////                            usb_cdc.h                            ////
//// Library for adding a virtual COM port on your PC over USB using ////
//// the standard Communication Device Class (CDC) specification.    ////
//// Including this file in your code will add all USB code,         ////
//// interrupts, descriptors and handlers required.  No other        ////
//// modifications need to be made.                                  ////
//// This library creates a virtual RS232 link between the PC and    ////
//// the PIC, therefore the library provided will be familiar to     ////
//// anyone with standard UART stream I/O:                           ////
//// usb_cdc_kbhit() - Returns TRUE if there is one or more          ////
////      character received and waiting in the receive buffer.      ////
//// usb_cdc_getc() - Gets a character from the receive buffer.  If  ////
////      there is no data in the receive buffer it will wait until  ////
////      there is data in the receive buffer.  If you do not want   ////
////      to wait in an infinit loop, use usb_cdc_kbhit() first to   ////
////      check if there is data before calling usb_cdc_getc().      ////
//// usb_cdc_putc(char c) - Puts a character into the transmit       ////
////      buffer.  If the transmit buffer is full it will wait until ////
////      the transmit buffer is not full before putting the char    ////
////      into the transmit buffer.  The transmit buffer is read by  ////
////      the PC very quickly, and therefore the buffer should only  ////
////      be full for a few milli-seconds.  If you are concerned     ////
////      and don't want to be stuck in a long or infinite loop,     ////
////      use usb_cdc_putready() to see if there is space in the     ////
////      transmit buffer before putting data into the transmit      ////
////      buffer.                                                    ////
//// usb_cdc_puts(*ptr) - Sends the null terminated string to the    ////
////     the transmit buffer.  Unlike usb_cdc_putc() or              ////
////     usb_cdc_putc_fast(), this routine will fit the string in    ////
////     one packet (whereas the other functions will flush the      ////
////     buffer as soon as the endpoint is free).                    ////
////     Returns TRUE if the packet was sent, FALSE if the buffer    ////
////     was still in use.                                           ////
////     Will stop copying characters from ptr to the endpoint       ////
////     buffer once it is full (but it will still return TRUE).     ////
//// usb_cdc_putready() - Returns TRUE if there is room left in the  ////
////      transmit buffer for another character.                     ////
//// usb_cdc_connected() - Returns TRUE if we received a             ////
////      Set_Line_Coding.  On most serial terminal programs (such   ////
////      as Hyperterminal), they will send a Set_Line_Coding        ////
////      message when the program starts and it opens the virtual   ////
////      COM port.  This is a simple way to determine if the PC     ////
////      is ready to display data on a serial terminal program,     ////
////      but is not garaunteed to work all the time or on other     ////
////      terminal programs.                                         ////
//// usb_cdc_putc_fast(char c) - Similar to usb_cdc_putc(), except   ////
////      if the transmit buffer is full it will skip the char.      ////
//// usb_cdc_line_coding - A structure used for Set_Line_Coding and  ////
////       Get_Line_Coding.  Most of the time you can ignore this.   ////
//// usb_cdc_break - If the PC has sent a break command, this will   ////
////       hold the break time (in milli-seconds).  If the PC sends  ////
////       a value of 0xFFFF the device is supposed to hold the      ////
////       break until it sends a value of 0                         ////
//// usb_cdc_carrier - Where Set_Control_Line_State value is stored. ////
////       Of most relevance is the field dte_present, which is the  ////
////       DTR setting.                                              ////
//// The following functions are also provided, and are ports of the ////
//// I/O functions in input.c.  See input.c and the CCS manual for   ////
//// documentation:                                                  ////
////   get_float_usb() - Read a float number from the user           ////
////   get_long_usb() - Read a long number from the user             ////
////   get_int_usb() - Read an integer number from the user          ////
////   get_string_usb(char *s, int max) - Read a string from the user. ////
////   gethex_usb() - Read a byte, in HEX, from the user             ////
////   gethex1_usb() - Read a HEX character                          ////
//// This driver will load all the rest of the USB code, and a set   ////
//// of descriptors that will properly describe a CDC device for a   ////
//// virtual COM port (usb_desc_cdc.h)                               ////
//// An .INF file is provided (cdc_NTXP.inf) that will load the      ////
//// standard CDC drivers for a virtual COM port in Windows          ////
//// NT/2000/XP and above.                                           ////
//// VERSION HISTORY                                                 ////
