Autor Tema: Simular con Proteus 6.6SP1, y PicBasicPro :X  (Leído 3454 veces)
Desconectado zorro31
« en: 16 de Febrero de 2006, 15:00:00 »
Holas amigos, soy nuevo por aqui, estuve revisando como hacer mis primeras simulacion con PRoteus para el 16f84, segui dos tutoriales, pero nada de nada
http://www.frino.com.ar/proteus.htm y http://www.gratisweb.com/yoelocmin/proteus/Proteus.chm, pero con ninguno me sale, el error que sale al simular es el siguiente:
Compiling source files...
Processing C:Archivos de programaMecaniqueMCSSamplesLED.ASM...
up to date.
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [13280CC5]...
PROSPICE Release 6.6 SP0 (C) Labcenter Electronics 1993-2002.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
ERROR: [U1] mixed model PIC16.DLL failed to authorize - Product Key not found.
Net VDD taken as alias for VCC
Net VSS taken as alias for GND
Reading SPICE models...
Loading library "LINTEC.SML"
Loading library "FAIRCHLD.SML"
Loading library "NATOA.SML"
Loading library "TECCOR.SML"
Loading library "TEX101.SML"
Loading library "TEX3_1.SML"
Loading library "TEX301.SML"
Loading library "TEX401.SML"
Loading library "TEX5_1.SML"
Loading library "VALVES.SML"
Loading library "ZETEX.SML"
Loading library "SUPERTEX.SML"
Loading library "ANALOGD.SML"
Loading library "APEX.SML"
Loading library "BURRBROWN.SML"
Loading library "ELANTEC.SML"
Loading library "INTERSIL.SML"
Building circuit...
Added GEARTH resistor for net #00000.
Added GEARTH resistor for net #00001.
Added GEARTH resistor for net #00002.
Added GEARTH resistor for net #00003.
Added GEARTH resistor for net #00004.
Added GEARTH resistor for net #00005.
Added GEARTH resistor for net #00006.
Added GEARTH resistor for net #00007.
Added GEARTH resistor for net #00008.
Instantiating SPICE models...
Warning: Error Unknown parser error code parsing property VALUE of PR_+5 V
Warning: [PR_+5 V] Value expected for property "VALUE" in "PR_+5 V"
Real Time Simulation failed to start
Simulation FAILED due to fatal simulator errors.
Espero me puedan  ayudar porque ya me estoy volviendo loco, jejje
Gracias de antemanooo
Desconectado LordLafebre
    • Micros & micros
RE: Simular con Proteus 6.6SP1, y PicBasicPro :X
« Respuesta #1 en: 16 de Febrero de 2006, 16:14:00 »
Hola:
Pues al ver esto:
Debe ser porque la libreria este dañada, o es un demo que intentaste "arreglarle" con el condimento incorrecto...
Espero no estar equivocado...
« Respuesta #2 en: 17 de Febrero de 2006, 15:10:00 »
Gracias, mmm, voy a probar instalandolo de nuevo, y bajar otro crack. so
JoseCarls
