///                               DS1307.C                                   /// 
///                     Driver for Real Time Clock                           /// 
/// ds1307_init() - Enable oscillator without clearing the seconds register -/// 
///                 used when PIC loses power and DS1307 run from 3V BAT     /// 
///               - Disable squarewave output                                /// 
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec)  Set the date/time   /// 
/// ds1307_get_date(day,mth,year,dow)               Get the date             /// 
/// ds1307_get_time(hr,min,sec)                     Get the time             /// 
BYTE bin2bcd(BYTE binary_value); 
BYTE bcd2bin(BYTE bcd_value); 
void ds1307_init(void) 
   BYTE seconds = 0; 
   i2c_start(RTC);
   i2c_write(RTC, 0xD0);      // WR to RTC 
   i2c_write(RTC, 0x00);      // REG 0 
   i2c_start(RTC);
   i2c_write(RTC, 0xD1);     // RD from RTC 
   seconds = bcd2bin(i2c_read(RTC, 0)); // Read current "seconds" in DS1307 
   i2c_stop(RTC);
   seconds &= 0x7F;
   delay_us(3); 
   i2c_start(RTC); 
   i2c_write(RTC, bin2bcd(seconds));     // Start oscillator with current "seconds value 
   i2c_start(RTC); 
   i2c_write(RTC, 0x07);      // Control Register 
   i2c_write(RTC, 0b0000000);     // Disable squarewave output pin a VSS.
   //i2c_write(RTC, 0b00010000);
   i2c_stop(RTC);
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec) 
   sec &= 0x7F; 
   hr &= 0x3F; 
   i2c_start(RTC); 
   i2c_write(RTC, 0xD0);            // I2C write address 
   i2c_write(RTC, 0x00);            // Start at REG 0 - Seconds 
   i2c_write(RTC, bin2bcd(sec));      // REG 0 
   i2c_write(RTC, bin2bcd(min));      // REG 1 
   i2c_write(RTC, bin2bcd(hr));      // REG 2 
   i2c_write(RTC, bin2bcd(dow));      // REG 3 
   i2c_write(RTC, bin2bcd(day));      // REG 4 
   i2c_write(RTC, bin2bcd(mth));      // REG 5 
   i2c_write(RTC, bin2bcd(year));      // REG 6 
   i2c_write(RTC, 0x80);            // REG 7 - Disable squarewave output pin 
   i2c_stop(RTC); 
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow) 
   i2c_start(RTC); 
   i2c_write(RTC, 0x03);            // Start at REG 3 - Day of week 
   i2c_start(RTC); 
   dow  = bcd2bin(i2c_read(RTC) & 0x7f);   // REG 3 
   day  = bcd2bin(i2c_read(RTC) & 0x3f);   // REG 4 
   mth  = bcd2bin(i2c_read(RTC) & 0x1f);   // REG 5 
   year = bcd2bin(i2c_read(RTC, 0));            // REG 6 
   i2c_stop(RTC); 
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec) 
   i2c_start(RTC); 
   i2c_start(RTC); 
   sec = bcd2bin(i2c_read(RTC) & 0x7f); 
   min = bcd2bin(i2c_read(RTC) & 0x7f); 
   hr  = bcd2bin(i2c_read(RTC, 0) & 0x3f); 
   i2c_stop(RTC); 
   BYTE temp; 
   BYTE retval; 
   temp = binary_value; 
   retval = 0; 
   while(TRUE) 
       // Get the tens digit by doing multiple subtraction 
      // of 10 from the binary value. 
      if(temp >= 10) 
         temp -= 10; 
         retval += 0x10; 
      else // Get the ones digit by adding the remainder. 
         retval += temp; 
         break; 
   return(retval); 
// Input range - 00 to 99. 
   BYTE temp; 
   temp = bcd_value; 
   // Shifting upper digit right by 1 is same as multiplying by 8. 
   temp >>= 1; 
   // Isolate the bits for the upper digit. 
   temp &= 0x78; 
   // Now return: (Tens * 8) + (Tens * 2) + Ones 
   return(temp + (temp >> 2) + (bcd_value & 0x0f)); 
