;                         OPEN RFID TAG - EM4100 TAG                           ;
;    Author:    Ramiro Pareja                                                  ;
;    E mail:    ramiropareja -at- t4f -dot- org                                ;
;    Web:       www.t4f.org                                                    ;
;    Date:      30/05/2009                                                     ;
;    Description: Simple EM4100 RFID emulator                                  ;
;                 More info -> http://www.t4f.org                              ;
;    License:   Software released under the GPL 3 license;                     ;
;               Commercial license avaliable under request;                    ;
;               See www.t4f.org/license                                        ;
#include "p12f683.inc"
	__CONFIG       _WDT_OFF & _BOD_OFF & _PWRTE_ON & _EC_OSC
;    MACRO:     TX                                                             ;
;    Desc.:     Transmits data to the reader                                   ;
;    Params.:   DATA -> data to transmit                                       ;
;               NUM_BITS -> number of bits to transmit                         ;
;               PARITY_CHECK -> calculates the parity bit                      ;
;    Notes:        ; 
TX	MACRO	DATA, NUM_BITS, PARITY_CHECK
	LOCAL i = NUM_BITS
	LOCAL tmp = DATA
	LOCAL parity = 0
	LOCAL mask = 0x01 << (NUM_BITS-1)
	WHILE i > 0
		IF (tmp & mask)
			CALL	_TX_manchester_one
			parity = !parity
		ELSE
			CALL	_TX_manchester_zero
		ENDIF
		tmp = tmp << 1
		i -=  1
	ENDW
	IF (PARITY_CHECK == 1)
		IF (parity)
		ELSE
		ENDIF	
	ENDIF
	ENDM
	ORG 0x00
;    Function:  _configuration                                                 ;
;    Desc.:     Configures the microcontroller                                 ;
;    Notes:     If you want to port the firmware to another 12F or 16F micro,  ; 
;               you have to change only this function. Be sure that you        ;
;               configure the IO ports as digital inputs.                      ;
	BSF	STATUS,RP0 		; Bank 1
	CLRF	ANSEL 			; GPIOs as digital ports
	BCF	STATUS,RP0		; Bank 0
	MOVLW	07h 			; Turning off the analog comparators
	MOVWF	CMCON0
	CLRF	ADCON0              	; turn off A/D convertor
;    Function:  _main                                                          ;
;    Desc.:     Main program loopm. Transmits the data.                        ;
;    Notes:     The firmware emulates an EM4100 tag with the next memory map   ;
;               111111111 			<- Header                      ;
;               00011 00011                     <- Manufacturer ID             ;
;               00011 00011 00011 00011         <- Serial number               ;
;               00011 00011 00011 00011                                        ;
;               11110                           <- parity column and stop bit  ;
_main
	BSF	STATUS, RP0		; Bank 1
	; Transmits the header ('111111111')
	TX	 0x1FF, 9, 0
	; Transmits the manufacturer ID (with parity bit)
	TX	0x00, 4, 1
	TX	0x00, 4, 1
	; Transmits the serial number (with parity bit)
	TX	0x01, 4, 1
	TX	0x01, 4, 1
	TX	0x08, 4, 1
	TX	0x02, 4, 1
	TX	0x09, 4, 1
	TX	0x08, 4, 1
	TX	0x03, 4, 1
	TX	0x09, 4, 1
	; Transmit the parity column (previosly calculated) and the stop bit ('0')
	TX	b'11100', 5, 0
	bcf	STATUS, RP0		; Bank 0
	goto 	_main			; Repeat the transmition
;    Function:  _TX_manchester_one                                             ;
;    Desc.:     Transmit a '1'                                                 ;
;    Notes:     Manchester encoding at 64 clocks per bit is used.              ;
;               To change the data rate, just add or remove NOP instructions   ;
;               Using a Biphase encoding would require more complex changes.   ;
;               However, you can transmit a biphase encoded memory map if you  ;
;               encode the raw data transmited as Manchester.                  ;
_TX_manchester_one
	BSF 	TRISIO, GP4		; GP4 to High impedance. TX a zero
	NOP				; Waiting for 32 clocks (8 instructions)
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	BCF 	TRISIO, GP4		; GP4 to GND. TX a one
	NOP
	NOP
	RETURN				; The RETURN and the next CALL 
					; instructions count as 16 clocks (4*4)
;    Function:  _TX_manchester_zero                                            ;
;    Desc.:     Transmit a '0'                                                 ;
_TX_manchester_zero
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	NOP
	END
