Microcontroladores PIC => Lenguaje C para microcontroladores PIC => Mensaje iniciado por: jluisruelas en 09 de Julio de 2015, 01:15:26
Título: 18f4620 y xc8
Publicado por: jluisruelas en 09 de Julio de 2015, 01:15:26
Que tal amigos, tengo un pequeño o gran problema, y es que estoy empezando con este pic y el xc8, no tengo experiencia, salvo con el 16f877a, estoy empezando con algo básico hacer, parpadear un led, pero no funciona, el led se queda encendido, adjunto el código, saludos
 * File:   mainpruebas2.c
 * Author: l
 * Created on July 7, 2015, 1:32 PM
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1H
#pragma config OSC = HS         // Oscillator Selection bits (HS oscillator)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = ON        // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3         // Brown Out Reset Voltage bits (Minimum setting)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC   // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF      // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#define _XTAL_FREQ 20000000
#define __delay_ms(x) _delay((unsigned long)((x)*(_XTAL_FREQ/20000000.0)))
void main ()
     TRISB = 0b00000000; // Configuro puerto B como salidas
     while (1) // Bucle infinito
         PORTBbits.RB1 = 0; // Apago pin RB0
         __delay_ms(500);
         PORTBbits.RB1 = 1; // Enciendo pin RB0
         __delay_ms(500);
Título: Re: 18f4620 y xc8
Publicado por: KILLERJC en 09 de Julio de 2015, 02:52:50
Los PIC18 y algunos de los ultimos PIC16 poseen otra forma de salida, Poseen 3 registros
LATx , PORTx y TRISx
Para hacerlo corto, para leer usar el PORTx  ya que este te va a dar el valor que esta en el pin.
Si escribis usa LATx ya que este es el que maneja la salida del pin.
Asi que si queres cambiar el pin reemplaza:
Por:
LATBbits.LATB1 = 0;
O si queres simplificarlo
  1. while(1)
  2. {
  3.     LATBbits.RB1 ^= 1;
  4.     __dealy_ms(500);
  5. }
Tambien recorda que algunos pines es para entrada analogica y en el reset comienzan asi, asi que vas a tener uqe ponerlos como digital si es que ese pin debe cambiarse a digital
Publicado por: jluisruelas en 09 de Julio de 2015, 16:31:36
Hice el siguiente cambio y ya compila pero el led se queda encendido
 * Author: l
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#include <xc.h>
#include <pic18f4620.h>
//#include <delays.h>
#include <stdio.h>
#include <stdlib.h>
void main ()
         LATBbits.LB1 = 0; // Apago pin RB0
         __delay_ms(500);
         LATBbits.LB1 = 1; // Enciendo pin RB0
         __delay_ms(500);
Publicado por: jluisruelas en 09 de Julio de 2015, 17:26:16
no se a que se debera, estoy usando un cristal de 20MHZ y he corroborado que la función delay es la que no esta funcionando
Publicado por: KILLERJC en 09 de Julio de 2015, 19:37:37
Lo que no entiendo es por que esta tan limitada, no se si sera por el tema de que el cristal esta a 20Mhz
La funcion __delay_ms() ya se encuentra definida en "xc.h" asi que no hay necesidad de hacerlo de nuevo. Probe con el __delay_ms(500) y me dijo que era un argumento demasiado grande.
Imagino esto por que debe usar la funcion delay __delay() y este debe tener un numero maximo. Y si quisiera calcula la cantidad de ciclos a meter para 500ms serian:
500ms / (4/Fosc) = 2.500.000 ciclos.... y se necesitarian casi 24 bits para eso, y creo que le maximo es de 16 bits o 65535(Abajo digo cuales son los limites). Entonces intente hacer 500 delays de 1ms, y ahi me funciono.
  1. #include <xc.h>
  2. #include <stdint.h>        /* Includes uint16_t definition                    */
  3. #include <stdbool.h>       /* Includes true/false definition                  */
  4.
  5. #define _XTAL_FREQ 20000000
  6.
  7. void main() {
  8.     uint16_t i;
  9.     TRISB = 0b00000000; // Configuro puerto B como salidas
  10.     while (1) // Bucle infinito
  11.     {
  12.         LATBbits.LB1 = 0; // Apago pin RB0
  13.         for(i=0;i<499;i++) { __delay_ms(1); }
  14.         LATBbits.LB1 = 1; // Enciendo pin RB0
  15.         for(i=0;i<499;i++) { __delay_ms(1); }
  16.     }
  17. }
Tampoco pongo el .h del pic, ya que tambien se encuentra incluido por el compilador al elegirlo. Y la configuracion la tengo en otro archivo.
Culpa de de ese bucle si ponia (i < 500) en el for, terminaba durando:
Target halted. Stopwatch cycle count = 2505012 (501,0024 ms)
Entonces probe con 1 delay menos y termine con
Target halted. Stopwatch cycle count = 2500002 (500,0004 ms)
Si supongo el maximo de 65k (2^16) El maximo tiempo que puedo hacer una demora con ese oscilador es de 13ms :/
Asi que probe con:
  1. for(i=0;i<50;i++) { __delay_ms(10); }
Y obtuve:
Target halted. Stopwatch cycle count = 2500258 (500,0516 ms)
Pero lo que mas me llamo la atencion fue esto:
:: advisory: (1233) Employing 18F4620 errata work-arounds:
:: advisory: (1234)  * Corrupted fast interrupt shadow registers
:: advisory: (1234)  * Data in RAM location can be corrupted if async. reset occurs during write
********** EDIT **********
Buscando info por internet me encuentro que es distinto para PIC18 y para PIC16.
PIC16 , el maximo son 50.462.464 ciclos
PIC18 , el maximo es de 197.120 ciclos
Asi que el maximo delay que podes generar es de 197120 * Tcy = 39ms con ese cristal de 20Mhz, de intentar generar un valor mas grande, o repetis o usar un for.
Probado con
  1. for(i=0;i<20;i++) { __delay_ms(25); }
Resultado
Target halted. Stopwatch cycle count = 2500108 (500,0216 ms)
Publicado por: jluisruelas en 14 de Julio de 2015, 14:15:50
  1. #include <xc.h>
  4.
  6.
  7. void main() {
  8.     uint16_t i;
  11.     {
  16.     }
  17. }
Asi que probe con:
Y obtuve:
Probado con
Resultado
en efecto amigo si funciona, un saludo y agradecimiento
