Microcontroladores PIC => Lenguaje C para microcontroladores PIC => Mensaje iniciado por: vicente5 en 06 de Febrero de 2003, 16:53:00
Título: ds1307
Publicado por: vicente5 en 06 de Febrero de 2003, 16:53:00
Hola, estoy buscando desesperadamente el driver para controlar el ds1307. yo uso el ccs, y que he intentado hacerme yo uno para poder manejar el susodicho reloj paro no me funciona.
Título: RE: ds1307
Publicado por: pacalaconcurso en 07 de Febrero de 2003, 02:13:00
espero que esto te ayude...
// ds1307.c -- Functions for the Dallas Semiconductor DS1307
// real time clock and NVRAM chip.
// The DS1307 uses BCD as its internal format, but we use it
// in binary format, outside of this module. So we have code
// to convert to/from BCD to binary in the functions below.
// Set the date and time.
The registers inside the ds1307 are in this format. The values are in BCD.
DS1307_SECONDS_REG 0
DS1307_MINUTES_REG 1
DS1307_HOURS_REG 2
DS1307_DAY_OF_WEEK_REG 3 // We don"t use this register. Set it to 0.
DS1307_DATE_REG 4
DS1307_MONTH_REG 5
DS1307_YEAR_REG 6
void ds1307_set_date_time(void)
char i;
// Convert the binary ds1307 data, which is passed in a global array,
// into bcd data. Store it in the same array.
for(i = 0; i "less than" 7; i++)
gca_ds1307_regs = bin2bcd(gca_ds1307_regs);
// There are two control bits embedded in the following data.
// The Clock Halt bit is in bit 7 of the DS1307 Seconds register.
// We need to make sure that it"s = 0, to make the clock run.
// The other bit is the 24/12 hour clock format bit, in bit 6 of
// the DS1307 Hours register. We need 24 hour mode, so set it = 0.
gca_ds1307_regs[DS1307_SECONDS_REG] &= 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] &= 0x3f;
// Now write the 7 bytes of BCD data to the ds1307, using inline code for speed.
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(DS1307_I2C_WRITE_ADDR);
i2c_write(DS1307_SECONDS_REG); // Start writing at the seconds reg
// Write 7 bytes, to registers 0 to 6.
i2c_write(gca_ds1307_regs);
// After setting the time in registers 0-6, also set the Control register. (index = 7)
// This just turns off the squarewave output pin. Doing it here, every time
// we set the clock registers, seems less risky than setting it near the
// start of the program, every time the unit powers-up.
i2c_write(DS1307_CONTROL_REG_INIT_VALUE);
i2c_stop();
enable_interrupts(GLOBAL);
// Read the date and time.
// The registers inside the ds1307 are in this order. The values inside the
// registers are in BCD.
// DS1307_SECONDS_REG_ADDR 0
// DS1307_MINUTES_REG_ADDR 1
// DS1307_HOURS_REG_ADDR 2
// DS1307_DAY_OF_WEEK_REG_ADDR 3
// DS1307_DATE_REG_ADDR 4
// DS1307_MONTH_REG_ADDR 5
// DS1307_YEAR_REG_ADDR 6
// We return the data in a global array. The data in is binary.
// seconds // 0-59 seconds
// minutes // 0-59 minutes
// hours // 0-23 hours
// day_of_week // 1-7
// date // 1-31 date
// month // 1-12 month
// year // 00-99 year (based on year 2000)
void ds1307_read_date_time(void)
char i;
i2c_start();
i2c_write(DS1307_SECONDS_REG); // Start reading at the Seconds reg
i2c_start();
i2c_write(DS1307_I2C_READ_ADDR);
// Read the 7 bytes from the ds1307. Mask off unused bits.
gca_ds1307_regs[DS1307_SECONDS_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_MINUTES_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG] = i2c_read() & 0x07;
gca_ds1307_regs[DS1307_DATE_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_MONTH_REG] = i2c_read() & 0x1f;
gca_ds1307_regs[DS1307_YEAR_REG] = i2c_read(0); // No ACK on last byte
i2c_stop();
// Now convert the data from BCD to binary. Do it after reading the bytes,
// so that the i2c reads can be done quickly.
gca_ds1307_regs = bcd2bin(gca_ds1307_regs);
// Read one byte at the specified address.
