Autor Tema: Direccionamiento INDIRECTO EN Proteus  (Leído 2399 veces)
Desconectado Y@el
« en: 21 de Octubre de 2005, 00:32:00 »
Hola, amigos, estoy haciendo un ckto, y el detalle esta en que si modifico un valor de forma indirecta. Se cierra Proteus Enfurruñado, no tengo ni la más minima idea de a que pueda deberse.
SIMULATION LOG
Design:   E:yoelpruebaslcktoINDF.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  19/10/05
Modified: 21/10/05
Compiling source files...
Processing panel.COD...
CODDDX panel.COD
CODDDX.EXE version 1.00 built on May 18 2001 at 16:42:13.
Processing file "panel.COD" to "panel.sdi"...
Done - 1390 lines written.
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [BFA9ABAD]...
Animation started sucessfully...
PROSPICE Release 6.7 SP0 (C) Labcenter Electronics 1993-2005.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Loading library "ANALOGD.SML"
Loading library "APEX.SML"
Loading library "BURRBROWN.SML"
Loading library "ELANTEC.SML"
Loading library "INTERSIL.SML"
Loading library "LINTEC.SML"
Loading library "FAIRCHLD.SML"
Loading library "NATOA.SML"
Loading library "TECCOR.SML"
Loading library "TEX101.SML"
Loading library "TEX3_1.SML"
Loading library "TEX301.SML"
Loading library "TEX401.SML"
Loading library "TEX5_1.SML"
Loading library "VALVES.SML"
Loading library "ZETEX.SML"
Loading library "SUPERTEX.SML"
Building circuit...
Instantiating SPICE models...
[U1] PIC16 model release 6.7 SP0 simulating PIC1684 device.
[U1] Loaded 64 bytes of persistent EEPROM data.
[U1] Loading HEX file "panel.HEX".
[U1] Read total of 892 bytes from file "panel.HEX".
[U1] Loaded 439 program words and 0 data bytes.
[U1] Dump of PIC1684 configurarion word:
[U1] Confguration word is 0x3FF9 (0b11111111111001).
[U1] Oscillator Type.......................(FOSC): XT
[U1] Watchdog Timer Enabled................(WDTE): No
[U1] Power-up Timer Enabled...............(PWRTE): No
[U1] Flash Program Memory Code Protected....(CPx): No
[U1] Note that some settings may be ignored according to model debug properties.
[SPICE] Error 106 - TRAN:  Timestep too small; time = 4.71466, timestep = 1.11022e-016: trouble with node "#00019"
Real Time Simulation FAILED.
Desconectado Y@el
RE: Direccionamiento INDIRECTO EN Proteus
« Respuesta #1 en: 01 de Noviembre de 2005, 09:35:00 »
Parece, que solo no aparece en tiempo de depuracion, ya q en ejecucion, si se muestra lo deseado....
bueno felizmente si simulo lo que deseaba. Si alguno tiene este mismo problema, paseme la oz, y haber q podemos hacer.... Muchas risas
bye