//// Jan 28, 2010:                                                   ////
////  Added usb_cdc_puts(str), which will fit the entire str into    ////
////     one packet.                                                 ////
//// Jan 25, 2010:                                                   ////
////  Ignore incoming 0 length packets.                              ////
//// June 9th, 2009:                                                 ////
////  Some problems with Vista and fast hubs/hosts fixed on PIC18.   ////
//// April 7th, 2009:                                                ////
////   Vista 'code 10' issues resolved.                              ////
//// March 5th, 2009:                                                ////
////   Cleanup for Wizard.                                           ////
////   PIC24 Initial release.                                        ////
//// Nov 26th, 2007:                                                 ////
////              usb_cdc_put_buffer_free() should be more stable.   ////
////              Fixed a hang-up that would happen if you sent      ////
////                 exactly 64 bytes.                               ////
//// Nov 6th, 2007:                                                  ////
////              Compatabible with latest pic18_usb.h, which        ////
////                 reduces RAM footprint of USB driver.            ////
////              This driver now fits on 18F4450/2450 PICs.         ////
//// October 27th, 2005: Changed the way incoming packets are        ////
////               handled in that CDC driver will not flush         ////
////               endpoint until user has handled all data.  This   ////
////               will prevent overflows as the USB will NAK        ////
////               incoming packets until it is ready to receive     ////
////               more.                                             ////
////            When using 18F4550 family, the RX buffer is          ////
////               mapped directly to the endpoint buffer - this     ////
////               saves a chunk of RAM.                             ////
////            When using the 18F4550 family, you can increase      ////
////               the TX and RX size over 64 bytes.                 ////
////            No longer send 0len packets in the TBE interrupt.    ////
////            Hopefully fixed bugs that caused random crashes      ////
////               if you tried sending more than 64 bytes.          ////
//// July 6th, 2005: Global interrupts disabled when writing to TX   ////
////                   buffer.                                       ////
//// July 1st, 2005: Initial Release.                                ////
////        (C) Copyright 1996,2005 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
   usb_cdc_putc() will not work correctly if interrupts are disabled, this
   also means it will not work if you call usb_cdc_putc() from inside another
   interrupt.
   Workaround is to call  _usb_cdc_putc_fast_noflush() instead.  This routine
   will erase last character if you put too many characters into the endpoint
   buffer.  Since this routine doesn't flush the endpoint buffer, you will
   also have to add this code in your main loop to check if buffer needs
   to be transmitted:
      if (usb_cdc_put_buffer_nextin && usb_cdc_put_buffer_free()) 
         usb_cdc_flush_out_buffer();
#warning usb_cdc_putc() needs to be improved to work if ISR is disabled (or if called inside an ISR).  See above comments for workaround
//api for the user:
#define usb_cdc_kbhit() (usb_cdc_get_buffer_status.got)
#define usb_cdc_putready() (usb_cdc_put_buffer_nextin<sizeof(usb_cdc_put_buffer))
#define usb_cdc_connected() (usb_cdc_got_set_line_coding)
void usb_cdc_putc_fast(char c);
char usb_cdc_getc(void);
void usb_cdc_putc(char c);
void usb_cdc_get_discard(void);
//input.c ported to use CDC:
float get_float_usb();
signed long get_long_usb();
signed int get_int_usb();
void get_string_usb(char* s, unsigned int max);
BYTE gethex_usb();
BYTE gethex1_usb();
//functions automatically called by USB handler code
void usb_isr_tkn_cdc(void);
void usb_cdc_init(void);
void usb_isr_tok_out_cdc_control_dne(void);
void usb_isr_tok_in_cdc_data_dne(void);
void usb_isr_tok_out_cdc_data_dne(void);
void usb_cdc_flush_out_buffer(void);
// Include the CCS USB Libraries.  See the comments at the top of these
// files for more information
#ifndef __USB_PIC_PERIF__
#define __USB_PIC_PERIF__   1
#endif
#if __USB_PIC_PERIF__
   #if defined(__PCH__)
    #include <pic18_usb.h>   //Microchip 18Fxx5x hardware layer for usb.c
   #else
    #include <pic24_usb.h>   //Microchip 18Fxx5x hardware layer for usb.c
   #endif
#else
   #include <usbn960x.h>
#endif
#include "./include/usb_desc_cdc.h"   //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
struct {
        unsigned int32   dwDTERrate;   //data terminal rate, in bits per second
        unsigned int8    bCharFormat;  //num of stop bits (0=1, 1=1.5, 2=2)
        unsigned int8    bParityType;  //parity (0=none, 1=odd, 2=even, 3=mark, 4=space)
        unsigned int8    bDataBits;    //data bits (5,6,7,8 or 16)
} __attribute__((__packed__)) usb_cdc_line_coding;
//length of time, in ms, of break signal as we received in a SendBreak message.
