Microcontroladores PIC => Lenguaje C para microcontroladores PIC => Mensaje iniciado por: jluisruelas en 14 de Julio de 2015, 14:26:49
Que tal amigos, ando de nuevo aquí, lo que pasa es que tengo el problema con mi programa de que cuando recibo datos por la usar, en la interrupción, el programa principal se queda colgado y no responde, hasta que se reinicio por el watch dog
* File: mainpruebas2.c
* Author: l
* Created on July 7, 2015, 1:32 PM
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1H
#pragma config OSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = ON // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3 // Brown Out Reset Voltage bits (Minimum setting)
// CONFIG2H
#pragma config WDT = ON // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
#include <xc.h>
#include <pic18f4620.h>
#include <delays.h>
#include <stdio.h>
#include <stdlib.h>
#include <plib/usart.h> //Libreria para el manejo del modulo USART
#define _XTAL_FREQ 20000000
//#define __delay_ms(x) _delay((unsigned long)((x)*(_XTAL_FREQ/20000000.0)))
int i;
char CaracterRx;
char MensajeTx[7];
void main ()
TRISB = 0b00000000; // Configuro puerto B como salidas
OpenUSART(USART_TX_INT_OFF &
USART_RX_INT_ON & //Activar la interrupcion por la recepcion de dato del buffer de Rx del USART
USART_ASYNCH_MODE & //Modo asincrono (fullduplex)
USART_EIGHT_BIT & //8 bits de datos
USART_CONT_RX & //Recepción continua
USART_BRGH_HIGH, 129); //9600 Baudios
// (frecuencia a la que trabaja el cpu/dbaudrate)/16)-1
// (8.000.000/9600)/16)-1=51
INTCONbits.PEIE = 1; //Activamos interrupcion de perifericos
INTCONbits.GIE = 1; //Activamos las interrupciones globales
while (1) // Bucle infinito
CLRWDT();
LATB=0x10; // Apago pin RB0
for(i=0;i<20;i++) { __delay_ms(12); }
LATB=0x00;
void interrupt Interrupcion() //Funcion que atiende las interrupciones
int k;
getsUSART((char *)MensajeTx,7);
//CaracterRx = ReadUSART(); //Se lee el dato que esta en el buffer de Rx del USART
/* MensajeTx[0]=ReadUSART();
MensajeTx[1]=ReadUSART();
MensajeTx[2]=ReadUSART();
MensajeTx[3]=ReadUSART();
MensajeTx[4]=ReadUSART();
MensajeTx[5]=ReadUSART();
MensajeTx[6]=ReadUSART();
EEPROM_WRITE(0X01,CaracterRx);
while(BusyUSART());
CaracterRx=EEPROM_READ(0X01);
WriteUSART(CaracterRx);*/
for(k=0;k<7;k++){
while(BusyUSART());
WriteUSART(MensajeTx[k]);
PIR1bits.RCIF = 0; //Desactivamos la bandera de recepción en el buffer de entrada del USART
return;
}ya le inclui un return. pero sigue igual, alguna sugerencia?
Cada ves que entra a la interrupcion es que recibio 1 solo caracter o letra. por lo cual no deberias tener TANTOS readusar o getsusart
Con un solo ReadUsart, y tener una variable que le vaya indicando donde guardarlo seria lo correcto
MensajeTx[j]=ReadUSART();
j++;
if( j>6){j=0;}
Entonces la primera ves que entra guarda en MensajeTx[0], la segunda en MensajeTx[1] y asi hasta 6, luego de ahi pasa nuevamente a 0
se te reinicia el WDG por todo el código que pusiste adentro de la rutina de interrupcion...
no se alcancer anotar que esa parte del código donde lee varias veces esta marcada como comentario, incluso lo de la eeprom, sin embargo probare tu sugerencia amigo killerjc
Lo mas seguro es que sea lo que dice elgarbe, desactiva el WDT
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
Y con respecto a los comentarios estan mal, por que es /* */ y vos tenes /* /* no se ni como puede compilar eso.
el problema ya lo solucione amigo, el wat necesito que este encendido y compila por que aunque viste el /* mas abajo estaba cerrado correctamente
no es una buena práctica de programación tener tanto código en las interrupciones. y menos que menos un while que se queda trabado (while(busyUsart)). estudiate como implementar una máquina de estados comandad por interrupciones. vas a ver que te va a reducir infinitamente la fuente de errores, y ni hablar que es mucho muhco más legible.
