Microcontroladores PIC => Lenguaje Basic para microcontroladores PIC => Mensaje iniciado por: Noelillo en 30 de Marzo de 2015, 10:11:37
Estoy desarrollando un proyecto y estoy utilizando el Pic 16F877A a 20 MHz. Ya no tengo memoria para continuar...buscando un Pic con mas memoria y con los mismos pines, el Pic 18F4550 en el mas compatible (por los pines).
Programe el pic 18F4550 y no funciona.
Busque un programa mas sencillo para comprobar diferencias. El programa es el siguiente:
'* Name : UNTITLED.BAS *
'* Author : [select VIEW...EDITOR OPTIONS] *
'* Notice : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 29/03/2015 *
'* Version : 1.0 *
'* Notes : *
' Read text from a Toshiba graphic LCD
'Device 16F877A
Device 18F4550
LCD_TYPE = TOSHIBA ' Use a Toshiba T6963 graphic LCD
XTAL = 20
' LCD interface pin assignments
LCD_DTPORT = PORTD ' LCD’s Data port
LCD_WRPIN = PORTC.0
LCD_RDPIN = PORTC.1
LCD_CEPIN = PORTC.2 ' LCD’s CE line
LCD_CDPIN = PORTC.3 ' LCD’s CD line
LCD_RSTPIN = PORTC.4 ' LCD’s RESET line (Optional)
' LCD characteristics
' LCD_X_RES = 128 ' LCD's X Resolution
' LCD_Y_RES = 64 ' LCD's Y Resolution
' LCD_FONT_WIDTH = 8 ' The width of the LCD’s font
LCD_TEXT_PAGES = 2 ' Choose two text pages
LCD_RAM_SIZE = 20480'8192 ' Amount of RAM the LCD contains
LCD_X_RES = 160 ' LCD’s X Resolution
LCD_Y_RES = 128 ' LCD’s Y Resolution
LCD_TEXT_HOME_ADDRESS = 0 ' Ensure that text RAM starts at address 0
Dim CHARPOS As Byte ' The X position of the read
Dim CHAR As Byte ' The byte read from the LCD
DelayMS 200 ' Wait for things to stabilise
ALL_DIGITAL = True ' PORTA and PORTE to digital mode
Cls
Low PORTE.2
Cls
Print At 0,0," THIS IS FOR COPYING" ' Display some text on the top line of the LCD
For CHARPOS = 0 To 20 ' Create a loop of 21 cycles
CHAR = LCDRead TEXT 0,CHARPOS ' Read the top line of the LCD
Print At 6,CHARPOS,CHAR ' Print the byte read on the second line
DelayMS 100 ' A small delay so we can see things happen
Next
High PORTE.2
'Cls ' Close the loop
Stop
/code]'
Cuando lo programo con el 16F877A ('Device 16F877A ) funciona bien. pero cuando lo programo con el 18F4550 (Device 18F4550) no sale nada en pantalla.
No se si antes se tiene que configurar algo... No se!!
He probado poner todas las salidas a 1 y portc.6, 5, 4 y 3 no ilumina los led.
Como me toca los co..nes...
Yo no uso basic sino te ayudaria.
Noelillo debes buscar en la ayuda del compilador la configuración del bloque oscilador de los 18F, porque no basta con solo asignar la frecuencia del cristal, hay que configurar la frecuencia del CPU del micro.
He buscado lo de configuracion de bloque y no encuentro nada. Estoy utilizando el PROTON.
voy a buscar ejemplos en Basic Proton que utilices el 18F4550.
Imposible hacer que se ilumine los led conectados en los puertos Portc 6,5,4 y 3.
Q tienen de especiales estos pines?
Declare onboard_usb = 0 ,es para no usar el puerto USB?
Para que coño vale poner Device 18f4550 si cada vez que cambias un nuevo pic tienes unos problemas de cojones...
Se puede ampliar la memoria del 16F877A?
Para que coño me dio por pasar, de encender y apagar led a pantallas graficas y M pap.
:oops: :oops: :oops: :oops:
(http://www.todopic.com.ar/foros/index.php?action=dlattach;topic=15208.0;attach=5323)
(http://www.todopic.com.ar/foros/index.php?action=dlattach;topic=15208.0;attach=5325)
http://www.todopic.com.ar/foros/index.php?topic=15208.msg95575#msg95575
otro detalle, leyendo la configuración del portc, me encuentro con que no existe RC3 y eso no es todo, RC4 y RC5 solo funcionan como entrada digital, parece que es el precio a pagar por implementar nuevos modulos(ver pag 119)
Zu Put_ Madre... El proyecto que estoy haciendo, tengo una pantalla GLCD y esta conectada al Puerto C, por eso no funciona...
Tendre que cambiar de puerto... :(
Muchas Gracias por la informacion ((:-))
Ya esta arreglado...
