| 66 |
PLIB_USART_HandshakeModeSelect(USART_ID_2, USART_HANDSHAKE_MODE_FLOW_CONTROL); |
66 |
| 67 |
PLIB_USART_OperationModeSelect(USART_ID_2, USART_ENABLE_TX_RX_USED); |
67 |
| 68 |
PLIB_USART_LineControlModeSelect(USART_ID_2, USART_8N1); |
68 |
| 69 |
PLIB_USART_TransmitterEnable(USART_ID_2); |
69 |
| 70 |
PLIB_USART_TransmitterInterruptModeSelect(USART_ID_2, USART_TRANSMIT_FIFO_NOT_FULL); |
70 |
| 71 |
71 |
72 |
/* Initialize TX interrupt */ |
73 |
PLIB_INT_SourceEnable(INT_ID_0, INT_SOURCE_USART_2_TRANSMIT); |
74 |
PLIB_INT_VectorPrioritySet(INT_ID_0, INT_VECTOR_UART2_TX, INT_PRIORITY_LEVEL1); |
75 |
PLIB_INT_VectorSubPrioritySet(INT_ID_0, INT_VECTOR_UART2_TX, INT_SUBPRIORITY_LEVEL0); |
76 |
77 |
78 |
/* Initialize Fault interrupt */ |
79 |
PLIB_INT_SourceEnable(INT_ID_0, INT_SOURCE_USART_2_ERROR); |
80 |
PLIB_INT_VectorPrioritySet(INT_ID_0, INT_VECTOR_UART2_FAULT, INT_PRIORITY_LEVEL1); |
81 |
PLIB_INT_VectorSubPrioritySet(INT_ID_0, INT_VECTOR_UART2_FAULT, INT_SUBPRIORITY_LEVEL0); |
82 |
| 72 |
PLIB_USART_Enable(USART_ID_2); |
83 |
| 73 |
84 |
| 74 |
85 |
| 75 |
86 |
| 76 |
87 |
| 77 |
88 |
| 96 |
107 |
| 97 |
108 |
| 98 |
109 |
| 99 |
PLIB_USART_TransmitterByteSend(USART_ID_2, byte); |
110 |
| 100 |
111 |
| 101 |
112 |
113 |
114 |
115 |
// Section: Instance 1 static driver functions |
116 |
117 |
| 102 |
118 |
119 |
void DRV_USART1_Initialize(void) |
120 |
121 |
/* Initialize USART */ |
122 |
PLIB_USART_BaudRateSet(USART_ID_3, SYS_CLK_PeripheralFrequencyGet(CLK_BUS_PERIPHERAL_2), 38400); |
123 |
PLIB_USART_HandshakeModeSelect(USART_ID_3, USART_HANDSHAKE_MODE_FLOW_CONTROL); |
124 |
PLIB_USART_OperationModeSelect(USART_ID_3, USART_ENABLE_TX_RX_USED); |
125 |
PLIB_USART_LineControlModeSelect(USART_ID_3, USART_8N1); |
126 |
PLIB_USART_ReceiverEnable(USART_ID_3); |
127 |
PLIB_USART_ReceiverInterruptModeSelect(USART_ID_3, USART_RECEIVE_FIFO_ONE_CHAR); |
128 |
129 |
/* Initialize RX interrupt */ |
130 |
PLIB_INT_SourceEnable(INT_ID_0, INT_SOURCE_USART_3_RECEIVE); |
131 |
PLIB_INT_VectorPrioritySet(INT_ID_0, INT_VECTOR_UART3_RX, INT_PRIORITY_LEVEL1); |
132 |
PLIB_INT_VectorSubPrioritySet(INT_ID_0, INT_VECTOR_UART3_RX, INT_SUBPRIORITY_LEVEL1); |
133 |
134 |
135 |
PLIB_INT_SourceEnable(INT_ID_0, INT_SOURCE_USART_3_ERROR); |
136 |
PLIB_INT_VectorPrioritySet(INT_ID_0, INT_VECTOR_UART3_FAULT, INT_PRIORITY_LEVEL1); |
137 |
PLIB_INT_VectorSubPrioritySet(INT_ID_0, INT_VECTOR_UART3_FAULT, INT_SUBPRIORITY_LEVEL1); |
138 |
139 |
PLIB_USART_Enable(USART_ID_3); |
140 |
141 |
142 |
143 |
144 |
145 |
bool DRV_USART1_ReceiverBufferIsEmpty(void) |
146 |
147 |
return (!PLIB_USART_ReceiverDataIsAvailable(USART_ID_3)); |
148 |
149 |
150 |
uint8_t DRV_USART1_ReadByte(void) |
151 |
152 |
if(PLIB_USART_ReceiverOverrunHasOccurred(USART_ID_3)) |
153 |
154 |
PLIB_USART_ReceiverOverrunErrorClear(USART_ID_3); |
155 |
156 |
157 |
return (PLIB_USART_ReceiverByteReceive(USART_ID_3)); |
158 |
159 |
160 |
void DRV_USART1_WriteByte(const uint8_t byte) |
161 |
162 |
while(PLIB_USART_TransmitterBufferIsFull(USART_ID_3)) |
163 |
164 |
165 |
166 |
PLIB_USART_TransmitterByteSend(USART_ID_3, byte); |
167 |
168 |
169 |
| 103 |
170 |
| 104 |
171 |
| 105 |
172 |
| 58 |
58 |
| 59 |
void DRV_USART0_Initialize(void); |
59 |
| 60 |
uint8_t DRV_USART0_ReadByte(void); |
60 |
| 61 |
void DRV_USART0_WriteByte(const uint8_t byte); |
61 |
| 62 |
bool DRV_USART0_ReceiverBufferIsEmpty(void); |
