Microcontroladores PIC => Lenguaje Basic para microcontroladores PIC => Mensaje iniciado por: arnoldojrm en 28 de Junio de 2004, 02:19:00
mi picbasic pro no posee el archivo 16f877.bas, cuando intento compilar para este pic me da un error, lo que no pasa para el 16f84, podria conseguir el archivo individual o estoy haciendo algo mal.
la instruccion para compilar que estoy usando es
pbp i2c.bas -p16f877
de antemano gracias
arnoldojrm@yahoo.es
;* 16F877.INC *
;* By : Leonard Zerman, Jeff Schmoyer *
;* Notice : Copyright (c) 2003 microEngineering Labs, Inc. *
;* All Rights Reserved *
;* Date : 11/07/03 *
;* Version : 2.45 *
;* Notes : *
NOLIST
ifdef PM_USED
LIST
include "M16F87x.INC" ; PM header
device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off
XALL
NOLIST
else
LIST
LIST p = 16F877, r = dec, w = -302
INCLUDE "P16F877.INC" ; MPASM Header
__config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
NOLIST
endif
LIST
"* 16F777.BAS *
"* By : Leonard Zerman, Jeff Schmoyer *
"* Notice : Copyright (c) 2003 microEngineering Labs, Inc. *
"* All Rights Reserved *
"* Date : 10/30/03 *
"* Version : 2.45 *
"* Notes : *
BANK0 $0020, $007F
BANK1 $00A0, $00EF
BANK2 $0110, $016F
BANK3 $0190, $01EF
LIBRARY "PBPPIC14"
DEFINE CODE_SIZE 8
include "PIC14EXT.BAS"
PORTL VAR PORTB
PORTH VAR PORTC
TRISL VAR TRISB
TRISH VAR TRISC
include "PBPPIC14.RAM"
"*-----------------------* EOF 16F777.BAS *---------------------*
"* PBPPIC14.RAM *
"* Notice : Copyright (c) 1998 microEngineering Labs, Inc. *
"* Date : 08/18/98 *
"* Version : 2.10 *
"* Notes : PIC14 library RAM assignments *
R0 VAR WORD BANK0 SYSTEM " System Register
R1 VAR WORD BANK0 SYSTEM " System Register
R2 VAR WORD BANK0 SYSTEM " System Register
R3 VAR WORD BANK0 SYSTEM " System Register
R4 VAR WORD BANK0 SYSTEM " System Register
R5 VAR WORD BANK0 SYSTEM " System Register
R6 VAR WORD BANK0 SYSTEM " System Register
R7 VAR WORD BANK0 SYSTEM " System Register
R8 VAR WORD BANK0 SYSTEM " System Register
RR1 VAR BYTE BANK0 SYSTEM " Pin 1 Register
RM1 VAR BYTE BANK0 SYSTEM " Pin 1 Mask
RR2 VAR BYTE BANK0 SYSTEM " Pin 2 Register
RM2 VAR BYTE BANK0 SYSTEM " Pin 2 Mask
GOP VAR BYTE BANK0 SYSTEM " Gen Op Parameter
FLAGS VAR BYTE BANK0 SYSTEM " Static flags
"*-----------------------* EOF PBPPIC14.RAM *-------------------*
; PIC16F87x Family Header
; Copyright 1995, 2002 microEngineering Labs, Inc.
