; File Created by SDCC : free open source ANSI-C Compiler
; Version 3.1.0 #7066 (Dec 27 2011) (Linux)
; This file was generated Wed Mar  7 17:41:49 2012
; PIC16 port for the Microchip 16-bit core micros
	.ident "SDCC version 3.1.0 #7066 [pic16 port]"
	.file	"pruebapyc.c"
	list	p=18f4455
	__config 0x300000, 0xc0
	__config 0x300001, 0x38
	__config 0x300002, 0xde
	__config 0x300003, 0xfe
	__config 0x300005, 0xfb
	__config 0x300006, 0x9b
	__config 0x300008, 0xff
	__config 0x300009, 0xff
	__config 0x30000a, 0xff
	__config 0x30000b, 0xff
	__config 0x30000c, 0xff
	__config 0x30000d, 0xff
	radix dec
; public variables in this module
	global _encender_led
	global _apagar_led
	global _main
; extern variables in this module
	extern _SPPDATAbits
	extern _SPPCFGbits
	extern _SPPEPSbits
	extern _SPPCONbits
	extern _UFRMLbits
	extern _UFRMHbits
	extern _UIRbits
	extern _UIEbits
	extern _UEIRbits
	extern _UEIEbits
	extern _USTATbits
	extern _UCONbits
	extern _UADDRbits
	extern _UCFGbits
	extern _UEP0bits
	extern _UEP1bits
	extern _UEP2bits
	extern _UEP3bits
	extern _UEP4bits
	extern _UEP5bits
	extern _UEP6bits
	extern _UEP7bits
	extern _UEP8bits
	extern _UEP9bits
	extern _UEP10bits
	extern _UEP11bits
	extern _UEP12bits
	extern _UEP13bits
	extern _UEP14bits
	extern _UEP15bits
	extern _PORTAbits
	extern _PORTBbits
	extern _PORTCbits
	extern _PORTDbits
	extern _PORTEbits
	extern _LATAbits
	extern _LATBbits
	extern _LATCbits
	extern _LATDbits
	extern _LATEbits
	extern _TRISAbits
	extern _TRISBbits
	extern _TRISCbits
	extern _TRISDbits
	extern _TRISEbits
	extern _OSCTUNEbits
	extern _PIE1bits
	extern _PIR1bits
	extern _IPR1bits
	extern _PIE2bits
	extern _PIR2bits
	extern _IPR2bits
	extern _EECON1bits
	extern _RCSTAbits
	extern _TXSTAbits
	extern _T3CONbits
	extern _CMCONbits
	extern _CVRCONbits
	extern _ECCP1ASbits
	extern _ECCP1DELbits
	extern _BAUDCONbits
	extern _CCP2CONbits
	extern _CCP1CONbits
	extern _ADCON2bits
	extern _ADCON1bits
	extern _ADCON0bits
	extern _SSPCON2bits
	extern _SSPCON1bits
	extern _SSPSTATbits
	extern _T2CONbits
	extern _T1CONbits
	extern _RCONbits
	extern _WDTCONbits
	extern _HLVDCONbits
	extern _OSCCONbits
	extern _T0CONbits
	extern _STATUSbits
	extern _FSR2Hbits
	extern _BSRbits
	extern _FSR1Hbits
	extern _FSR0Hbits
	extern _INTCON3bits
	extern _INTCON2bits
	extern _INTCONbits
	extern _TBLPTRUbits
	extern _PCLATHbits
	extern _PCLATUbits
	extern _STKPTRbits
	extern _TOSUbits
	extern _SPPDATA
	extern _SPPCFG
	extern _SPPEPS
	extern _SPPCON
	extern _UFRML
	extern _UFRMH
	extern _UIR
	extern _UIE
	extern _UEIR
	extern _UEIE
	extern _USTAT
	extern _UCON
	extern _UADDR
	extern _UCFG
	extern _UEP0
	extern _UEP1
	extern _UEP2
	extern _UEP3
	extern _UEP4
	extern _UEP5
	extern _UEP6
	extern _UEP7
	extern _UEP8
	extern _UEP9
	extern _UEP10
	extern _UEP11
	extern _UEP12
	extern _UEP13
	extern _UEP14
	extern _UEP15
	extern _PORTA
	extern _PORTB
	extern _PORTC
