SCK_TRIS TRISCbits.TRISC2
        #define EEPROM_SDO_TRIS TRISCbits.TRISC0
        #define EEPROM_SDI_TRIS TRISCbits.TRISC1
    #else
        #define EEPROM_SCK_TRIS TRISGbits.TRISG6
        #define EEPROM_SDO_TRIS TRISGbits.TRISG8
        #define EEPROM_SDI_TRIS TRISGbits.TRISG7
    #endif
        #define SST25_CS_TRIS   TRISAbits.TRISA8
        #define SST25_CS_LAT    LATAbits.LATA8
        #define SST25_SCK_TRIS  TRISCbits.TRISC2
        #define SST25_SDO_TRIS  TRISCbits.TRISC0
        #define SST25_SDI_TRIS  TRISCbits.TRISC1
    #else
        #define SST25_CS_TRIS   TRISDbits.TRISD1
        #define SST25_CS_LAT    LATDbits.LATD1
        #define SST25_SCK_TRIS  TRISGbits.TRISG6
        #define SST25_SDO_TRIS  TRISGbits.TRISG8
        #define SST25_SDI_TRIS  TRISGbits.TRISG7
		#define SST25_SDI_ANS   ANSGbits.ANSG7
    #endif
    #define SST25_CS_TRIS   TRISAbits.TRISA14
    #define SST25_CS_LAT    LATAbits.LATA14
    #define SST25_SCK_TRIS  TRISDbits.TRISD8
    #define SST25_SDO_TRIS  TRISBbits.TRISB1
    #define SST25_SDI_TRIS  TRISBbits.TRISB0
    #define SST25_SDI_ANS   ANSBbits.ANSB0
    #define SST25_SDO_ANS   ANSBbits.ANSB1
	#if defined (PIC32_GP_SK_DM320001) || defined (PIC32_USB_SK_DM320003_1)  
	#elif defined (PIC32_USB_SK_DM320003_2)
		#define USE_SST25_SPI2A
	#elif defined (PIC32_ENET_SK_DM320004)
		#define USE_SST25_SPI3A
	#else
		#error "Please define the starter kit that you are using"
	#endif
	// define the CPLD SPI selection and chip select
	#ifdef USE_SST25_SPI2
		#define SST25_CS_TRIS   TRISGbits.TRISG9
		#define SST25_CS_LAT    LATGbits.LATG9
		#define SPI_FLASH_CHANNEL   CPLD_SPI2
	#elif defined (USE_SST25_SPI2A)
		#define SPI_FLASH_CHANNEL   CPLD_SPI2A
	#elif defined (USE_SST25_SPI3A)
		#define SST25_CS_TRIS   TRISFbits.TRISF12
		#define SST25_CS_LAT    LATFbits.LATF12
		#define SPI_FLASH_CHANNEL   CPLD_SPI3A
	#else
		#error "SPI Channel can't be used for SPI Flash"
	#endif
#endif
* IOS FOR THE GRAPHICS PICTAIL PARALLEL FLASH MEMORY
	#define SST39_CS_TRIS    TRISDbits.TRISD9
	#define SST39_CS_LAT     LATDbits.LATD9
	#define SST39_A18_TRIS   TRISBbits.TRISB11
	#define SST39_A18_LAT    LATBbits.LATB11
	#define SST39_A17_TRIS   TRISBbits.TRISB10
	#define SST39_A17_LAT    LATBbits.LATB10
	#define SST39_A16_TRIS   TRISDbits.TRISD3
	#define SST39_A16_LAT    LATDbits.LATD3
#elif defined(GFX_PICTAIL_V2)
		#define SST39_CS_TRIS    TRISAbits.TRISA8
		#define SST39_CS_LAT     LATAbits.LATA8
		#define SST39_A18_TRIS   TRISAbits.TRISA1
		#define SST39_A18_LAT    LATAbits.LATA1
		#define SST39_A17_TRIS   TRISCbits.TRISC5
		#define SST39_A17_LAT    LATCbits.LATC5
		#define SST39_A16_TRIS   TRISCbits.TRISC4
		#define SST39_A16_LAT    LATCbits.LATC4
	#else
