#include <18F2550.h>
//~~~ 20MHZ OSCILLATOR CONFIGS ~~~//
//// FULL SPEED
#use delay(clock=48000000)
#use rs232(baud=9600)
// If you are using a USB connection sense pin, define it here. If you are
// not using connection sense, comment out this line. Without connection
// sense you will not know if the device gets disconnected.
// (connection sense should look like this:
// 100k
// VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
// +----/\/\/\/\/\-----GND
// 100k
// (where VBUS is pin1 of the USB connector)
// the CCS 18F4550 development kit has this pin
// #define USB_CON_SENSE_PIN PIN_B2
// Include the CCS USB Libraries. See the comments at the top of these
// files for more information
#include <pic18_usb.h> //Microchip PIC18Fxx5x hardware layer for usb.c
#include <usb_desc_mouse.h> //USB Configuration and Device descriptors for this UBS device
#include <usb.c> //handles usb setup tokens and get descriptor reports
// Configure the demonstration I/O
#define LED2 PIN_B4
#define LED3 PIN_B5
#define LED_ON(x) output_low(x)
#define LED_OFF(x) output_high(x)
#define BUTTON_PRESSED() !input(PIN_A4)