NOLIST
; *** Default Device Specifications
DEVICE 3FFF3FFFh ; All Fuse Bits On
DEVICE 50101004h ; 14-Bit, 8K Code, 256 EE, ID = 4
; *** DEVICE Device Definitions
PIC16F873 equ 50080803h ; 14-Bit, 4K Code, 128 EE, ID = 3
PIC16F874 equ 50080803h ; 14-Bit, 4K Code, 128 EE, ID = 3
PIC16F876 equ 50101004h ; 14-Bit, 8K Code, 256 EE, ID = 4
PIC16F877 equ 50101004h ; 14-Bit, 8K Code, 256 EE, ID = 4
; *** DEVICE Fuses Definitions
RC_OSC equ 3FFC0003h ; XX XXXX XXXX XX11
HS_OSC equ 3FFC0002h ; XX XXXX XXXX XX10
XT_OSC equ 3FFC0001h ; XX XXXX XXXX XX01
LP_OSC equ 3FFC0000h ; XX XXXX XXXX XX00
WDT_ON equ 3FFB0004h ; XX XXXX XXXX X1XX
WDT_OFF equ 3FFB0000h ; XX XXXX XXXX X0XX
PWRT_ON equ 3FF70000h ; XX XXXX XXXX 0XXX
PWRT_OFF equ 3FF70008h ; XX XXXX XXXX 1XXX
BOD_ON equ 3FBF0040h ; XX XXXX X1XX XXXX
BOD_OFF equ 3FBF0000h ; XX XXXX X0XX XXXX
LVP_ON equ 3F7F0080h ; XX XXXX 1XXX XXXX
LVP_OFF equ 3F7F0000h ; XX XXXX 0XXX XXXX
CPD_ON equ 3EFF0000h ; XX XXX0 XXXX XXXX
CPD_OFF equ 3EFF0100h ; XX XXX1 XXXX XXXX
WRT_ON equ 3DFF0200h ; XX XX1X XXXX XXXX
WRT_OFF equ 3DFF0000h ; XX XX0X XXXX XXXX
DEBUG_ON equ 37FF0000h ; XX 0XXX XXXX XXXX
DEBUG_OFF equ 37FF0800h ; XX 1XXX XXXX XXXX
PROTECT_ON equ 0FCF0000h ; 00 XXXX XX00 XXXX
PROTECT_OFF equ 0FCF3030h ; 11 XXXX XX11 XXXX
; *** Register Names
INDF equ 00h ; Indirect Data
TMR0 equ 01h ; Real Time Clock/Counter
PCL equ 02h ; Program Counter (LSB)
STATUS equ 03h ; Status Flags
FSR equ 04h ; File Select Register
PORTA equ 05h ; Port A Data
PORTB equ 06h ; Port B Data
PORTC equ 07h ; Port C Data
PORTD equ 08h ; Port D Data
PORTE equ 09h ; Port E Data
PCLATH equ 0Ah ; Program Counter (MSB)
INTCON equ 0Bh ; Interrupt Control
PIR1 equ 0Ch ; Peripheral Interrupt Flags 1
PIR2 equ 0Dh ; Peripheral Interrupt Flags 2
TMR1L equ 0Eh ; Timer 1 Data (LSB)
TMR1H equ 0Fh ; Timer 1 Data (MSB)
T1CON equ 10h ; Timer 1 Control
TMR2 equ 11h ; Timer 2 Data
T2CON equ 12h ; Timer 2 Control
SSPBUF equ 13h ; SSP Data
SSPCON equ 14h ; SSP Control
CCPR1L equ 15h ; CCP 1 Data (LSB)
CCPR1H equ 16h ; CCP 1 Data (MSB)
CCP1CON equ 17h ; CCP 1 Control
RCSTA equ 18h ; ASP Status/Control
TXREG equ 19h ; ASP Transmit Data
RCREG equ 1Ah ; ASP Receive Data
CCPR2L equ 1Bh ; CCP 2 Data (LSB)
CCPR2H equ 1Ch ; CCP 2 Data (MSB)
CCP2CON equ 1Dh ; CCP 2 Control
ADRESH equ 1Eh ; A/D Result High
ADRES equ 1Eh ; A/D Result High
ADCON0 equ 1Fh ; A/D Control 0
OPTION_REG equ 81h ; OPTION Register
TRISA equ 85h ; Port A Tristate Control
TRISB equ 86h ; Port B Tristate Control
TRISC equ 87h ; Port C Tristate Control
TRISD equ 88h ; Port D Tristate Control
TRISE equ 89h ; Port E Tristate Control
PIE1 equ 8Ch ; Peripheral Interrupt Enables 1
PIE2 equ 8Dh ; Peripheral Interrupt Enables 2