		#define SST39_CS_TRIS    TRISDbits.TRISD1
		#define SST39_CS_LAT     LATDbits.LATD1
		#define SST39_A18_TRIS   TRISCbits.TRISC2
		#define SST39_A18_LAT    LATCbits.LATC2
		#define SST39_A17_TRIS   TRISGbits.TRISG15
		#define SST39_A17_LAT    LATGbits.LATG15
		#define SST39_A16_TRIS   TRISGbits.TRISG14
		#define SST39_A16_LAT    LATGbits.LATG14
	#endif
#endif
* IOS FOR THE TOUCH SCREEN
// ADC Status
#define TOUCH_ADC_DONE			AD1CON1bits.DONE
// ADC channel constants
#if defined (PIC24FJ256DA210_DEV_BOARD)
	#define ADC_TEMP    4
	#define ADC_POT     5
	/* The Multi-Media Development Board does not have a
     * analog pot or temperature sensor (see BMA150 for temperature
     * sensor data
#else
		#define ADC_TEMP        4
		#define ADC_POT         0
		#define ADC_POT_TRIS    TRISAbits.TRISA0
		#define ADC_POT_PCFG    AD1PCFGLbits.PCFG0
		#define ADC_TEMP    ADC_CH0_POS_SAMPLEA_AN4
		#define ADC_POT     ADC_CH0_POS_SAMPLEA_AN5
	#else
		#define ADC_TEMP    4
		#define ADC_POT     5
	#endif
#endif 
    #ifdef __PIC32MX__
        #define ADC_XPOS    ADC_CH0_POS_SAMPLEA_AN13
        #define ADC_YPOS    ADC_CH0_POS_SAMPLEA_AN12
    #else
        #define ADC_XPOS    13
        #define ADC_YPOS    12
    #endif
	// Y port definitions
    #define ADPCFG_XPOS AD1PCFGbits.PCFG13
    #define LAT_XPOS    LATBbits.LATB13
    #define LAT_XNEG    LATBbits.LATB11
    #define TRIS_XPOS   TRISBbits.TRISB13
    #define TRIS_XNEG   TRISBbits.TRISB11
	// X port definitions
    #define ADPCFG_YPOS AD1PCFGbits.PCFG12
    #define LAT_YPOS    LATBbits.LATB12
    #define LAT_YNEG    LATBbits.LATB10
    #define TRIS_YPOS   TRISBbits.TRISB12
    #define TRIS_YNEG   TRISBbits.TRISB10
        #define ADC_XPOS    5
        #define ADC_YPOS    4
        #define ADC_XPOS    ADC_CH0_POS_SAMPLEA_AN11
        #define ADC_YPOS    ADC_CH0_POS_SAMPLEA_AN10
    #else
        #define ADC_XPOS    11
        #define ADC_YPOS    10
    #endif
        #define ADPCFG_XPOS AD1PCFGLbits.PCFG5
        #define LAT_XPOS    LATBbits.LATB3
        #define LAT_XNEG    LATCbits.LATC9
        #define TRIS_XPOS   TRISBbits.TRISB3
        #define TRIS_XNEG   TRISCbits.TRISC9
        #define ADPCFG_YPOS AD1PCFGLbits.PCFG4
        #define LAT_YPOS    LATBbits.LATB2
        #define LAT_YNEG    LATCbits.LATC8
        #define TRIS_YPOS   TRISBbits.TRISB2
        #define TRIS_YNEG   TRISCbits.TRISC8
    #else
        #define ADPCFG_XPOS AD1PCFGbits.PCFG11
        #define LAT_XPOS    LATBbits.LATB11
        #define LAT_XNEG    LATGbits.LATG13
        #define TRIS_XPOS   TRISBbits.TRISB11
        #define TRIS_XNEG   TRISGbits.TRISG13
        #define ADPCFG_YPOS AD1PCFGbits.PCFG10
        #define LAT_YPOS    LATBbits.LATB10