	extern _PORTD
	extern _PORTE
	extern _LATA
	extern _LATB
	extern _LATC
	extern _LATD
	extern _LATE
	extern _TRISA
	extern _TRISB
	extern _TRISC
	extern _TRISD
	extern _TRISE
	extern _OSCTUNE
	extern _PIE1
	extern _PIR1
	extern _IPR1
	extern _PIE2
	extern _PIR2
	extern _IPR2
	extern _EECON1
	extern _EECON2
	extern _EEDATA
	extern _EEADR
	extern _RCSTA
	extern _TXSTA
	extern _TXREG
	extern _RCREG
	extern _SPBRG
	extern _SPBRGH
	extern _T3CON
	extern _TMR3L
	extern _TMR3H
	extern _CMCON
	extern _CVRCON
	extern _ECCP1AS
	extern _ECCP1DEL
	extern _BAUDCON
	extern _CCP2CON
	extern _CCPR2L
	extern _CCPR2H
	extern _CCP1CON
	extern _CCPR1L
	extern _CCPR1H
	extern _ADCON2
	extern _ADCON1
	extern _ADCON0
	extern _ADRESL
	extern _ADRESH
	extern _SSPCON2
	extern _SSPCON1
	extern _SSPSTAT
	extern _SSPADD
	extern _SSPBUF
	extern _T2CON
	extern _PR2
	extern _TMR2
	extern _T1CON
	extern _TMR1L
	extern _TMR1H
	extern _RCON
	extern _WDTCON
	extern _HLVDCON
	extern _OSCCON
	extern _T0CON
	extern _TMR0L
	extern _TMR0H
	extern _STATUS
	extern _FSR2L
	extern _FSR2H
	extern _PLUSW2
	extern _PREINC2
	extern _POSTDEC2
	extern _POSTINC2
	extern _INDF2
	extern _BSR
	extern _FSR1L
	extern _FSR1H
	extern _PLUSW1
	extern _PREINC1
	extern _POSTDEC1
	extern _POSTINC1
	extern _INDF1
	extern _WREG
	extern _FSR0L
	extern _FSR0H
	extern _PLUSW0
	extern _PREINC0
	extern _POSTDEC0
	extern _POSTINC0
	extern _INDF0
	extern _INTCON3
	extern _INTCON2
	extern _INTCON
	extern _PRODL
	extern _PRODH
	extern _TABLAT
	extern _TBLPTRL
	extern _TBLPTRH
	extern _TBLPTRU
	extern _PCL
	extern _PCLATH
	extern _PCLATU
	extern _STKPTR
	extern _TOSL
	extern _TOSH
	extern _TOSU
	extern _delay10ktcy
;	Equates to used internal registers
FSR1L	equ	0xfe1
FSR2L	equ	0xfd9
POSTDEC1	equ	0xfe5
PREINC1	equ	0xfe4
; interrupt vector
; global & static initialisations
; I code from now on!
; ; Starting pCode block
S_pruebapyc__main	code
_main:
	.line	33; pruebapyc.c	TRISCbits.TRISC0 = 0;
	BCF	_TRISCbits, 0
	.line	34; pruebapyc.c	LATCbits.LATC0 = 0;
	BCF	_LATCbits, 0
_00116_DS_:
	.line	37; pruebapyc.c	delay10ktcy(i);
	MOVLW	0x05
	CALL	_delay10ktcy
	.line	38; pruebapyc.c	apagar_led();
	CALL	_apagar_led
	.line	39; pruebapyc.c	delay10ktcy(10);
	MOVLW	0x0a
	CALL	_delay10ktcy
	.line	40; pruebapyc.c	encender_led();
	CALL	_encender_led
	BRA	_00116_DS_
	RETURN
S_pruebapyc__apagar_led	code
_apagar_led:
	.line	24; pruebapyc.c	void apagar_led ()
	MOVFF	FSR2L, POSTDEC1
	MOVFF	FSR1L, FSR2L
	.line	26; pruebapyc.c	LATCbits.LATC0 = 1;
	BSF	_LATCbits, 0
	MOVFF	PREINC1, FSR2L
	RETURN
S_pruebapyc__encender_led	code
_encender_led:
	.line	19; pruebapyc.c	void encender_led ()
	MOVFF	FSR1L, FSR2L
	.line	21; pruebapyc.c	LATCbits.LATC0 = 0;
	BCF	_LATCbits, 0
	RETURN
; Statistics:
; code size:	   60 (0x003c) bytes ( 0.05%)
;           	   30 (0x001e) words
; udata size:	    0 (0x0000) bytes ( 0.00%)
; access size:	    0 (0x0000) bytes
	end
