Autor Tema: uppic  (Leído 3651 veces)
Desconectado jjlopez
uppic
« en: 11 de Febrero de 2003, 07:25:00 »
alguien sabe ke es este error en proteus
must specify file extension for program property
me lo da al iniciar la simulacion
Desconectado angelmoi123
    • Construccion de Maquinas CNC
RE: uppic
« Respuesta #1 en: 11 de Febrero de 2003, 08:02:00 »
Jjlopez,  saludos
pudieras ser mas explicito, que especificamente estas haciendo ?
angelmoi123
RE: uppic
« Respuesta #2 en: 12 de Febrero de 2003, 19:58:00 »
cargo el esquema pulso empezar la simulacion y aparece lo siguiente:
SIMULATION LOG
Design:   Control de Acceso
Doc. no.: 100
Revision: 1.0
Author:   Uppic & Javione
Created:  04/02/03
Modified: 12/02/03
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
WARNING [ROOT10] : Parameter <STATE> not defined in STATE of R1.
WARNING [ROOT10] : Parameter <STATE> not defined in STATE of R2.
WARNING [LINKER] : Unresolved module pin "U2_SCK".
WARNING [LINKER] : Unresolved module pin "U2_SDA".
WARNING [LINKER] : Unresolved module pin "U2_WP".
WARNING [LINKER] : Unresolved module pin "U2_A0".
WARNING [LINKER] : Unresolved module pin "U2_A1".
WARNING [LINKER] : Unresolved module pin "U2_A2".
WARNING [LINKER] : Unresolved module pin "U3_SCK".
WARNING [LINKER] : Unresolved module pin "U3_SDA".
WARNING [LINKER] : Unresolved module pin "U3_WP".
WARNING [LINKER] : Unresolved module pin "U3_A0".
WARNING [LINKER] : Unresolved module pin "U3_A1".
WARNING [LINKER] : Unresolved module pin "U3_A2".
WARNING [LINKER] : Unresolved module pin "U3_VCC".
WARNING [LINKER] : Unresolved module pin "U2_VCC".
WARNING [LINKER] : Unresolved module pin "U4_VI".
WARNING [LINKER] : Unresolved module pin "U4_VO".
WARNING [LINKER] : Unresolved module pin "U4_GND".
WARNING [LINKER] : Unresolved module pin "U5_VI".
WARNING [LINKER] : Unresolved module pin "U5_VO".
WARNING [LINKER] : Unresolved module pin "U5_GND".
WARNING [LINKER] : Unresolved module pin "U3_GND".
WARNING [LINKER] : Unresolved module pin "U2_GND".
Partition analysis...
Simulating partition 1 [748CEE39]...
Animation started with warnings...
PROSPICE Release 5.20.06 (C) Labcenter Electronics 1993-2001.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Warning: Model LX_BRIDGE specified but not found in BR1.
Net VDD taken as alias for VCC
Net VSS taken as alias for GND
Reading SPICE models...
Loaded SPICE model "BC547BP" from library "ZETEX"
Building circuit...
Added GEARTH resistor for net #00123.
Added GEARTH resistor for net #00124.
Added GEARTH resistor for net #00085.
Added GEARTH resistor for net #00086.
Added GEARTH resistor for net #00087.
Added GEARTH resistor for net #00088.
Added GEARTH resistor for net #00089.
Added GEARTH resistor for net #00090.
Added GEARTH resistor for net #00106.
Added GEARTH resistor for net #00107.
Added GEARTH resistor for net #00108.
Added GEARTH resistor for net #00109.
Added GEARTH resistor for net #00152.
Added GEARTH resistor for net #00153.
Added GEARTH resistor for net #00155.
Added GEARTH resistor for net #00157.
Added GEARTH resistor for net #00158.
Added GEARTH resistor for net #00160.
Instantiating SPICE models...
[U1] PIC16 model release 5.20.06 (IR1) simulating PIC16876 device.
[U1] Loaded 256 bytes of persistent EEPROM data.
ERROR: [U1] Must specify file extension for PROGRAM property.
[U1] Loaded 0 program words and 0 data bytes.
[DSIM] BOOT Error.
Real Time Simulation failed to start
Real Time Simulation FAILED.
si pudieras echarme un cable te lo agradeceria
Salu2
RE: uppic
« Respuesta #3 en: 13 de Febrero de 2003, 12:11:00 »
Estimado amigo Jjlopez.
Ayudaria bastante si envias el diseño, te comento que en proteus hay varios modelos que no funcionan, por  su puesto depende de la version que tengas, en mi caso solo funcionan los componentes activos, pasivos y algunos de los microcontroladores.
angelmoi123
