LIBRERIA MODIFICADA PARA USO CON placa felixls EN PUERTO D CON PATA RW ACTIVA, Y 4 BITS
CONTROLES EN LOS PINES portd0-3 Y DATOS EN portd4-7
CONEXIONES:
lcd conectado en PUERTO D
bus de datos en el nible alto conector idc rb 4 a 7
DATA7    PUERTO D.7
DATA6    PUERTO D.6
DATA5    PUERTO D.5
DATA4    PUERTO D.4
bus de control en el nible bajo conector idc rb 0 a 3
E_PIN    PUERTO D.3
RS_PIN   PUERTO D.2
RW_PIN   PUERTO D.1
SE DEBE SELECCIONAR EL MODO DE MEMORIA LARGO LARGE MEMORY MODEL. SINO HAY QUE CAMBIAR LOS FAR POR NEAR.
#ifndef __XLCD_H
#define __XLCD_H
#include "p18cxxx.h"
/* PIC18 XLCD peripheral routines.
 *   Notes:
 *      - These libraries routines are written to support the
 *        Hitachi HD44780 LCD controller.
 *      - The user must define the following items:
 *          - The LCD interface type (4- or 8-bits)
 *          - If 4-bit mode
 *              - whether using the upper or lower nibble
 *          - The data port
 *              - The tris register for data port
 *              - The control signal ports and pins
 *              - The control signal port tris and pins
 *          - The user must provide three delay routines:
 *              - DelayFor18TCY() provides a 18 Tcy delay
 *              - DelayPORXLCD() provides at least 15ms delay
 *              - DelayXLCD() provides at least 5ms delay
/* Interface type 8-bit or 4-bit
 * For 8-bit operation uncomment the #define BIT8
/* #define BIT8 */
/* When in 4-bit interface define if the data is in the upper
 * or lower nibble.  For lower nibble, comment the #define UPPER
#define UPPER          
/* DATA_PORT defines the port to which the LCD data lines are connected */
#define DATA_PORT      PORTD
#define TRIS_DATA_PORT TRISD
/* CTRL_PORT defines the port where the control lines are connected.
 * These are just samples, change to match your application.
#define RW_PIN   LATDbits.LATD1   /* PORT for RW */ 
#define TRIS_RW  TRISDbits.TRISD1    /* TRIS for RW */ 
#define RS_PIN   LATDbits.LATD2   /* PORT for RS */ 
#define TRIS_RS  TRISDbits.TRISD2    /* TRIS for RS */ 
#define E_PIN    LATDbits.LATD3   /* PORT for D  */ 
#define TRIS_E   TRISDbits.TRISD3    /* TRIS for E  */
/* Display ON/OFF Control defines */
#define DON         0b00001111  /* Display on      */
#define DOFF        0b00001011  /* Display off     */
#define CURSOR_ON   0b00001111  /* Cursor on       */
#define CURSOR_OFF  0b00001101  /* Cursor off      */
#define BLINK_ON    0b00001111  /* Cursor Blink    */
#define BLINK_OFF   0b00001110  /* Cursor No Blink */
/* Cursor or Display Shift defines */
#define SHIFT_CUR_LEFT    0b00010011  /* Cursor shifts to the left   */
#define SHIFT_CUR_RIGHT   0b00010111  /* Cursor shifts to the right  */
#define SHIFT_DISP_LEFT   0b00011011  /* Display shifts to the left  */
#define SHIFT_DISP_RIGHT  0b00011111  /* Display shifts to the right */
/* Function Set defines */
#define FOUR_BIT   0b00101111  /* 4-bit Interface               */
#define EIGHT_BIT  0b00111111  /* 8-bit Interface               */
#define LINE_5X7   0b00110011  /* 5x7 characters, single line   */
#define LINE_5X10  0b00110111  /* 5x10 characters               */
#define LINES_5X7  0b00111011  /* 5x7 characters, multiple line */
#define PARAM_SCLASS auto
#define MEM_MODEL far  // MODIFICAMOS FAR POR NEAR
#define LINE_0   0b10000000     //linea inicial
#define NEXT_LINE 0b11000000
// definiciones de funciones --------------------------------------------------------
/* OpenXLCD
 * Configures I/O pins for external LCD
void OpenXLCD(PARAM_SCLASS unsigned char);
/* SetCGRamAddr
 * Sets the character generator address
void SetCGRamAddr(PARAM_SCLASS unsigned char);
/* SetDDRamAddr
 * Sets the display data address
void SetDDRamAddr(PARAM_SCLASS unsigned char);
/* BusyXLCD
 * Returns the busy status of the LCD
unsigned char BusyXLCD(void);
/* ReadAddrXLCD
 * Reads the current address
unsigned char ReadAddrXLCD(void);
/* ReadDataXLCD
 * Reads a byte of data
char ReadDataXLCD(void);
/* WriteCmdXLCD
 * Writes a command to the LCD
void WriteCmdXLCD(PARAM_SCLASS unsigned char);
/* WriteDataXLCD
 * Writes a data byte to the LCD