        #define LAT_YNEG    LATGbits.LATG12
        #define TRIS_YPOS   TRISBbits.TRISB10
        #define TRIS_YNEG   TRISGbits.TRISG12
    #endif
        #define ADC_XPOS    5
        #define ADC_YPOS    4
    #else
        #define ADC_XPOS    11
        #define ADC_YPOS    10
    #endif
    #else
        #if defined(__32MX460F512L__) && !defined (PIC32_USB_SK_DM320003_1)
            #define LAT_XNEG    LATGbits.LATG15
            #define TRIS_XNEG   TRISGbits.TRISG15
        #else
            #define LAT_XNEG    LATDbits.LATD9
            #define TRIS_XNEG   TRISDbits.TRISD9
        #endif
        #define LAT_YNEG    LATDbits.LATD8
        #define TRIS_YNEG   TRISDbits.TRISD8
    #endif
    #if defined(__PIC24FJ256DA210__)
        #define ADC_XPOS    16
        #define ADC_YPOS    18
        #define ADPCFG_XPOS ANSCbits.ANSC4
        #define LAT_XPOS    LATCbits.LATC4
        #define TRIS_XPOS   TRISCbits.TRISC4
        #define LAT_XNEG    LATAbits.LATA2
        #define TRIS_XNEG   TRISAbits.TRISA2
        #define ADPCFG_YPOS ANSGbits.ANSG7
        #define LAT_YPOS    LATGbits.LATG7
        #define TRIS_YPOS   TRISGbits.TRISG7
    	#define LAT_YNEG    LATAbits.LATA1
        #define TRIS_YNEG   TRISAbits.TRISA1
    #endif
	#define ADC_YPOS    ADC_CH0_POS_SAMPLEA_AN14
	#define LAT_XNEG    LATBbits.LATB13
	#define TRIS_XNEG   AD1PCFGbits.PCFG13 = 1, TRISBbits.TRISB13
	#define ADPCFG_YPOS AD1PCFGbits.PCFG14
	#define LAT_YPOS    LATBbits.LATB14
	#define TRIS_YPOS   TRISBbits.TRISB14
	#define LAT_YNEG    LATBbits.LATB12 
	#define TRIS_YNEG   AD1PCFGbits.PCFG12 = 1, TRISBbits.TRISB12
#endif
* IOS FOR THE SWITCHES (SIDE BUTTONS)
        #define BTN_S1  _RG8
        #define BTN_S2  _RE9
        #define BTN_S3  _RB5
      #endif 
      #define BTN_S3  1 
      #define BTN_S4  1
      #define BTN_S5  1
      #define BTN_S6  1
#else
        #define BTN_S3  _RA9
        #define BTN_S4  1
        #define BTN_S5  1
        #define BTN_S6  1
      #elif defined (PIC32_USB_SK_DM320003_1) || defined (PIC32_USB_SK_DM320003_2) || defined (PIC32_GP_SK_DM320001) 
        #define BTN_S3  1 
        #define BTN_S4  1
        #define BTN_S5  1
        #define BTN_S6  1
      #else
        #define BTN_S3  _RD6
        #define BTN_S4  _RD13
        #define BTN_S5  _RA7
        #define BTN_S6  _RD7
    #endif
#endif 
* IOS FOR THE TCON 
		#define CS_PORT     _RA0
		#define CS_TRIS     _TRISA0
		#define CS_DIG()
		#define SCL_PORT    _RD8
		#define SCL_TRIS    _TRISD8
		#define SCL_DIG()
		#define SDO_PORT    _RB1
		#define SDO_TRIS    _TRISB1
		#define SDO_DIG()   _ANSB1 = 0;
		#define DC_PORT     _RB0
		#define DC_TRIS     _TRISB0
		#define DC_DIG()    _ANSB0 = 0;
#endif // #if defined (DA210_DEV_BOARD)...
