Lenguajes de programación para PC => Visual Basic => Mensaje iniciado por: IAO en 27 de Septiembre de 2007, 14:52:05
Título: Por qué no me agrega nada al .TXT
Publicado por: IAO en 27 de Septiembre de 2007, 14:52:05
Holaaaaaa:
Algúno de los cerebros en VB, podría decirme por qué el programa no me agrega nada en el txt?.
Me aparece como si se grabó algo, pero cuando abro el txt no hay nada.
Gracias anticipadas por responder.
Option Explicit
'''Boton Closecomm1
Private Sub Closecomm1_Click()
'''Close the port if it is open
If MSComm1.PortOpen = True Then MSComm1.PortOpen = False
 '''Close le userform at the end of the reception
 'Form1.Hide
End Sub
'''Boton Opencomm1
Private Sub Opencomm1_Click()
If MSComm1.PortOpen = False Then MSComm1.PortOpen = True
Call Receive
End Sub
Private Sub Form_Load()
'''Chose correct settings for your device
Dim Settings As String
Settings = "9600,n,8,1"
MSComm1.CommPort = 1
MSComm1.Settings = Settings
With MSComm1
'''Receive chr by chr
    MSComm1.InputLen = 1
    MSComm1.RThreshold = 0
    MSComm1.SThreshold = 0
    MSComm1.InBufferSize = 1024       '''10kb
    MSComm1.InputMode = comInputModeText
    MSComm1.Handshaking = 0            '''None
End With
End Sub
Private Sub Receive()
Dim FileName As String
Dim RxTxt As Variant
Dim inbuff As Variant
FileName = App.Path & "\RS232.txt"
Open FileName For Output As #1
    Do
    DoEvents
    RxTxt = MSComm1.Input
'''Start capture if you get some input you may also wait for some other specific character
    Print #1, inbuff
    Loop Until RxTxt > vbNullString
    inbuff = vbNullString
    Do
    DoEvents
'''Data is supposed to be separated by Chr(10) chose another separationmark if neccesary
        If RxTxt = Chr(10) And Len(inbuff) > 0 Then
            If inbuff = Left(inbuff, 1) = Chr(10) Then inbuff = Right(inbuff, Len(inbuff) - 1)
            Print #1, inbuff
        Else
            If Len(RxTxt) > 0 Then
            inbuff = inbuff + RxTxt
            End If
        End If
'''Data is supposed to end with Chr(3) chose another endmark if neccesary.
    Loop Until RxTxt = Chr(3)
Close #1
End Sub
Bye('_').
Título: Re: Por qué no me agrega nada al .TXT
Publicado por: IAO en 01 de Octubre de 2007, 11:25:39
Holaaaaaaa:
Asi lo pude hacer funcionar, más  o menos bastante aceptable.
Option Explicit
'''Boton Closecomm1
    End If
End Sub
Dim CommPort As String, Settings As String
MSComm1.CommPort = 1                'puerto com1
MSComm1.Settings = "9600,n,8,1"     'configuracion del puerto serie
MSComm1.PortOpen = True             'se abre el puerto para que funcione
MSComm1.RThreshold = 1              'cada byte recibido, dispara el evento OnComm
End Sub
 Private Sub MSComm1_OnComm()
 Dim Inbuff As String
If MSComm1.CommEvent = comEvReceive Then           'si el puerto comienza a recibir .....
  Inbuff = MSComm1.Input                           'en esta variable se almacena lo que entra por el puerto serie
     Print #1, Inbuff
End If
 End Sub
Private Sub Form_Terminate()    '''Cuando se finaliza el Formulario
    End If
    Close #1
End Sub
Allí se los dejo, para que sufran menos al momento de querer hacer algo parecido. :)
Bye('_').
