* Define TFT panel here
#define TY430TFT480272 	0
#define TY500TFT800480 	1
#define TY700TFT800480 	2
#define YOUR_PANEL		4
//#define DISPLAY_PANEL TY430TFT480272
#define DISPLAY_PANEL TY500TFT800480
//#define DISPLAY_PANEL TY700TFT800480
//#define DISPLAY_PANEL YOUR_PANEL
 comment or uncomment #define TY700TFT_USE_QA_PATTERN to show/not show
 a built-in QA pattern for TY700TFT800480. Project rebuild req.
 only valid for #define DISPLAY_PANEL TY700TFT800480
//#define TY700TFT_USE_QA_PATTERN	
/********************** INDIVIDUAL PANEL DEFS **************************/
	#if (DISPLAY_PANEL == TY430TFT480272)
	* TIMING PARAMETERS FOR 4.3" TFT PANEL (480x272):
	* PART# TY430TFT480272
	* Overview: Horizontal and vertical display resolution
	*                  (from the glass datasheet).
	#define DISP_HOR_RESOLUTION				480
	#define DISP_VER_RESOLUTION				272
	* Overview: Image orientation (can be 0, 90, 180, 270 degrees).
	#define DISP_ORIENTATION				180
	* Overview: Panel Data Width
	#define DISP_DATA_WIDTH                 24
	* Overview: LSHIFT Polarity Swap
	* If defined LSHIFT is a falling trigger
	//#define DISP_INV_LSHIFT
	* Overview: Horizontal synchronization timing in pixels
	#define DISP_HOR_PULSE_WIDTH		41  
	#define DISP_HOR_BACK_PORCH			2
	#define DISP_HOR_FRONT_PORCH		2	
	* Overview: Vertical synchronization timing in lines
	#define DISP_VER_PULSE_WIDTH		10
	#define DISP_VER_BACK_PORCH			2	
	#define DISP_VER_FRONT_PORCH		2
	* Definition for SPI interface for SSD1963 
	* Hardware dependent!
	#define GPIO3 3
	#define GPIO2 2
	#define GPIO1 1
	#define GPIO0 0
	#define LCD_RESET (1<<GPIO0)		//LCD Reset signal (Reset for display panel, NOT ssd1963)
	#define LCD_SPENA	0
	#define LCD_SPCLK	0
	#define LCD_SPDAT	0
	/* End of definition for TY430TFT480272 */
#elif (DISPLAY_PANEL == TY500TFT800480)
	* TIMING PARAMETERS FOR 5" TFT PANEL (800x480):
	* PART# TY500TFT800480
	#define DISP_HOR_RESOLUTION				800
	#define DISP_VER_RESOLUTION				480
	#define DISP_ORIENTATION				90
	#define DISP_HOR_PULSE_WIDTH		128  
	#define DISP_HOR_BACK_PORCH			88
	#define DISP_HOR_FRONT_PORCH		40	
	#define DISP_VER_PULSE_WIDTH		2
	#define DISP_VER_BACK_PORCH			25	
	#define DISP_VER_FRONT_PORCH		18
	#define GPIO3 3
	#define GPIO2 2
	#define GPIO1 1
	#define GPIO0 0
	#define LCD_SPENA	0
	#define LCD_SPCLK	0
	#define LCD_SPDAT	0
	/* End of definition for DISPLAY_PANEL == TY500TFT800480 */
#elif (DISPLAY_PANEL == TY700TFT800480)
	* TIMING PARAMETERS FOR 7" TFT PANEL (800x480):
	* PART# TY700TFT800480
	* Reamrks: 	By accident, a QA procedure for TY700TFT800480 discovered!
	*			Set all parameters as follows for a built-in display 
	*			R,G,B, and B&W spare pattern
	*		#define DISP_VER_PULSE_WIDTH		0
	*		#define DISP_VER_BACK_PORCH			0	
	*		#define DISP_VER_FRONT_PORCH		0
	*		Normal operating values 
	*		#define DISP_VER_PULSE_WIDTH		1
	*		#define DISP_VER_BACK_PORCH			34	
	*		#define DISP_VER_FRONT_PORCH		10
  	#define DISP_ORIENTATION    0
	* Overview: Panel Data Width (R,G,B) in (6,6,6)
	#define DISP_DATA_WIDTH                 18
	#define DISP_HOR_BACK_PORCH			210
	#define DISP_HOR_FRONT_PORCH		45	
	#if defined (TY700TFT_USE_QA_PATTERN)
	#else
	#endif
	#define GPIO3 3
	#define GPIO2 2
	#define GPIO1 1
	#define GPIO0 0
	#define LCD_RESET 	0
	#define LCD_SPENA	0
	#define LCD_SPCLK	0
	#define LCD_SPDAT	0
	/* End of definition for TY700TFT800480 */
#elif (DISPLAY_PANEL == YOUR_PANEL)
	//...your TFT parameters to be defined here
#endif