//if ==0xFFFF, send break signal until we receive a 0x0000.
unsigned int16 usb_cdc_break;
unsigned int8 usb_cdc_encapsulated_cmd[8];
unsigned int8 usb_cdc_put_buffer[USB_CDC_DATA_IN_SIZE-1];
#define usb_cdc_put_buffer_free()  usb_tbe(USB_CDC_DATA_IN_ENDPOINT)
#if sizeof(usb_cdc_put_buffer)>=0x100
 unsigned int16 usb_cdc_put_buffer_nextin=0;
// int16 usb_cdc_last_data_packet_size;
#else
 unsigned int8 usb_cdc_put_buffer_nextin=0;
// int8 usb_cdc_last_data_packet_size;
#endif
struct {
   int1 got;
  #if USB_CDC_DATA_OUT_SIZE>=0x100
   unsigned int16 len;
   unsigned int16 index;
  #else
   unsigned int8 len;
   unsigned int8 index;
  #endif
} usb_cdc_get_buffer_status;
#if defined(__PIC__)
 #define usb_cdc_get_buffer_status_buffer usb_ep2_rx_buffer
#else
 unsigned int8 usb_cdc_get_buffer_status_buffer[USB_CDC_DATA_OUT_SIZE];
#endif
int1 usb_cdc_got_set_line_coding;
struct  {
   int1 dte_present; //1=DTE present, 0=DTE not present
   int1 active;      //1=activate carrier, 0=deactivate carrier
   unsigned int reserved:6;
} usb_cdc_carrier;
unsigned int8 g_LastCDCDataPacketSize;
enum {USB_CDC_OUT_NOTHING=0, USB_CDC_OUT_COMMAND=1, USB_CDC_OUT_LINECODING=2, USB_CDC_WAIT_0LEN=3} __usb_cdc_state=0;
 #byte INTCON=0xFF2
 #bit INT_GIE=INTCON.7
#else
 #word SR=0x42
#endif
//handle OUT token done interrupt on endpoint 0 [read encapsulated cmd and line coding data]
void usb_isr_tok_out_cdc_control_dne(void) {
   debug_usb(debug_putc,"CDC %X ",__usb_cdc_state);
   switch (__usb_cdc_state) {
      //printf(putc_tbe,"@%X@\r\n", __usb_cdc_state);
      case USB_CDC_OUT_COMMAND:
         //usb_get_packet(0, usb_cdc_encapsulated_cmd, 8);
         memcpy(usb_cdc_encapsulated_cmd, usb_ep0_rx_buffer,8);
        #if USB_MAX_EP0_PACKET_LENGTH==8
         __usb_cdc_state=USB_CDC_WAIT_0LEN;
         usb_request_get_data();
        #else
         usb_put_0len_0();
         __usb_cdc_state=0;
        #endif
         break;
      case USB_CDC_WAIT_0LEN:
         usb_put_0len_0();
         __usb_cdc_state=0;
         break;
    #endif
      case USB_CDC_OUT_LINECODING:
         //usb_get_packet(0, &usb_cdc_line_coding, 7);
         //printf(putc_tbe,"\r\n!GSLC FIN!\r\n");
         memcpy(&usb_cdc_line_coding, usb_ep0_rx_buffer,7);
         __usb_cdc_state=0;
         usb_put_0len_0();
         break;
      default:
         __usb_cdc_state=0;
         //usb_init_ep0_setup(); //REMOVED JUN/9/2009
         break;
//handle IN token on 0 (setup packet)
void usb_isr_tkn_cdc(void) {
   //make sure the request goes to a CDC interface
   if ((usb_ep0_rx_buffer[4] == 1) || (usb_ep0_rx_buffer[4] == 0)) {
      //printf(putc_tbe,"!%X!\r\n", usb_ep0_rx_buffer[1]);
      switch(usb_ep0_rx_buffer[1]) {
         case 0x00:  //send_encapsulated_command
            __usb_cdc_state=USB_CDC_OUT_COMMAND;
            break;
         case 0x01:  //get_encapsulated_command
            memcpy(usb_ep0_tx_buffer, usb_cdc_encapsulated_cmd, 8);
            usb_request_send_response(usb_ep0_rx_buffer[6]);  //send wLength bytes