PCON equ 8Eh ; Power Control
SSPCON2 equ 91h ; SSP Control 2
PR2 equ 92h ; Timer 2 Period
SSPADD equ 93h ; SSP I2C Address
SSPSTAT equ 94h ; SSP Status Flags
TXSTA equ 98h ; ASP Transmit Status/Control
SPBRG equ 99h ; ASP Baud Rate
ADRESL equ 9Eh ; A/D Result Low
ADCON1 equ 9Fh ; A/D Control 1
EEDATA equ 10Ch ; EEPROM Data
EEADR equ 10Dh ; EEPROM Address
EEDATH equ 10Eh ; EEPROM Data High
EEADRH equ 10Fh ; EEPROM Address High
EECON1 equ 18Ch ; EEPROM Control 1
EECON2 equ 18Dh ; EEPROM Control 2
; *** STATUS Bits
C equ 0 ; Carry
DC equ 1 ; Digit (Half) Carry
Z equ 2 ; Zero
PD equ 3 ; Power Down
TO equ 4 ; Time Out
RP0 equ 5 ; Direct Data Page Select 0
RP1 equ 6 ; Direct Data Page Select 1
IRP equ 7 ; Indirect Data Page Select
; *** INTCON Bits
RBIF equ 0 ; PORTB[4..7] Change Interrupt Flag
INTF equ 1 ; RB0/INT Interrupt Flag
T0IF equ 2 ; TMR0 Overflow Interrupt Flag
RBIE equ 3 ; PORTB[4..7] Change Interrupt Enable
INTE equ 4 ; RB0/INT Interrupt Enable
T0IE equ 5 ; TMR0 Overflow Interrupt Enable
PEIE equ 6 ; Peripheral Interrupt Enable
GIE equ 7 ; Global Interrupt Enable
; *** PIR1 Bits
TMR1IF equ 0 ; Timer 1 Interrupt Flag
TMR2IF equ 1 ; Timer 2 Interrupt Flag
CCP1IF equ 2 ; CCP 1 Interrupt Flag
SSPIF equ 3 ; SSP Interrupt Flag
TXIF equ 4 ; ASP Transmit Interrupt Flag
RCIF equ 5 ; ASP Receive Interrupt Flag
ADIF equ 6 ; A/D Interrupt Flag
PSPIF equ 7 ; PSP Interrupt Flag
; *** PIR2 Bits
CCP2IF equ 0 ; CCP 2 Interrupt Flag
BCLIF equ 3 ; Bus Collision Interrupt Flag
EEIF equ 4 ; EEPROM Interrupt Flag
; *** T1CON Bits
TMR1ON equ 0 ; Timer 1 Enable
TMR1CS equ 1 ; Timer 1 Clock Select
T1INSYNC equ 2 ; Timer 1 Sync Enable
T1OSCEN equ 3 ; Timer 1 Oscillator Enable
T1CKPS0 equ 4 ; Timer 1 Prescaler Select (2 Bits)
T1CKPS1 equ 5
; *** T2CON Bits
T2CKPS0 equ 0 ; Timer 2 Prescaler Select (2 Bits)
T2CKPS1 equ 1
TMR2ON equ 2 ; Timer 2 Enable
TOUTPS0 equ 3 ; Timer 2 Postscaler Select (4 Bits)
TOUTPS1 equ 4
TOUTPS2 equ 5
TOUTPS3 equ 6
; *** SSPCON Bits
SSPM0 equ 0 ; SSP Mode Select (4 Bits)
SSPM1 equ 1
SSPM2 equ 2
SSPM3 equ 3
CKP equ 4 ; SSP Clock Polarity Select
SSPEN equ 5 ; SSP Enable
SSPOV equ 6 ; SSP Receive Overflow Flag
WCOL equ 7 ; SSP Write Collision Detect
; *** CCP1CON Bits
CCP1M0 equ 0 ; CCP 1 Mode Select (4 Bits)
CCP1M1 equ 1
CCP1M2 equ 2
CCP1M3 equ 3
CCP1Y equ 4 ; CCP 1 PWM Bit 0
CCP1X equ 5 ; CCP 1 PWM Bit 1
; *** RCSTA Bits
RX9D equ 0 ; ASP Received 9th/Parity Bit
OERR equ 1 ; ASP Overrun Flag
FERR equ 2 ; ASP Framing Error Flag
ADDEN equ 3
CREN equ 4 ; ASP Continuous Receive Enable
SREN equ 5 ; ASP Single Receive Enable
RX9 equ 6 ; ASP Receive Data Length Select
SPEN equ 7 ; ASP Enable
; *** CCP2CON Bits
CCP2M0 equ 0 ; CCP 2 Mode Select (4 Bits)