62 |
| 63 |
63 |
64 |
65 |
66 |
// Section: Interface Headers for Instance 1 for the static driver |
67 |
68 |
69 |
70 |
void DRV_USART1_Initialize(void); |
71 |
uint8_t DRV_USART1_ReadByte(void); |
72 |
void DRV_USART1_WriteByte(const uint8_t byte); |
73 |
bool DRV_USART1_ReceiverBufferIsEmpty(void); |
74 |
| 64 |
#endif |
75 |
#endif |
| 65 |
76 |
| 66 |
77 |
| 67 |
78 |
| 68 |
79 |
| 108 |
PLIB_PORTS_ChannelChangeNoticeEnable(PORTS_ID_0, PORT_CHANNEL_G, SYS_PORT_G_CNEN); |
108 |
| 109 |
PLIB_PORTS_ChannelChangeNoticePullUpEnable(PORTS_ID_0, PORT_CHANNEL_G, SYS_PORT_G_CNPU); |
109 |
| 110 |
PLIB_PORTS_ChannelChangeNoticePullDownEnable(PORTS_ID_0, PORT_CHANNEL_G, SYS_PORT_G_CNPD); |
110 |
| 111 |
111 |
| 112 |
112 |
| 113 |
PLIB_PORTS_RemapInput(PORTS_ID_0, INPUT_FUNC_SDI4, INPUT_PIN_RPD3 ); |
113 |
114 |
PLIB_PORTS_RemapInput(PORTS_ID_0, INPUT_FUNC_U3RX, INPUT_PIN_RPB3 ); |
| 114 |
115 |
| 115 |
116 |
| 116 |
PLIB_PORTS_RemapOutput(PORTS_ID_0, OUTPUT_FUNC_U2TX, OUTPUT_PIN_RPB2 ); |
117 |
| 117 |
PLIB_PORTS_RemapOutput(PORTS_ID_0, OUTPUT_FUNC_SDO6, OUTPUT_PIN_RPC3 ); |
118 |
| 118 |
PLIB_PORTS_RemapOutput(PORTS_ID_0, OUTPUT_FUNC_SDO2, OUTPUT_PIN_RPE5 ); |
119 |
| 119 |
PLIB_PORTS_RemapOutput(PORTS_ID_0, OUTPUT_FUNC_SDO4, OUTPUT_PIN_RPD11 ); |
120 |
| 55 |
#include "system/devcon/sys_devcon.h" |
55 |
| 56 |
#include "system/int/sys_int.h" |
56 |
| 57 |
#include "framework/driver/tmr/drv_tmr_static.h" |
57 |
| 58 |
#include "peripheral/int/plib_int.h" |
58 |
| 59 |
#include "framework/driver/usart/drv_usart_static.h" |
59 |
| 60 |
#include "peripheral/usart/plib_usart.h" |
60 |
61 |
| 61 |
#include "system/ports/sys_ports.h" |
62 |
| 62 |
#include "framework/driver/spi/drv_spi_static.h" |
63 |
| 63 |
64 |
| 64 |
65 |
| 65 |
66 |
| 66 |
67 |
| 73 |
void __ISR(_TIMER_1_VECTOR, ipl1) _IntHandlerDrvTmrInstance0(void) |
73 |
| 74 |
74 |
| 75 |
++PORTDbits.RD1; |
75 |
++PORTDbits.RD1; |
| 76 |
PLIB_INT_SourceFlagClear(INT_ID_0,INT_SOURCE_TIMER_1); |
76 |
| 77 |
77 |
| 78 |
78 |
79 |
void __ISR(_UART2_TX_VECTOR, ipl1) _IntHandlerDrvUsartTransmitInstance0(void) |
80 |
81 |
82 |
/* TODO: Add code to process interrupt here */ |
83 |
84 |
/* Clear pending interrupt */ |
85 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_2_TRANSMIT); |
86 |
87 |
void __ISR(_UART2_RX_VECTOR, ipl1) _IntHandlerDrvUsartReceiveInstance0(void) |
88 |
89 |
90 |
91 |
92 |
93 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_2_RECEIVE); |
94 |
95 |
void __ISR(_UART2_FAULT_VECTOR, ipl1) _IntHandlerDrvUsartErrorInstance0(void) |
96 |
97 |
98 |
99 |
100 |
101 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_2_ERROR); |
102 |
103 |
104 |
105 |
106 |
107 |
void __ISR(_UART3_TX_VECTOR, ipl1) _IntHandlerDrvUsartTransmitInstance1(void) |
108 |
109 |
110 |
111 |
112 |
113 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_3_TRANSMIT); |
114 |
115 |
void __ISR(_UART3_RX_VECTOR, ipl1) _IntHandlerDrvUsartReceiveInstance1(void) |
116 |
117 |
118 |
119 |
++PORTDbits.RD2; |
120 |
121 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_3_RECEIVE); |
122 |
123 |
void __ISR(_UART3_FAULT_VECTOR, ipl1) _IntHandlerDrvUsartErrorInstance1(void) |
124 |
125 |
126 |
127 |
128 |
129 |
PLIB_INT_SourceFlagClear(INT_ID_0, INT_SOURCE_USART_3_ERROR); |
130 |
131 |
132 |
133 |
134 |
135 |
136 |
137 |
138 |
139 |
| 79 |
140 |
| 80 |
141 |
| 81 |
142 |
| 82 |
143 |