#endif //ifdef _GRAPHICS_H
* IOS FOR THE UART
    #define TX_TRIS TRISCbits.TRISC1
    #define RX_TRIS TRISCbits.TRISC0
#elif defined(__PIC24FJ256DA210__)    
    #define TX_TRIS TRISFbits.TRISF3
    #define RX_TRIS TRISDbits.TRISD0
#else
    #define TX_TRIS TRISFbits.TRISF5
    #define RX_TRIS TRISFbits.TRISF4
#endif
* RTCC DEFAULT INITIALIZATION (these are values to initialize the RTCC
#define RTCC_DEFAULT_DAY        29      // 29
#define RTCC_DEFAULT_MONTH      4       // April
#define RTCC_DEFAULT_YEAR       10      // 2010
#define RTCC_DEFAULT_WEEKDAY    04      // Thursday
#define RTCC_DEFAULT_HOUR       10      // 10:10:01
#define RTCC_DEFAULT_MINUTE     10
#define RTCC_DEFAULT_SECOND     01
#if defined (MULTI_MEDIA_BOARD_DM00123)
#include <plib.h>
* Configuration for the CPLD
#ifdef USE_16BIT_PMP
#define GRAPHICS_HW_CONFIG     CPLD_GFX_CONFIG_16BIT
#else
#define GRAPHICS_HW_CONFIG     CPLD_GFX_CONFIG_8BIT
#endif
* MMB LEDs
typedef enum
    LED_2,
    LED_3,
    LED_4,
    LED_5,
    LED_10
}MMB_LED;
extern inline void __attribute__((always_inline)) SetLEDDirection(void)
   PORTSetPinsDigitalOut(IOPORT_D, (BIT_1 | BIT_2 | BIT_3));
    PORTSetPinsDigitalOut(IOPORT_C, (BIT_1 | BIT_2));
extern inline void __attribute__((always_inline)) TurnLEDOn(MMB_LED led)
    if(led == LED_2)
      PORTSetBits(IOPORT_D, BIT_1);
    if(led == LED_3)
      PORTSetBits(IOPORT_D, BIT_2);
    if(led == LED_4)
      PORTSetBits(IOPORT_D, BIT_3);
    if(led == LED_5)
      PORTSetBits(IOPORT_C, BIT_1);
    if(led == LED_10)
      PORTSetBits(IOPORT_C, BIT_2);
extern inline void __attribute__((always_inline)) TurnLEDOff(MMB_LED led)
    if(led == LED_2)
      PORTClearBits(IOPORT_D, BIT_1);
    if(led == LED_3)
      PORTClearBits(IOPORT_D, BIT_2);
    if(led == LED_4)
      PORTClearBits(IOPORT_D, BIT_3);
    if(led == LED_5)
      PORTClearBits(IOPORT_C, BIT_1);
    if(led == LED_10)
      PORTClearBits(IOPORT_C, BIT_2);
extern inline void __attribute__((always_inline)) ToggleLED(MMB_LED led)
    if(led == LED_2)
      PORTToggleBits(IOPORT_D, BIT_1);
    if(led == LED_3)
      PORTToggleBits(IOPORT_D, BIT_2);
    if(led == LED_4)
      PORTToggleBits(IOPORT_D, BIT_3);
    if(led == LED_5)
      PORTToggleBits(IOPORT_C, BIT_1);
    if(led == LED_10)
      PORTToggleBits(IOPORT_C, BIT_2);
extern inline void __attribute__((always_inline)) TurnLEDAllOn(void)
extern inline void __attribute__((always_inline)) TurnLEDAllOff(void)
#endif // #ifdef (MULTI_MEDIA_BOARD_DM00123)
#endif // __HARDWARE_PROFILE_H
