unsigned short kp, cnt, cnt2, A, B, T, oldstate = 0;
char txt[6];
char txt2[6];
char num1[6];
char num2[6];
char total[6];
// Keypad module connections
char keypadPort at PORTD;
// End Keypad module connections
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
void main() {
cnt = 0; // Reset counter
Keypad_Init(); // Initialize Keypad
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1, 1, "Sumando: "); // Write message text on LCD
do {
kp = 0; // Reset key code variable
// Wait for key to be pressed and released
do
// kp = Keypad_Key_Press(); // Store key code in kp variable
kp = Keypad_Key_Click(); // Store key code in kp variable
while (!kp);
// Prepare value for output, transform key to it's ASCII value
switch (kp) {
//case 10: kp = 42; break; // '*' // Uncomment this block for keypad4x3
//case 11: kp = 48; break; // '0'
//case 12: kp = 35; break; // '#'
//default: kp += 48;
case 1: kp = 49; break; // 1 // Uncomment this block for keypad4x4
case 2: kp = 50; break; // 2
case 3: kp = 51; break; // 3
case 4: kp = 43; break; // A
case 5: kp = 52; break; // 4
case 6: kp = 53; break; // 5
case 7: kp = 54; break; // 6
case 8: kp = 66; break; // B
case 9: kp = 55; break; // 7
case 10: kp = 56; break; // 8
case 11: kp = 57; break; // 9
case 12: kp = 67; break; // C
case 13: kp = 42; break; // *
case 14: kp = 48; break; // 0
case 15: kp = 35; break; // #
case 16: kp = 61; break; // D
cnt++;
Lcd_Chr_cp(kp); // Print key ASCII value on LCD
if (cnt==0){
A=kp;
IntToStr(kp,num1); //se almacena en num1 como txt
A=num1;
//??????????????; //no encuentro como convertirlo a decimal tambien
} //para poder sumarlo
if (cnt==1){
IntToStr(kp,num2); //se transforma y almacena en num1 como texto
B=num2;
if (cnt==3){
T=A+B; //total=num1+num2
IntToStr(T,total); //estoy claro que no puedo sumar aqui
Lcd_Chr_cp(T);
} //algun comando como el inttostr, pero para
//convertir a decimal. y poder trabajarla aritmeticamente.
} while (1);