void WriteDataXLCD(PARAM_SCLASS char);
/* putcXLCD
 * A putc is a write
#define putcXLCD WriteDataXLCD
/* putsXLCD
 * Writes a string of characters to the LCD
void putsXLCD(PARAM_SCLASS char *);
/* putrsXLCD
 * Writes a string of characters in ROM to the LCD
void putrsXLCD(PARAM_SCLASS const MEM_MODEL rom char *);
/* User defines these routines according to the oscillator frequency */
extern void DelayFor18TCY(void);
extern void DelayPORXLCD(void);
extern void DelayXLCD(void);
#endif
*       Function Name:  OpenXLCD                                    *
*       Return Value:   void                                        *
*       Parameters:     lcdtype: sets the type of LCD (lines)       *
*       Description:    This routine configures the LCD. Based on   *
*                       the Hitachi HD44780 LCD controller. The     *
*                       routine will configure the I/O pins of the  *
*                       microcontroller, setup the LCD for 4- or    *
*                       8-bit mode and clear the display. The user  *
*                       must provide three delay routines:          *
*                       DelayFor18TCY() provides a 18 Tcy delay     *
*                       DelayPORXLCD() provides at least 15ms delay *
*                       DelayXLCD() provides at least 5ms delay     *
void OpenXLCD(unsigned char lcdtype)
        // The data bits must be either a 8-bit port or the upper or
        // lower 4-bits of a port. These pins are made into inputs
#ifdef BIT8                             // 8-bit mode, use whole port
        DATA_PORT = 0;
        TRIS_DATA_PORT = 0xff;
#else                                   // 4-bit mode
#ifdef UPPER                            // Upper 4-bits of the port
        DATA_PORT &= 0x0f;
        TRIS_DATA_PORT |= 0xf0;
#else                                   // Lower 4-bits of the port
        DATA_PORT &= 0xf0;
        TRIS_DATA_PORT |= 0x0f;
#endif
#endif
        TRIS_RW = 0;                    // All control signals made outputs
        TRIS_RS = 0;
        TRIS_E = 0;
        RW_PIN = 0;                     // R/W pin made low
        RS_PIN = 0;                     // Register select pin made low
        E_PIN = 0;                      // Clock pin made low
        // Delay for 15ms to allow for LCD Power on reset
        DelayPORXLCD();
        // Setup interface to LCD
#ifdef BIT8                             // 8-bit mode interface
        TRIS_DATA_PORT = 0;             // Data port output
        DATA_PORT = 0b00110000;         // Function set cmd(8-bit interface)
#else                                   // 4-bit mode interface
#ifdef UPPER                            // Upper nibble interface
        TRIS_DATA_PORT &= 0x0f;
        DATA_PORT &= 0x0f;
        DATA_PORT |= 0b00100000;        // Function set cmd(4-bit interface)
#else                                   // Lower nibble interface
        TRIS_DATA_PORT &= 0xf0;
        DATA_PORT &= 0xf0;
        DATA_PORT |= 0b00000010;        // Function set cmd(4-bit interface)
#endif
#endif
        E_PIN = 1;                      // Clock the cmd in
        DelayFor18TCY();
        E_PIN = 0;
        // Delay for at least 4.1ms
        DelayXLCD();
#ifdef BIT8                             // 8-bit interface
#else                                   // 4-bit interface
        DATA_PORT &= 0x0f;              // Function set cmd(4-bit interface)
        DATA_PORT &= 0xf0;              // Function set cmd(4-bit interface)
#endif
#endif
        DelayFor18TCY();
        E_PIN = 0;
        // Delay for at least 100us
        DelayXLCD();
#endif
#endif
        E_PIN = 1;                      // Clock cmd in
        DelayFor18TCY();
        E_PIN = 0;
        TRIS_DATA_PORT = 0xff;          // Make data port input
        TRIS_DATA_PORT |= 0xf0;         // Make data nibble input
        TRIS_DATA_PORT |= 0x0f;         // Make data nibble input
#endif
#endif
        // Set data interface width, # lines, font
        while(BusyXLCD());              // Wait if LCD busy
        WriteCmdXLCD(lcdtype);          // Function set cmd
        // Turn the display on then off