CCP2M1 equ 1
CCP2M2 equ 2
CCP2M3 equ 3
CCP2Y equ 4 ; CCP 2 PWM Bit 0
CCP2X equ 5 ; CCP 2 PWM Bit 1
; *** ADCON0 Bits
ADON equ 0 ; A/D Power Control
GO_DONE equ 2 ; A/D GO/DONE Bit
CHS0 equ 3 ; A/D Channel Select (4 Bits)
CHS1 equ 4
CHS2 equ 5
ADCS0 equ 6 ; A/D Clock Select (2 Bits)
ADCS1 equ 7
; *** OPTION Bits
PS0 equ 0 ; Prescaler Divisor Select (3 Bits)
PS1 equ 1
PS2 equ 2
PSA equ 3 ; Prescaler Assignment
T0SE equ 4 ; Timer 0 Source Edge Select
T0CS equ 5 ; Timer 0 Clock Source Select
INTEDG equ 6 ; RB0/INT Edge Select
RBPU equ 7 ; Port B Weak Pull-Up Enable
; *** TRISE Bits
TRISE0 equ 0 ; PORTE[0..2] Tristate Control (3 Bits)
TRISE1 equ 1
TRISE2 equ 2
PSPMODE equ 4 ; PSP Mode Select
IBOV equ 5 ; PSP Input Buffer Overflow Flag
OBF equ 6 ; PSP Output Buffer Full Flag
IBF equ 7 ; PSP input Buffer Full Flag
; *** PIE1 Bits
TMR1IE equ 0 ; Timer 1 Interrupt Enable
TMR2IE equ 1 ; Timer 2 Interrupt Enable
CCP1IE equ 2 ; CCP 1 Interrupt Enable
SSPIE equ 3 ; SSP Interrupt Enable
TXIE equ 4 ; ASP Transmit Interrupt Enable
RCIE equ 5 ; ASP Receive Interrupt Enable
ADIE equ 6 ; A/D Interrupt Enable
PSPIE equ 7 ; PSP Interrupt Enable
; *** PIE2 Bits
CCP2IE equ 0 ; CCP 2 Interrupt Enable
BCLIE equ 3 ; Bus Collision Interrupt Enable
EEIE equ 4 ; EEPROM Interrupt Enable
; *** PCON Bits
BOR equ 0 ; Brown-Out Reset Flag
POR equ 1 ; Power-On Reset Flag
; *** SSPCON2 Bits
SEN equ 0
RSEN equ 1
PEN equ 2
RCEN equ 3
ACKEN equ 4
ACKDT equ 5
ACKSTAT equ 6
GCEN equ 7
; *** SSPSTAT Bits
BF equ 0 ; SSP Buffer Full Flag
UA equ 1 ; SSP I2C Update Address Flag
R_W equ 2 ; SSP I2C Read/Write Status
S equ 3 ; SSP I2C Start Flag
P equ 4 ; SSP I2C Stop Flag
D_A equ 5 ; SSP I2C Data/Address Flag
CKE equ 6 ; SSP SPI Clock Edge Select
SMP equ 7 ; SSP SPI Data Input Sample Phase
; *** TXSTA Bits
TX9D equ 0 ; ASP Transmit 9th Bit
TRMT equ 1 ; ASP Transmit Shift Register Empty
BRGH equ 2 ; ASP High Baud Rate Select
SYNC equ 4 ; ASP Mode Select
TXEN equ 5 ; ASP Transmit Enable
TX9 equ 6 ; ASP Transmit Data Length Select
CSRC equ 7 ; ASP Clock Source Select
; *** ADCON1 Bits
PCFG0 equ 0 ; Port A Configuration (3 Bits)
PCFG1 equ 1
PCFG2 equ 2
PCFG3 equ 3
ADFM equ 7 ; A/D Result Format Select
; *** EECON1 Bits
RD equ 0 ; EEPROM Read Control
WR equ 1 ; EEPROM Write Control
WREN equ 2 ; EEPROM Write Enable
WRERR equ 3 ; EEPROM Write Error Flag
EEPGD equ 7 ; EEPROM Program / Data Select
LIST
muchas gracias, los consejos que me han dado trabajan de maravilla.
De nada, lo único que he hecho, es poner una copia exacta de las librerías que necesitabas... <img border="0" width="15" height="15" src="http://pics.miarroba.com/caretos/biggrin.gif">
de todos modos veo que tienes que PBP incompleto
