//bootloader code
// APPLICATION_ISR_VECTOR - Where the compiler is going to put the ISR
#define FIRMWARE_UPGRADE_VECTOR  0          // Bootloader at Start of memory
#define MAX_UPGRADE_AREA         (0x500)    // Space required by bootloader
#define MIN_FIRMWARE_UPGRADE_MEMORY_AREA   (0x20)   // Start of bootloder code
#define MAX_FIRMWARE_UPGRADE_MEMORY_AREA   (MAX_UPGRADE_AREA-1) // End of bootloder code
#define APPLICATION_RESET_VECTOR 0x500     // New RESET Vector
#define APPLICATION_ISR_VECTOR   0x508     // New Interrupt Vector
// Re-vectored RESET vector from 0x0000 to 0x0500
// Re-vectored Interrupt vector from 0x0008 to 0x0508
#build(reset=APPLICATION_RESET_VECTOR, interrupt=APPLICATION_ISR_VECTOR)
#define LOADER_END   MAX_UPGRADE_AREA -1
#define LOADER_ADDR  MIN_FIRMWARE_UPGRADE_MEMORY_AREA
#define BUFFER_LEN_LOD 64
int  buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON    0x11
#define XOFF   0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
void real_load_program (void)
   int1  do_ACKLOD, done=FALSE;
   int8  checksum, line_type;
   int16 l_addr,h_addr=0;
   int32 addr;
   #if getenv("FLASH_ERASE_SIZE")>2
      int32 next_addr;
   #endif
   int8  dataidx, i, count;
   int8  data[32];
   while (!done)  // Loop until the entire program is downloaded
      buffidx = 0;  // Read into the buffer until 0x0D ('\r') is received or the buffer is full
      do {
         buffer[buffidx] = getc();
      } while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
      putchar (XOFF);  // Suspend sender
      do_ACKLOD = TRUE;
      // Only process data blocks that start with ':'
      if (buffer[0] == ':') {
         count = atoi_b16 (&buffer[1]);  // Get the number of bytes from the buffer
         // Get the lower 16 bits of address
         l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
         line_type = atoi_b16 (&buffer[7]);
         addr = make32(h_addr,l_addr);
         #if defined(__PCM__)  // PIC16 uses word addresses
            addr /= 2;
         #endif
         // If the line type is 1, then data is done being sent
         if (line_type == 1) {
            done = TRUE;
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
         #elif defined(__PCH__)
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
         #endif
            checksum = 0;  // Sum the bytes to find the check sum value
            for (i=1; i<(buffidx-3); i+=2)
               checksum += atoi_b16 (&buffer[i]);
            checksum = 0xFF - checksum + 1;
            if (checksum != atoi_b16 (&buffer[buffidx-3]))
               do_ACKLOD = FALSE;
            else   {
               if (line_type == 0) {
                  // Loops through all of the data and stores it in data
                  // The last 2 bytes are the check sum, hence buffidx-3
                  for (i = 9,dataidx=0; i < buffidx-3; i += 2)
                     data[dataidx++]=atoi_b16(&buffer[i]);
                  #if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
                     #else
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
                     #endif
                           erase_program_eeprom(addr);
                     next_addr = addr + 1;
                  #endif
                  write_program_memory(addr, data, count);
               else if (line_type == 4)
                  h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
      if (do_ACKLOD)
         putchar (ACKLOD);
      putchar(XON);
   putchar (ACKLOD);
   putchar(XON);
   #ifndef _bootloader
   reset_cpu();
   #endif
unsigned int atoi_b16(char *s) {  // Convert two hex characters to a int8
   unsigned int result = 0;
   int i;
   for (i=0; i<2; i++,s++)  {
      if (*s >= 'A')
         result = 16*result + (*s) - 'A' + 10;
      else
         result = 16*result + (*s) - '0';
   return(result);