// This function is used to access the control byte or the NVRAM bytes.
char ds1307_read_byte(char addr)
char retval;
i2c_start();
i2c_write(addr);
i2c_start();
retval = i2c_read(0); // We"re only reading a single byte, so no ACK on it.
i2c_stop();
return(retval);
// Write one byte to the DS1307.
void ds1307_write_byte(char addr, char value)
i2c_start();
i2c_write(addr);
i2c_write(value);
i2c_stop();
// This function converts an 8 bit binary value to an 8 bit BCD value.
// The input range must be from 0 to 99.
char bin2bcd(char binary_value)
char temp;
char retval;
temp = binary_value;
retval = 0;
while(1)
// Get the tens digit by doing multiple subtraction of 10 from the binary value
if(temp "greater than or equal to" 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
break;
return(retval);
// This function converts an 8 bit BCD value to an 8 bit binary value.
// The input range must be from 00 to 99.
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
temp "shift right"= 1; // Shifting upper digit right by 1 is same as mult. by 8
temp &= 0x78; // Isolate the bits for the upper digit
// Now return: (Tens *8) + (Tens *2) + Ones
return(temp + (temp "shift right" 2) + (bcd_value & 0x0f));
This is the "include" file that goes with the above C file.
// ds1307.h
// i2c addresses
#define DS1307_I2C_WRITE_ADDR 0xd0
#define DS1307_I2C_READ_ADDR 0xd1
// DS1307 register offsets
#define DS1307_SECONDS_REG 0
#define DS1307_MINUTES_REG 1
#define DS1307_HOURS_REG 2
#define DS1307_DAY_OF_WEEK_REG 3
#define DS1307_DATE_REG 4
#define DS1307_MONTH_REG 5
#define DS1307_YEAR_REG 6
#define DS1307_CONTROL_REG 7
#define DS1307_DATE_TIME_BYTE_COUNT 7 // includes bytes 0-6
#define DS1307_NVRAM_START_ADDR 8
// We disable the SQWV output, because it uses a lot of battery current
// when it"s enabled.
#define DS1307_CONTROL_REG_INIT_VALUE 0x80 // Disable SQWV, set Out = O.C.
//#define DS1307_CONTROL_REG_INIT_VALUE 0x13 // 32.768 KHz output
// GLOBAL VARIABLES
// This is a global array to hold data which is passed to/from the
// functions that set the ds1307 date and time.
char gca_ds1307_regs[DS1307_DATE_TIME_BYTE_COUNT];
// FUNCTION PROTOTYPES
void ds1307_set_date_time(void);
void ds1307_read_date_time(void);
void ds1307_write_byte(char addr, char value);
char ds1307_read_byte(char addr);
char bin2bcd(char binary_value);
char bcd2bin(char bcd_value);
Título: RE: ds1307
Publicado por: vicente5 en 08 de Febrero de 2003, 17:48:00
gracias por tu ayuda pero esto no me funciona, necesito una ayuda para torpes, el micro que utilizo es un 16f876 y el ccs.
Título: RE: ds1307
Publicado por: pikman en 01 de Junio de 2003, 18:14:00
Hola, bueno como esta el ejemplo ni intenten usarlo pues tiene varios errores que no se si han sido colocados con fines educativos ,pero como esta no sirve, pero se puede arreglar, pero no es para torpes,
Ariel
Título: RE: ds1307
Publicado por: en 03 de Junio de 2003, 15:58:00
hola pikman, ¿tienes el driver ? te agradeceria que me lo facilitaras. gracias.
