Autor Tema: Grabadora de sonido  (Leído 7931 veces)
Desconectado churrinfunflais
Re: Grabadora de sonido
« Respuesta #15 en: 03 de Julio de 2012, 12:46:10 »
estoy pensando en que se puede resolver algo parceido a esto...
void RecMic(void) {
    unsigned int* data;
    unsigned int i;
    FSFILE *logFile;
    BOOL initResults;
    WORD_VAL ADCResult;
    BYTE printData[6];
    WORD_VAL w;
    //set the data pointer for the FSfwrite function
    data = &i;
    initResults = FSInit();
    //initialize the A/D
    mInitMIC();
    //Set up the LED as output
    mInitAllLEDs();
    //Set the push button input
    mInitSwitch2();
    //The log file is not open so let's make sure the pointer is NULLed out
    logFile = NULL;
    while (TRUE) {
        if (initResults == TRUE) {
            if (sw2 == 1) {
                if (logFile != NULL) {
                    // Get an ADC sample
                    mInitMIC();
                    ADCON0bits.GO = 1;// Start AD conversion
                    while (ADCON0bits.NOT_DONE); // Wait for conversion
                    w.v[0] = ADRESL;
                    sample = ADPCMENcoder((w.v[0] >> 4)&0x0f, &state);
                    mInitMIC();
                    ADCON0bits.GO = 1; // Start AD conversion
                    w.v[1] = ADRESH;
                    sample = ADPCMEncoder((w.v[1] >> 8)&0x0f, &state);
                    sprintf((char*) &printData[0], "%d\r\n", sample.Val);
                    FSfwrite((const void*) &printData[0], 1, sizeof (printData), logFile);
                } else {
#if defined(__18CXX)
                    logFile = FSfopenpgm("log.csv", "w");
#endif
                mLED_1_On();
            } else {
                    FSfclose(logFile);
                    logFile = NULL;
                mLED_1_Off();
        } else {
            if (MDD_SDSPI_MediaDetect() == TRUE) {
    } //end while
#if !defined(__18CXX)
    return 0;
#endif
Estoy utilizando un 18F8722, 4Mhz Xtal, SD Card atached to the SPI ports, the Microchip Memory Disk Drive File System.
Que piensan... dejen sus comentarios...
Saludos.....