        WriteCmdXLCD(DOFF&CURSOR_OFF&BLINK_OFF);        // Display OFF/Blink OFF
        WriteCmdXLCD(DON&CURSOR_ON&BLINK_ON);           // Display ON/Blink ON
        // Clear display
        WriteCmdXLCD(0x01);             // Clear display
        // Set entry mode inc, no shift
        WriteCmdXLCD(SHIFT_CUR_LEFT);   // Entry Mode
        // Set DD Ram address to 0
        SetDDRamAddr(0);                // Set Display data ram address to 0
        return;
*       Function Name:  putrsXLCD
*       Parameters:     : pointer to string
*       Description:    This routine writes a string of bytes to the
*                       Hitachi HD44780 LCD controller. The user
*                       must check to see if the LCD controller is
*                       busy before calling this routine. The data
*                       is written to the character generator RAM or
*                       the display data RAM depending on what the
*                       previous SetxxRamAddr routine was called.
void putrsXLCD(const rom char *buffer_)
        while(*buffer_)                  // Write data to LCD up to null
                while(BusyXLCD());      // Wait while LCD is busy
                WriteDataXLCD(*buffer_); // Write character to LCD
                buffer_++;               // Increment buffer
        return;
*       Function Name:  putsXLCD
*       Parameters:     buffer: pointer to string
void putsXLCD(char *buffer)
        while(*buffer)                  // Write data to LCD up to null
                WriteDataXLCD(*buffer); // Write character to LCD
                buffer++;               // Increment buffer
        return;
*       Function Name:  ReadAddrXLCD                                 *
*       Return Value:   char: address from LCD controller            *
*       Parameters:     void                                         *
*       Description:    This routine reads an address byte from the  *
*                       Hitachi HD44780 LCD controller. The user     *
*                       must check to see if the LCD controller is   *
*                       busy before calling this routine. The address*
*                       is read from the character generator RAM or  *
*                       the display data RAM depending on what the   *
*                       previous SetxxRamAddr routine was called.    *
        char data;                      // Holds the data retrieved from the LCD
        RW_PIN = 1;                     // Set control bits for the read
        RS_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock data out of the LCD controller
        DelayFor18TCY();
        data = DATA_PORT;               // Save the data in the register
        E_PIN = 0;
        RW_PIN = 0;                     // Reset the control bits
        RS_PIN = 0;
        DelayFor18TCY();
        DelayFor18TCY();
        data = DATA_PORT&0xf0;          // Read the nibble into the upper nibble of data
        data = (DATA_PORT<<4)&0xf0;     // Read the nibble into the upper nibble of data
#endif
        E_PIN = 0;                      // Reset the clock
        DelayFor18TCY();
        E_PIN = 1;                      // Clock out the lower nibble
        DelayFor18TCY();
        data |= (DATA_PORT>>4)&0x0f;    // Read the nibble into the lower nibble of data
        data |= DATA_PORT&0x0f;         // Read the nibble into the lower nibble of data
#endif
        E_PIN = 0;
        RW_PIN = 0;                     // Reset the control lines
#endif
        return (data&0x7f);             // Return the address, Mask off the busy bit
*       Function Name:  ReadDataXLCD                                *
*       Return Value:   char: data byte from LCD controller         *
*       Description:    This routine reads a data byte from the     *
*                       busy before calling this routine. The data  *
        char data;
        RS_PIN = 1;                     // Set the control bits
        RW_PIN = 1;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock the data out of the LCD
        DelayFor18TCY();
        data = DATA_PORT;               // Read the data
