typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define FLASH_PAGE_SIZE ((uint32_t)0x00000400) /* FLASH Page Size */
#define FLASH_USER_START_ADDR ((uint32_t)0x08006000) /* Start @ of user Flash area */
#define FLASH_USER_END_ADDR ((uint32_t)0x08007000) /* End @ of user Flash area */
#define DATA_32 ((uint32_t)0x12345678)
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint32_t EraseCounter = 0x00, Address = 0x00;
uint32_t Data = 0x3210ABCD;
uint32_t NbrOfPage = 0x00;
__IO FLASH_Status FLASHStatus = FLASH_COMPLETE;
__IO TestStatus MemoryProgramStatus = PASSED;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f0xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f0xx.c file
/* Unlock the Flash to enable the flash control register access *************/
FLASH_Unlock();
/* Erase the user Flash area
(area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/
/* Clear pending flags (if any) */
FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPERR);
/* Define the number of page to be erased */
NbrOfPage = (FLASH_USER_END_ADDR - FLASH_USER_START_ADDR) / FLASH_PAGE_SIZE;
/* Erase the FLASH pages */
for(EraseCounter = 0; (EraseCounter < NbrOfPage) && (FLASHStatus == FLASH_COMPLETE); EraseCounter++)
if (FLASH_ErasePage(FLASH_USER_START_ADDR + (FLASH_PAGE_SIZE * EraseCounter))!= FLASH_COMPLETE)
/* Error occurred while sector erase.
User can add here some code to deal with this error */
while (1)
/* Program the user Flash area word by word
Address = FLASH_USER_START_ADDR;
while (Address < FLASH_USER_END_ADDR)
if (FLASH_ProgramWord(Address, DATA_32) == FLASH_COMPLETE)
Address = Address + 4;
else
/* Error occurred while writing data in Flash memory.
while (1)
/* Lock the Flash to disable the flash control register access (recommended
to protect the FLASH memory against possible unwanted operation) *********/
FLASH_Lock();
/* Check if the programmed data is OK
MemoryProgramStatus = 0: data programmed correctly
MemoryProgramStatus != 0: number of words not programmed correctly ******/
Data = *(__IO uint32_t *)Address;
if (Data != DATA_32)
MemoryProgramStatus = FAILED;
/* Infinite loop */
while (1)
