#include <18f4550.h>
//#fuses HS,MCLR,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOPBADEN,NOLVP,NOCPD,NODEBUG,NOWRT,NOVREGEN
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#define USE_INTERRUPTS 1
char dato;
// INTERRUPCION por RECEPCION SERIE -------------------------------------------
#int_rda
void serial_isr() {
     if(kbhit()){
     dato=getc();
     printf("Dato Recibido %S\r\n",dato);
void main() {
   disable_interrupts(global);
   disable_interrupts(int_timer1);
   disable_interrupts(int_rda);
   disable_interrupts(int_ext);
   disable_interrupts(int_ext1);
   disable_interrupts(int_ext2);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_psp(PSP_DISABLED);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_timer_0(RTCC_OFF);
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
   setup_timer_3(T3_DISABLED);
   setup_vref(FALSE);
   port_b_pullups(FALSE);
   set_tris_b(0b00000111);
   set_tris_e(0b00010000);
   output_e(0x00);
   set_tris_c(0b10000000);
  while (TRUE);
//lazo infinito
