		Readme File for Code Example:
              CE404 - Clock Switch
This file contains the following sections:
1. Code Example Description
2. Folder Contents
3. Suggested Development Resources
4. Reconfiguring the project for a different dsPIC33E device
5. Revision History
1. Code Example Description:
In this example, CPU is initially configured to run from external secondary osc and then clock switching
is initiated to run from Internal FRC.
extern void clockSwitch(unsigned int r);
This function selects the next clock input and initiates clock switch sequence.
2. Folder Contents:
This folder contains the following sub-folders:
a. C:\Program Files\Microchip\MPLAB C30\support\gld
        This folder will have the device GLD file, it is used for building the project.
	This file was provided with the MPLAB C30 toolsuite.
b. C:\Program Files\Microchip\MPLAB C30\support\h
        This folder contains C header files useful in building this
        project. Device register and bit definitions are provided in
        the *.h file that follows the device name. These files were provided
c. C:\Program Files\Microchip\MPLAB C30\lib
        This folder contains library archive files, which are a
        collection of precompiled object files. The file
        named "libpic30-coff.a" contains the C run-time start-up
        library. These file were provided with the
d. hex
        This folder contains three file types - coff, hex and map.
        These are files generated by the MPLAB C30 toolsuite on build
        operation performed within MPLAB IDE. The *.map file contains
        details on memory allocation for various variables, constants
        and dsPIC instructions specified in the source and library
        code. The *.hex file contains a binary file that may be
        programmed into the dsPIC device. The *.coff file contains
        a binary file that is used by MPLAB IDE for simulation.
e. h
        This folder contains include files for the code example.
f. src
        This folder contains all the C and Assembler source files (*.c,
        *.s) used in demonstrating the described example. This folder
        also contains a sub-folder named "obj" that stores compiled
        object files generated when the project is built.
3. Suggested Development Resources:
        a. Explorer 16 Demo board with dsPIC33EP512MU810 controller
4. Reconfiguring the project for a different dsPIC33E device:
The Project/Workspace can be easily reconfigured for any dsPIC33E device.
Please use the following general guidelines:
        a. Change device selection within MPLAB IDE to a dsPIC33E device of
        your choice by using the following menu option:
        MPLAB IDE>>Configure>>Select Device
        b. Provide the correct device linker script and header file for your
        device. Device linker scripts and header files are available in your
        MPLAB C30 installation folder under:
        Device Linker Script-
                YourDrive:>Program Files\Microchip\MPLAB C30\support\gld
        Device C Header file-
                YourDrive:>Program Files\Microchip\MPLAB C30\support\h
        Device ASM Include file-
                YourDrive:>Program Files\Microchip\MPLAB C30\support\inc
        c. Provide the appropriate path to your MPLAB C30 support file locations
        using the menu option:
        MPLAB IDE>>Project>>Build Options>>Project
        d. Chose the development board applicable to your device. Some options
        are provided below:
        e. Re-build the MPLAB project using the menu option:
        MPLAB IDE>>Project>>Build All
        f. Download the hex file into the device and run.
5. Revision History :
        04/01/2006 - Initial Release of the Code Example
	07/01/2010 - Code Example updated for dsPIC33E