        E_PIN = 0;
        RS_PIN = 0;                     // Reset the control bits
        RW_PIN = 0;
        RW_PIN = 1;
        RS_PIN = 1;
        DelayFor18TCY();
        DelayFor18TCY();
        data = DATA_PORT&0xf0;          // Read the upper nibble of data
        data = (DATA_PORT<<4)&0xf0;     // read the upper nibble of data
#endif
        E_PIN = 0;                      // Reset the clock line
        DelayFor18TCY();
        E_PIN = 1;                      // Clock the next nibble out of the LCD
        DelayFor18TCY();
        data |= (DATA_PORT>>4)&0x0f;    // Read the lower nibble of data
        data |= DATA_PORT&0x0f;         // Read the lower nibble of data
#endif
        E_PIN = 0;                                      
        RW_PIN = 0;
#endif
        return(data);                   // Return the data byte
*       Function Name:  SetCGRamAddr                                *
*       Parameters:     CGaddr: character generator ram address     *
*       Description:    This routine sets the character generator   *
*                       address of the Hitachi HD44780 LCD          *
*                       controller. The user must check to see if   *
*                       the LCD controller is busy before calling   *
*                       this routine.                               *
void SetCGRamAddr(unsigned char CGaddr)
        TRIS_DATA_PORT = 0;                     // Make data port ouput
        DATA_PORT = CGaddr | 0b01000000;        // Write cmd and address to port
        RW_PIN = 0;                             // Set control signals
        RS_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                              // Clock cmd and address in
        DelayFor18TCY();
        E_PIN = 0;
        DelayFor18TCY();
        TRIS_DATA_PORT = 0xff;                  // Make data port inputs
        TRIS_DATA_PORT &= 0x0f;                 // Make nibble input
        DATA_PORT &= 0x0f;                      // and write upper nibble
        DATA_PORT |= ((CGaddr | 0b01000000) & 0xf0);
        TRIS_DATA_PORT &= 0xf0;                 // Make nibble input
        DATA_PORT &= 0xf0;                      // and write upper nibble
        DATA_PORT |= (((CGaddr |0b01000000)>>4) & 0x0f);
#endif
        RS_PIN = 0;
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
        DATA_PORT &= 0x0f;                      // Write lower nibble
        DATA_PORT |= ((CGaddr<<4)&0xf0);
        DATA_PORT &= 0xf0;                      // Write lower nibble
        DATA_PORT |= (CGaddr&0x0f);
#endif
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
        TRIS_DATA_PORT |= 0xf0;                 // Make inputs
        TRIS_DATA_PORT |= 0x0f;                 // Make inputs
#endif
#endif
        return;
*       Function Name:  SetDDRamAddr                                *
*       Parameters:     CGaddr: display data address                *
*       Description:    This routine sets the display data address  *
*                       of the Hitachi HD44780 LCD controller. The  *
*                       user must check to see if the LCD controller*
*                       is busy before calling this routine.        *
void SetDDRamAddr(unsigned char DDaddr)
        TRIS_DATA_PORT = 0;                     // Make port output
        DATA_PORT = DDaddr | 0b10000000;        // Write cmd and address to port
        RW_PIN = 0;                             // Set the control bits
        RS_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                              // Clock the cmd and address in
        DelayFor18TCY();
        E_PIN = 0;
        DelayFor18TCY();
        TRIS_DATA_PORT = 0xff;                  // Make port input
        TRIS_DATA_PORT &= 0x0f;                 // Make port output
        DATA_PORT |= ((DDaddr | 0b10000000) & 0xf0);
        TRIS_DATA_PORT &= 0xf0;                 // Make port output
        DATA_PORT |= (((DDaddr | 0b10000000)>>4) & 0x0f);
#endif
        RW_PIN = 0;                             // Set control bits
        RS_PIN = 0;
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
        DATA_PORT |= ((DDaddr<<4)&0xf0);
