Microcontroladores PIC => Lenguaje C para microcontroladores PIC => Mensaje iniciado por: PalitroqueZ en 24 de Mayo de 2006, 13:40:30
Hola amigos foreros, gracias a unas librerias que trae el CCS, pude hacer funcionar una lcd gráfica que trae el proteus
(http://img221.imageshack.us/img221/4002/lcdg2tm.gif)
y el código
#include <16F877.h>
#include <HDM64GS12.c>
#include <graphics.c>
#use delay(clock=20000000)
// FORMA PARTE DE LA LIBRERIA GLCD.C
//// glcd_init(mode) ////
//// * Must be called before any other function. ////
//// - mode can be ON or OFF to turn the LCD on or off ////
//// glcd_pixel(x,y,color) ////
//// * Sets the pixel to the given color. ////
//// - color can be ON or OFF ////
//// glcd_line(x1,y1,x2,y2,color) ////
//// * Draws a line from the first point to the second point ////
//// with the given color. ////
//// glcd_rect(x1,y1,x2,y2,fill,color) ////
//// * Draws a rectangle with upper left point (x1,y1) and lower ////
//// right point (x2,y2). ////
//// - fill can be YES or NO ////
//// glcd_bar(x1,y1,x2,y2,width,color) ////
//// * Draws a bar (wide line) from the first point to the ////
//// second point. ////
//// - width is the number of pixels wide ////
//// - color is ON or OFF ////
//// glcd_circle(x,y,radius,fill,color) ////
//// * Draws a circle with center at (x,y) ////
//// glcd_text57(x,y,textptr,size,color) ////
//// * Write the null terminated text pointed to by textptr with ////
//// the upper left coordinate of the first character at (x,y).////
//// Characters are 5 pixels wide and 7 pixels tall. ////
//// - size is an integer that scales the size of the text ////
//// * Note - The given text is character wrapped. If this ////
//// function is used on a different size display, then change ////
//// the GLCD_WIDTH define appropriately. ////
//// glcd_fillScreen(color) ////
//// * Fills the entire LCD with the given color. ////
// FORMA PARTE DE LA LIBRERIA HDM64GS12.c
//// glcd_update() ////
//// * Write the display data stored in RAM to the LCD ////
//// * Only available if FAST_GLCD is defined ////
// FORMA PARTE DE LA LIBRERIA graphics.c
//// glcd_line(x1, y1, x2, y2, color) ////
//// with the given color ////
//// glcd_rect(x1, y1, x2, y2, fill, color) ////
//// * Draws a rectangle with one corner at point (x1,y1) and ////
//// the other corner at point (x2,y2) ////
//// glcd_bar(x1, y1, x2, y2, width, color) ////
//// second point ////
//// glcd_circle(x, y, radius, fill, color) ////
//// glcd_text57(x, y, textptr, size, color) ////
//// the upper left coordinate of the first character at (x,y) ////
//// Characters are 5 pixels wide and 7 pixels tall ////
//// * Note - This function wraps characters to the next line ////
//// use #define GLCD_WIDTH to specify a display width ////
//para la pantalla usada max resolucion=(190,,ON)
void main(){
int t;
char voltText[] = "PalitroqueZ";
char segunda[] = " TODOPIC";
glcd_init(ON);
s: glcd_text57(30, 25, voltText, 1, on);
glcd_text57(30, 35, segunda, 1, on);
delay_ms(100);
glcd_fillScreen(ON);
glcd_text57(30, 25, voltText, 1, off);
glcd_text57(30, 35, segunda, 1, off);
delay_ms(100);
glcd_fillScreen(OFF);
goto s;
el adjunto con todo:
hola amigo gracias por postear tu trabajo aqui. bueno queria decirte que copie el ejemplo que colocaste y lo conecte igual en proteus identicamente y no me funciona, no sale en la pantalla lo que escribiste en el programa. yo pienso que las librerias que tengo de grafics.c y la de HDM64GS12.c no son las mismas que tienes en tu ccs y por eso no corre pero si me puedes ayudar
hola buenas tardes, yo en una oportunidad tambien probe ese ejemplo del colega y no me funciono de principio y resulto que no estaban declarados los fuses del pic luego que se los coloque me funciono sin problema alguno.
Saludos y espero puedas resolver ojo yo lo monte en fisico en proteus no lo probe.
Atten.
Alexander Santana.
Venezuela-Barcelona.