            break;
         case 0x20:  //set_line_coding
            debug_usb(debug_putc,"!GSLC!");
            __usb_cdc_state=USB_CDC_OUT_LINECODING;
            usb_cdc_got_set_line_coding=TRUE;
            break;
         case 0x21:  //get_line_coding
            memcpy(usb_ep0_tx_buffer, &usb_cdc_line_coding, sizeof(usb_cdc_line_coding));
            usb_request_send_response(sizeof(usb_cdc_line_coding)); //send wLength bytes
            break;
         case 0x22:  //set_control_line_state
            usb_cdc_carrier=usb_ep0_rx_buffer[2];
            usb_put_0len_0();
            break;
         case 0x23:  //send_break
            usb_cdc_break=make16(usb_ep0_rx_buffer[2],usb_ep0_rx_buffer[3]);
            usb_put_0len_0();
            break;
         default:
            usb_request_stall();
            break;
//handle OUT token done interrupt on endpoint 3 [buffer incoming received chars]
void usb_isr_tok_out_cdc_data_dne(void) {
   usb_cdc_get_buffer_status.got=TRUE;
   usb_cdc_get_buffer_status.index=0;
#if (defined(__PIC__) && __PIC__)
    usb_cdc_get_buffer_status.len=usb_rx_packet_size(USB_CDC_DATA_OUT_ENDPOINT);
#else
   usb_cdc_get_buffer_status.len=usb_get_packet_buffer(
      USB_CDC_DATA_OUT_ENDPOINT,&usb_cdc_get_buffer_status_buffer[0],USB_CDC_DATA_OUT_SIZE);
#endif
   if (!usb_cdc_get_buffer_status.len)
      usb_cdc_get_discard();
//handle IN token done interrupt on endpoint 2 [transmit buffered characters]
   //putc('!');
   if (usb_cdc_put_buffer_nextin /* || (g_LastCDCDataPacketSize == USB_CDC_DATA_IN_SIZE)*/ ) 
      //printf("FL3 %LU\r\n", (int16)usb_cdc_put_buffer_nextin);
   //printf(putc_tbe, "FL %U\r\n", usb_cdc_put_buffer_nextin);
   usb_put_packet(USB_CDC_DATA_IN_ENDPOINT,usb_cdc_put_buffer,usb_cdc_put_buffer_nextin,USB_DTS_TOGGLE);
   g_LastCDCDataPacketSize = usb_cdc_put_buffer_nextin;
   usb_cdc_line_coding.dwDTERrate = 9600;
   usb_cdc_line_coding.bCharFormat = 0;
   usb_cdc_line_coding.bParityType = 0;
   usb_cdc_line_coding.bDataBits = 8;
   (int8)usb_cdc_carrier = 0;
   usb_cdc_got_set_line_coding = FALSE;
   usb_cdc_break = 0;
   usb_cdc_put_buffer_nextin = 0;
   usb_cdc_get_buffer_status.got = 0;
////////////////// END USB CONTROL HANDLING //////////////////////////////////
////////////////// BEGIN USB<->RS232 CDC LIBRARY /////////////////////////////
   usb_cdc_get_buffer_status.got = FALSE;
   usb_flush_out(USB_CDC_DATA_OUT_ENDPOINT, USB_DTS_TOGGLE);
   char c;
   while (!usb_cdc_kbhit()) {}
   c=usb_cdc_get_buffer_status_buffer[usb_cdc_get_buffer_status.index++];
   if (usb_cdc_get_buffer_status.index >= usb_cdc_get_buffer_status.len) 
   return(c);
static void _usb_cdc_putc_fast_noflush(char c)
   int1 old_gie;
   //disable global interrupts
   old_gie = INT_GIE;
   INT_GIE = 0;
 #else
   unsigned int16 oldSR;
   oldSR = SR;
   SR |= 0xE0;
 #endif
   if (usb_cdc_put_buffer_nextin >= sizeof(usb_cdc_put_buffer)) {
      usb_cdc_put_buffer_nextin = sizeof(usb_cdc_put_buffer)-1;  //we just overflowed the buffer!