        DATA_PORT |= (DDaddr&0x0f);
#endif
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
        TRIS_DATA_PORT |= 0xf0;                 // Make port input
        TRIS_DATA_PORT |= 0x0f;                 // Make port input
#endif
#endif
        return;
*       Function Name:  BusyXLCD                                    *
*       Return Value:   char: busy status of LCD controller         *
*       Description:    This routine reads the busy status of the   *
*                       Hitachi HD44780 LCD controller.             *
        RW_PIN = 1;                     // Set the control bits for read
        RS_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock in the command
        DelayFor18TCY();
        if(DATA_PORT&0x80)                      // Read bit 7 (busy bit)
        {                               // If high
                E_PIN = 0;              // Reset clock line
                RW_PIN = 0;             // Reset control line
                return 1;               // Return TRUE
        else                            // Bit 7 low
                return 0;               // Return FALSE
        if(DATA_PORT&0x80)
        if(DATA_PORT&0x08)
#endif
                DelayFor18TCY();
                E_PIN = 1;              // Clock out other nibble
                DelayFor18TCY();
                E_PIN = 0;
        else                            // Busy bit is low
                DelayFor18TCY();
                DelayFor18TCY();
                E_PIN = 0;
#endif
*       Function Name:  WriteCmdXLCD                                *
*       Parameters:     cmd: command to send to LCD                 *
*       Description:    This routine writes a command to the Hitachi*
*                       HD44780 LCD controller. The user must check *
*                       to see if the LCD controller is busy before *
*                       calling this routine.                       *
void WriteCmdXLCD(unsigned char cmd)
        DATA_PORT = cmd;                // Write command to data port
        RW_PIN = 0;                     // Set the control signals
        RS_PIN = 0;                     // for sending a command
        DelayFor18TCY();
        E_PIN = 1;                      // Clock the command in
        DelayFor18TCY();
        E_PIN = 0;
        DelayFor18TCY();
        TRIS_DATA_PORT = 0xff;          // Data port input
        DATA_PORT &= 0x0f;
        DATA_PORT |= cmd&0xf0;
        DATA_PORT &= 0xf0;
        DATA_PORT |= (cmd>>4)&0x0f;
#endif
        RW_PIN = 0;                     // Set control signals for command
        RS_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock command in
        DelayFor18TCY();
        E_PIN = 0;
        DATA_PORT &= 0x0f;
        DATA_PORT |= (cmd<<4)&0xf0;
        DATA_PORT &= 0xf0;
        DATA_PORT |= cmd&0x0f;
#endif
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
#ifdef UPPER                            // Make data nibble input
#else
#endif
#endif
        return;
*       Function Name:  WriteDataXLCD                               *
*       Parameters:     data: data byte to be written to LCD        *
*       Description:    This routine writes a data byte to the      *
*                       is written to the character generator RAM or*
void WriteDataXLCD(char data)
        DATA_PORT = data;               // Write data to port
        RS_PIN = 1;                     // Set control bits
        RW_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock data into LCD
        DelayFor18TCY();
        E_PIN = 0;
        RS_PIN = 0;                     // Reset control bits
        DATA_PORT &= 0x0f;
        DATA_PORT |= data&0xf0;
        DATA_PORT &= 0xf0;
        DATA_PORT |= ((data>>4)&0x0f);
#endif
        RW_PIN = 0;
        DelayFor18TCY();
        E_PIN = 1;                      // Clock nibble into LCD
        DelayFor18TCY();
        E_PIN = 0;
        DATA_PORT &= 0x0f;
        DATA_PORT |= ((data<<4)&0xf0);
        DATA_PORT &= 0xf0;
        DATA_PORT |= (data&0x0f);
#endif
        DelayFor18TCY();
        DelayFor18TCY();
        E_PIN = 0;
#endif
#endif
        return;
