program new_example_glcd_16f877a ' Declarations section dim GLCD_DataPORT as byte at PORTD dim GLCD_CS1 as sbit at RC0_bit ' Conexiones del módulo Glcd GLCD_CS2 as sbit at RC1_bit GLCD_RS as sbit at RC2_bit GLCD_RW as sbit at RC3_bit GLCD_EN as sbit at RC4_bit GLCD_RST as sbit at RC5_bit dim GLCD_CS1_Direction as sbit at TRISC0_bit GLCD_CS2_Direction as sbit at TRISC1_bit GLCD_RS_Direction as sbit at TRISC2_bit GLCD_RW_Direction as sbit at TRISC3_bit GLCD_EN_Direction as sbit at TRISC4_bit GLCD_RST_Direction as sbit at TRISC5_bit ' Final de conexiones del módulo Glcd dim t as byte 'variavle t del tipo byte main: INTCON = 0 ' Todas las interrupciones deshabilitadas ADCON0=%11010001 ADCON1=%00000000 TRISA = 0x00 PORTA =0 t= 10 Glcd_Init() ' Glcd_Init_EP5 Glcd_Set_Font(@font5x7, 5, 7, 32) ' Seleccionar el tamaño de fuente 5x7 Glcd_Fill(0) ' Borrar el GLCD Glcd_Write_Text("ING. ELECTRONICA",10,0,1) Glcd_Write_Text("GLCD Y PANEL TACTIL",10,7,1) Glcd_Set_Side(1) Glcd_Set_X(10) Glcd_Set_Page(4) Glcd_Write_data(48+tlong) end.