   usb_cdc_put_buffer[usb_cdc_put_buffer_nextin++] = c;
   //renable global interrupts
   INT_GIE = old_gie;
  #else
   SR = oldSR;
  #endif
   _usb_cdc_putc_fast_noflush(c);
   if (usb_cdc_put_buffer_free()) 
      //printf("FL2 %LU\r\n", (int16)usb_cdc_put_buffer_nextin);
   //putc('*');
   while (!usb_cdc_putready()) 
         //printf("FL1 %LU\r\n", (int16)usb_cdc_put_buffer_nextin);
      //delay_ms(500);
      //printf(putc_tbe,"TBE=%U CNT=%U LST=%U\r\n",usb_tbe(USB_CDC_DATA_IN_ENDPOINT), usb_cdc_put_buffer_nextin, usb_cdc_last_data_packet_size);
   //putc('.');
   //putc(c);
   usb_cdc_putc_fast(c);
int1 usb_cdc_puts(char *ptr)
 #if USB_EP2_TX_SIZE>=0x100
   unsigned int16 i;
 #else
   unsigned int8 i;
 #endif
   char c;
   i = 0;
   if (!usb_cdc_put_buffer_free())
      return(FALSE);
   for (;;)
      c = *ptr++;
      if (!c)
         break;
      if (++i >= USB_EP2_TX_SIZE)
         break;
   return(TRUE);
#include <ctype.h>
BYTE gethex1_usb() 
   char digit;
   digit = usb_cdc_getc();
   usb_cdc_putc(digit);
   if(digit<='9')
     return(digit-'0');
   else
     return((toupper(digit)-'A')+10);
BYTE gethex_usb() {
   unsigned int8 lo,hi;
   hi = gethex1_usb();
   lo = gethex1_usb();
   if(lo==0xdd)
     return(hi);
   else
     return( hi*16+lo );
void get_string_usb(char* s, unsigned int max) {
   unsigned int len;
   char c;
   --max;
   len=0;
   do {
     c=usb_cdc_getc();
     if(c==8) {  // Backspace
        if(len>0) {
          len--;
          usb_cdc_putc(c);
          usb_cdc_putc(' ');
          usb_cdc_putc(c);
     } else if ((c>=' ')&&(c<='~'))
       if(len<max) {
         s[len++]=c;
         usb_cdc_putc(c);
   } while(c!=13);
   s[len]=0;
// stdlib.h is required for the ato_ conversions
// in the following functions
#ifdef _STDLIB
signed int get_int_usb() {
  char s[7];
  signed int i;
  get_string_usb(s, 7);
  i=atoi(s);
  return(i);
signed long get_long_usb() {
  char s[13];
  signed long l;
  get_string_usb(s, 13);
  l=atol(s);
  return(l);
float get_float_usb() {
  char s[20];
  float f;
  get_string_usb(s, 20);
  f = atof(s);
  return(f);
#endif
