#include <18f4550.h>
#fuses HS,MCLR,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOPBADEN,NOLVP,NOCPD,NODEBUG,NOWRT,NOVREGEN
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
const long Low    = 666;
const long Medium = 333;
const long Fast   = 111;
const long Mega   = 55;
const long Ultra  = 22;
char Keypress=' ';
char Speed;
#int_rda
void serial_isr() {
   Keypress=0x00;
   if(kbhit()){
      Keypress=getc();
      if(Keypress!=0x00){
         putchar(keypress);
         if((keypress>'0')&&(keypress<'6')){
            Speed=keypress;
         if(keypress=='F'){
            Speed='\0';
         keypress=0x00;
void My_Delay(void){
   Switch(Speed){
      case '1': delay_ms(Low);    break;
      case '2': delay_ms(Medium); break;
      case '3': delay_ms(Fast);   break;
      case '4': delay_ms(Mega);   break;
      case '5': delay_ms(Ultra);  break;
void main() {
   int i=0,j;
   disable_interrupts(global);
   disable_interrupts(int_timer1);
   disable_interrupts(int_rda);
   disable_interrupts(int_ext);
   disable_interrupts(int_ext1);
   disable_interrupts(int_ext2);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_psp(PSP_DISABLED);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_timer_0(RTCC_OFF);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   setup_timer_3(T3_DISABLED);
   setup_vref(FALSE);
   port_b_pullups(FALSE);
   set_tris_b(0b00000000);
   set_tris_e(0b00010000);
   set_tris_c(0b10000000);
   enable_interrupts(global);
   enable_interrupts(int_rda);
   Output_b(0b00000000);
   Speed='1';
   printf("\r\n\Listen on RS232\r\n\n");
   printf("Press 1, 2, 3, 4, 5 or F\r\n\n");
   delay_ms(500);
   do {
      Output_b(i++);
      My_Delay();
      if(i==0){
         for(j=1;j<5;j++){
            Output_b(0xff);
            My_Delay();
            Output_b(0x00);
            My_Delay();
   } while (TRUE);
