Otros Microcontroladores / Dispositivos programables => Lógica Programable => Mensaje iniciado por: androx en 03 de Mayo de 2006, 07:05:46
Hola a todos!!!
Me gustaría saber cómo puedo hacer una división en VHDL.Espero me puedan ayudar
Muchas gracias :-/
He encontrado un algritmo para hacer una división,el problema es que no se muy bien como hacer el test bench.El código es este:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity divisor is
port (
GO: in STD_LOGIC;
IN_N: in STD_LOGIC_VECTOR (7 downto 0);
IN_D: in STD_LOGIC_VECTOR (7 downto 0);
EXT_CLK: in STD_LOGIC;
OUT_Q: out STD_LOGIC_VECTOR (7 downto 0);
OUT_R: out STD_LOGIC_VECTOR (7 downto 0));
end divisor;
architecture Behavioral of divisor is
signal X: STD_LOGIC_VECTOR(16 downto 0);
signal D: STD_LOGIC_VECTOR(8 downto 0);
signal ND: STD_LOGIC_VECTOR(8 downto 0);
signal cycle: INTEGER RANGE 0 to 18;
begin
D <= '0' & IN_D;
ND <= '0' & (-IN_D);
OUT_R <= X(15 downto 8);
OUT_Q <= X(7 downto 0);
process is
variable sum: STD_LOGIC_VECTOR(8 downto 0);
begin
wait on EXT_CLK until EXT_CLK = '1';
if (GO = '1') then
cycle <= 1;
X <= "000000000" & IN_N;
elsif (cycle = 0) then
elsif (cycle = 17) then
if (X(0) = '0') then
X(15 downto 8) <= X(15 downto 8) + D(7 downto 0);
end if;
cycle <= 0;
elsif (cycle mod 2 = 1) then
X <= '0' & X(14 downto 0) & '0';
cycle <= cycle + 1;
else
if ((X(1) = '1') or (cycle = 2)) then
sum := X(16 downto 8) + ND;
else
sum := X(16 downto 8) + D;
end if;
X(15 downto 8) <= sum(7 downto 0);
X(0) <= sum(8);
cycle <= cycle + 1;
end if ;
end process;
end Behavioral;
Y el código del test bench que he hecho yo es el siguiente:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY testbench IS
END testbench;
ARCHITECTURE behavior OF testbench IS
-- Component Declaration
COMPONENT divisor
PORT(
GO : IN std_logic;
IN_N : IN std_logic_vector(7 downto 0);
IN_D : IN std_logic_vector(7 downto 0);
EXT_CLK: IN std_logic;
END COMPONENT;
--Entradas
SIGNAL EXT_CLK : std_logic:='0';
SIGNAL GO : std_logic :='1';
SIGNAL IN_N : std_logic_vector(7 downto 0) := "00001110";
SIGNAL IN_D: std_logic_vector(7 downto 0) := "00000010";
--Outputs
SIGNAL OUT_Q: std_logic_vector(7 downto 0);
SIGNAL OUT_R: std_logic_vector(7 downto 0);
BEGIN
-- Component Instantiation
uut: divisor PORT MAP(
EXT_CLK => EXT_CLK,
GO => GO,
IN_N => IN_N,
IN_D => IN_D,
OUT_Q => OUT_Q,
OUT_R => OUT_R);
-- Test Bench Statements
tb : PROCESS
BEGIN
wait for 100 ns; -- wait until global set/reset completes
-- Add user defined stimulus here
wait; -- will wait forever
END PROCESS tb;
-- End Test Bench
END;
Pero al probarlo las salidas OUT_Q y OUT_R toman los valores UUUUUUUU y no se por qué es
tb : PROCESS
BEGIN
Aqui debes ir modificando las señales de entrada al módulo divisor.
END PROCESS tb;
-- End Test Bench
END;
El test bench lo que hace es mover las señales de entrada al módulo divisor. Pero tu aqui no tienes señales moviendose por lo que las salidas están indeterminadas 'UUUUU'
