Autor Tema: Notas de Aplicación AVRs  (Leído 4694 veces)
« en: 05 de Junio de 2006, 21:19:42 »
Publico un buen link para encontrar subrutinas y tips para usar los AVRs.
http://atmel.com/dyn/products/app_notes.asp?family_id=607
Entre las interesantes están:
AVR000: Register and Bit-Name Definitions for the AVR Microcontroller
AVR033: Getting Started with the CodeVisionAVR C Compiler
AVR035: Efficient C Coding for AVR
AVR042: AVR Hardware Design Considerations
AVR064: STK502 - A Temperature Monitoring System with LCD Output
AVR072: Accessing 16-bit I/O Registers
AVR100: Accessing the EEPROM
AVR103: Using the EEPROM Programming Modes
AVR107: Interfacing AVR serial memories
AVR121: Enhancing ADC resolution by oversampling
AVR128: Setup and use the Analog Comparator
AVR130: Setup and use the AVR Timers
AVR131: Using the AVR’s High-speed PWM
AVR132: Using the Enhanced Watchdog Timer
AVR133: Long Delay Generation Using the AVR Microcontroller
AVR135: Using Timer Capture to Measure PWM Duty Cycle
AVR182: Zero Cross Detector
AVR200: Multiply and Divide Routines
AVR201: Using the AVR Hardware Multiplier
AVR202: 16-Bit Arithmetics
AVR204: BCD Arithmetics
AVR220: Bubble Sort
AVR240: 4x4 Keypad-Wake Up on Keypress
AVR242: 8-bit Microcontroller Multiplexing LED Drive & a 4x4 Keypad.
AVR243: Matrix Keyboard Decoder
AVR273: USB Mass Storage Implementation
AVR304: Half Duplex Interrupt Driven Software UART
AVR305: Half Duplex Compact Software UART
AVR314: DTMF Generator
AVR401: 8-Bit Precision A/D Converter
AVR410: RC5 IR Remote Control Receiver
AVR411: Secure Rolling Code Algorithm for Wireless Link
AVR450: Battery Charger for SLA, NiCd, NiMH and Li-ion Batteries
AVR465: Energy Meter
