para avr en c
unsigned char i;
unsigned char PS2byte;
unsigned char PS2data4;
unsigned char PS2data5;
#define PS2clk 3 // bit 3
#define PS2cmd 2 // bit 2
#define PS2att 1 // bit 1
#define PS2dat 0 // bit 0
#define PS2PORT PORTB // change to fit your port hardware
#define PS2IN PINB // change to fit your port hardware
void ReadGamepad()
SET(PS2PORT,PS2cmd);
SET(PS2PORT,PS2clk);
CLR(PS2PORT,PS2att); // low enable joystick
Delay(1); // one uS delay CPU timed at the clock speed your AVR is running.
PS2byte=0x01; // first command
for(i=0;i<8;i++)
if(CHK(PS2byte,i)) SET(PS2PORT,PS2cmd);
else CLR(PS2PORT,PS2cmd);
CLR(PS2PORT,PS2clk); //Delay(1); if you run faster then 8Mhz you might need a small delay
Delay(1);
PS2byte=0x42; // sec command
for(i=0;i<8;i++)
Delay(1);
for(i=0;i<8;i++) // 3 byte
Delay(1);
PS2data4=0;
for(i=0;i<8;i++) // 4 byte
CLR(PS2PORT,PS2clk); Delay(1); // this delay is needed even at 8MHz!!
if(CHK(PS2IN,PS2dat)) SET(PS2data4,i);
Delay(1);
PS2data5=0;
for(i=0;i<8;i++) // 5 byte
if(CHK(PS2IN,PS2dat)) SET(PS2data5,i);
Delay(1);
SET(PS2PORT,PS2att); // HI disable joystick
