#include <16F88.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT //No Power Up Timer
#FUSES MCLR //Master Clear pin enabled
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOPROTECT //Code not protected from reading
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES IESO //Internal External Switch Over mode enabled
#use delay(clock=20000000)
#define LCD_TYPE 2
#include <lcd.c>
#use fast_io(a)
int i;
char n;
void vista();
void convierte();
//set_tris_a(1);//'1'-->entrada ; '0'--> salida
lcd_init();
setup_adc_ports(sAN1|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL );
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_vref(FALSE);
while(1){
vista();
convierte();
void vista(){
lcd_putc(" Iniciando");
delay_ms(1000);
for(i=0;i<=3;i++) //me muestra los ....
lcd_gotoxy((13+i),1);
lcd_putc(".");
delay_ms(300);
delay_ms(2000);
lcd_putc("\f");
lcd_putc(" Sistemas Para\n");
lcd_putc(" Control-2010");
delay_ms(3000);
lcd_putc("\f");
lcd_putc(" Control Temp\n"); //Saca texto
lcd_putc(" con LM 35"); //Saca texto
delay_ms(3000);
lcd_putc("\f");
void convierte(){
set_adc_channel(0);
delay_us(50);
n=read_adc();
lcd_gotoxy(1,1);
delay_ms(2000);
