Microcontroladores PIC => Todo en microcontroladores PIC => Mensaje iniciado por: oscarec60 en 07 de Marzo de 2006, 07:38:00
Título: porfavor digame el error en este codigo del 18f4620
Publicado por: oscarec60 en 07 de Marzo de 2006, 07:38:00
este codigo es para utilizar a una pantalla LCD con el 18f4620 pero por alguna razón que desconosco no se porque no hace lo que dice, ayundeme por favor....
#include "P18f4620.INC" ;Include header file
#define CLK_FREQ   D"20000000"
indf    equ     0h
tmro    equ     1
pc      equ     2
fsr     equ     4
RP0   equ   13
r0c     equ     0ch
r0d     equ     0dh
r13     equ     13h
z       equ     2h
c       equ     0h
w       equ     0h
r       equ     1h
e       equ     1h
rs      equ     0h
siete   equ   7h
        org     0
        goto    inicio
        org     20
retardo movlw   0ffh
        movwf   r13
decre   decfsz  r13,r
        goto    decre
        retlw   0
control bcf     PORTA,rs
        goto    dato2
dato    bsf     PORTA,rs
dato2   bsf     PORTA,e
        movwf   PORTD
        call    retardo
        bcf     PORTA,e
        call    retardo
        retlw   0
tabla2  addwf   pc,r
        retlw   "O"
        retlw   "S"
        retlw   "C"
        retlw   "A"
        retlw   "R"
        retlw   " "
        retlw   "C"
        retlw   "."
        retlw   " "
        retlw   "E"
        retlw   "L"
        retlw   " "
        retlw   "M"
        retlw   "E"
        retlw   "J"
        retlw   "O"
        retlw   "R"
        retlw   " "
        retlw   "P"
        retlw   "R"
        retlw   "O"
        retlw   "G"
        retlw   "R"
        retlw   "A"
        retlw   "M"
        retlw   "A"
        retlw   "D"
        retlw   "O"
        retlw   "R"
        retlw   " "
        retlw   "D"
        retlw   "E"
        retlw   " "
        retlw   "P"
        retlw   "I"
        retlw   "C"
        retlw   """
        retlw   "S"
        retlw   " "
        retlw   " "
        retlw   " "
        retlw   " "
        retlw   " "
        retlw   " "
   retlw   0
inicio    clrf   PORTA
   clrf   TRISA      ; Port A all input
   clrf   PORTB
   setf   TRISB      ; Port B all input, ATA D0-7
   clrf   PORTC
   movlw   B"11100000"   ; Port C lower bits for ATA adressing
   movwf   TRISC
   ;movlw   B"00000111"   ; Turn off comparitor
   ;movwf   CMCON      ; On PORTD bits 0-3
   clrf   PORTD
   clrf   TRISD      ; Port D all output, ATA D8-15
   movlw   B"00000011"
   movwf   PORTE
   movlw   B"00000100"   ; Port E lower two bits output for ATA
   movwf   TRISE      ; read and write
   bsf   T0CON,siete
begin   movlw   30h
        call    control
        movlw   07h
        call    control
        movlw   0ch
        call    control
muestra movlw   0
        movwf   r0c
ciclo   movf    r0c,w
        call    tabla2
        call    dato
        movlw   09fh
        movwf   r0d
reta1   call    retardo
        ;call    retardo
        ;call    retardo
   call    retardo
   decfsz  r0d,r
        goto    reta1
        incf    r0c,r
        movlw   28h
        xorwf   r0c,W
        btfss   STATUS,Z
   goto   ciclo
        goto    muestra
        end
Título: RE: porfavor digame el error en este codigo del 18f4620
Publicado por: poi5on en 07 de Marzo de 2006, 10:44:00
Hola, asi es muy dificil!locoloco di lo que hace, lo que no hace, para que sirve, los errores al compilar (si los tiene)
Publicado por: oscarec60 en 07 de Marzo de 2006, 11:55:00
ok entiendo, bueno no tiene errores comunica al pic con una LCD de 16*2, este codigo lo utilice para el pic16f84a lo pase para el pic18f4620 pero realmente no se que tiene el codigo que no enciende la pantalla LCD a ambas simulaciones se hicieron en proteus a 4MHz. esa es la ayuda que les pido....
Publicado por: poi5on en 07 de Marzo de 2006, 16:15:00
chequea la declaración de los puertos, no deberias pasarte al banco 1 para declararlos? o simplemente con esas instrucciones basta? si estas trabajando a 20MHz creo que le estas dando muy poco retardo a la LCD para q trabaje.
Salu2
Publicado por: maunix en 07 de Marzo de 2006, 16:50:00
Escrito originalmente por poi5on
Salu2
No, no hace falta cambiarse de página para setear los TRIS o los PORT.. registers.
En los 18 los registros de uso comun como el Tris, portA, etc,  estan todos en la última porción de memoria pero es una región "unbanked" que se puede acceder desde cualquier página de RAM.
Publicado por: oscarec60 en 08 de Marzo de 2006, 08:56:00
Gracias, pero todavia no consigo que es lo que tiene el codigo de malo? por favor alguna ayuda...
