Autor Tema: Proteus y RTOS  (Leído 3065 veces)
Proteus y RTOS
« en: 12 de Febrero de 2006, 01:19:00 »
No soy muy amigo de Proteus, pero andaba probando una cosa en el simulador y me hace algo extraño que no comprendo.
Lo publico por si es uno de los clásicos errores de Proteus, o por el contrario, es que estoy haciendo algo mal.
Lo que estoy probando es los ejemplos de RTOS que vienen en el CCS. Concretamente, el ejemplo ex_rtos_demo_tasks.c que es primero de los que hay y que pego a continuación:
Codigo:
////                     ex_rtos_demo1_tasks.C                       ////
////  This file demonstrates how to use the ral time operating       ////
////  system to schedule tasks and how to use the rtos_run function  ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#include <18F452.h>
#use delay(clock=4000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
// this tells the compiler that the rtos functionality will be needed, that
// timer0 will be used as the timing device, and that the minor cycle for
// all tasks will be 100 miliseconds
#use rtos(timer=0,minor_cycle=100ms)
// each function that is to be an operating system task must have the #task
// preprocessor directive located above it.
// in this case, the task will run every second, its maximum time to run must
// be less than or equal to the minor cycle, and there is no need for a
// queue at this point, so no memory will be reserved.
#task(rate=1000ms,max=100ms)
// the function can be called anything that a standard function can be called
void The_first_rtos_task ( )
   printf("1
#task(rate=500ms,max=100ms)
void The_second_rtos_task ( )
   printf("   2!
#task(rate=100ms,max=100ms)
void The_third_rtos_task ( )
   printf("      3
// main is still the entry point for the program
void main ( )
   // rtos_run begins the loop which will call the task functions above at the
   // schedualed time
   rtos_run ( );
El problema es que cuando simulo paso a paso, al llegar a la única instrucción del main, rtos_run() el programa se reinicia.
¿Alguien tiene solución?
Desconectado pocher
RE: Proteus y RTOS
« Respuesta #1 en: 12 de Febrero de 2006, 05:28:00 »
No te lo he provado Nocturno, porque no sé lo que tiene que hacer el programa. ¿Sabes como va y para qué sirve?
RE: Proteus y RTOS
« Respuesta #2 en: 12 de Febrero de 2006, 07:04:00 »
Pues precísamente lo que quiero averiguar es cómo funciona el RTOS, pero intuyo que va compartiendo el tiempo de proceso entre las tres tareas que vienen identificadas, y en cada una de ellas hay un printf diferente, por lo que en el Virtual Terminal deben ir apareciendo cosas.
El problema es que el programa se reinicia al llegar al rtos_run()
Desconectado vszener
RE: Proteus y RTOS
« Respuesta #3 en: 12 de Febrero de 2006, 07:28:00 »
Buenas!!!cuando dices que se reinicia a que te refieres, ¿a que sale del modo debug y pasa a la simulacion normal?
Si es asi, deberas tener cuidado en el procedimiendo del debug paso a paso, ya que si no recuerdo mal, la ventanita del debug paso a paso sale el codigo en c y arriba los iconitos para su debug, el primero es instruccion por instruccion y el siguiente iconito es para entrar en una funcion y el siguiente es para salir de una funcion, vamos en inconito donde sale una flechipa para abajo es para entrar en la funcion, y en este caso es a donde tienes que pulsarlo....
Suerte!!!Giño
· Nos vemos en los bares!!!!!
· Mi Blog: Aqueronte
RE: Proteus y RTOS
« Respuesta #4 en: 12 de Febrero de 2006, 07:36:00 »
No, me refiero a que salta a la primera instrucción del programa, sin cerrarse la ventanita del debug. Evidentemente yendo paso a paso es como veo dicho salto.
