Autor Tema: Ya tengo nuevo juguete : El Tibbo EM T1000, La Bestia  (Leído 18067 veces)
Desconectado RedPic
    • Picmania by Redraven
« en: 01 de Febrero de 2007, 10:52:22 »
Tibbo Taiwan
TiOS (Tibbo Operating System)
TIDE (Tibbo Integrated Development Environment)
The EM1000 is a BASIC-programmable Ethernet Module for onboard installation. Module hardware includes:
• High-performance (88MIPS) RISC processor.
• One 100BaseT Ethernet port (standard Ethernet magnetics are NOT integrated into the Module).
• Support for UDP(1), TCP(1), ICMP (ping)(1), DHCP(1), and HTTP(1) protocols; up to 16 simultaneous UDP or TCP(HTTP) connections(1). Additional protocols, such as SMTP, can be implemented in your BASIC application.
• Four high-speed serial ports (CMOS-level) that can work in UART, Wiegand(1), and clock/data(1) modes.
• UART baudrates can be up to 1'382'400bps; none/even/odd/mark/space parity and 7/8 bits/character UART modes available; full-duplex UART mode with optional flow control(1) and half-duplex UART mode with automatic direction control(1) supported. TX(2), RX(2), RTS(1), CTS(1), DTR(1), DSR(1) and DCD(1) lines provided.
• 49 general-purpose I/O lines (this count includes lines of all four serial ports).
• Eight interrupt lines which can be triggered on positive or negative transition on the line.
• Programmable square wave generator (6Hz - 22'1184MHz) that can be used to control buzzer.
• 512KBytes of FLASH memory. 64KB are used to store device firmware (TiOS). The rest is available to store BASIC application and data.
• 2KBytes of EEPROM memory.
• Real-time-counter (RTC) with its own backup power input.
• Optional backup supercapacitor onboard (option "-S" only).
• Onboard PLL (Phase-Locked loop) to control the clock frequency of the device: 11.0592MHz with PLL off, 88.4736MHz with PLL on.
• Reliable power-on/brown-out reset circuit, no additional external reset circuitry required.
The EM1000 is a universal module that can serve as a central building block of control equipment, data terminals, safety and security systems, etc. Its firmware, called TiOS (Tibbo Operating System), features a BASIC virtual machine that executes your application written in Tibbo BASIC.
The EM1000 has no pre-defined functionality whatsoever -- programmability in Tibbo BASIC means that you can create your own unique EM1000 application! The Module is powerful enough to be the "heart" of your system, not just a networking peripheral.
Module's firmware (TiOS), as well as BASIC programming are covered in a separate Manual ("TAIKO Manual").
In 2006Q4 Tibbo is planning to introduce a BASIC application that will turn EM1000 into a 4-port serial device server. As such, the EM1000 will be fully compatible with "fixed-firmware" device servers manufactured by Tibbo (such as the EM100). All information provided in the Device Server Application Firmware manual will apply equally to the EM1000 running this "device server" BASIC application. Naturally, this application will be compatible with the Device Server Toolkit (DST), Virtual Serial Port Driver for Linux (VSPDL), and the LinkServer.
The TiOS firmware of the EM1000 can be upgraded through the module's serial port or Ethernet port. Serial upgrades are facilitated by a so-called Monitor- a fixed "service" firmware inside the EM1000. The Monitor cannot be upgraded. Network upgrades rely on the application firmware itself- there is a self upgrade algorithm that will be detailed later.
1. This feature is actually implemented in firmware.
2. In the UART mode TX and RX lines are controlled by dedicated UART hardware, in the Wiegand and clock/data mode these pins are under the control of TiOS firmware.
« Última modificación: 01 de Febrero de 2007, 11:28:31 por RedPic »
Mi Güeb : Picmania
Desconectado aitopes
    • uControl
Re: Ya tengo nuevo juguete : El Tibbo EM T1000, La Bestia
« Respuesta #1 en: 01 de Febrero de 2007, 11:25:17 »
Impresionante!!!
Desde aca se le siente el olorcito a nuevo..... :)
“. Seymour Papert
« Respuesta #2 en: 01 de Febrero de 2007, 12:23:28 »
¡Manda güevos tú con las fotos del desembalaje!, ¡eso no se hace, abusón!
    • uControl
« Respuesta #3 en: 01 de Febrero de 2007, 12:27:15 »
Sere curioso....cuanto cuesta un juguete de esos? (ni se para que me serviria, pero vio como es uno de  curioso y jugueton!)  :D
“. Seymour Papert
Desconectado todopic
« Respuesta #4 en: 01 de Febrero de 2007, 14:25:46 »
 :D :-/ :D :-/ :D :-/  ja ja!, felicitaciones Diego! esperamos ir viendo tus avances!
Firmat - Santa Fe - Argentina
www.TodoPic.net
Desconectado jfmateos2
« Respuesta #5 en: 01 de Febrero de 2007, 15:39:24 »
Pues a mí me ha gustado ver las fotos del desembalaje; es como si lo hiciera uno en primera persona (en cierta forma se siente uno como mirando a través del escaparete de una pastelería; claro que cuando intentas acercarte demasiado te das con el cristal en las narices).
Le he echado un vistazo al "Taiko manual" y realmente parece fácil de programar.
Desconectado RedPic
« Respuesta #6 en: 01 de Febrero de 2007, 16:10:49 »
Ja, ja, ja  :D :D :D
La serie de fotografias es mayor, quitándo capa a capa todos los envoltorios, desde el papel con crácteres chino-taigüaneses que lo envolvía hasta la última con el cacharro en la mano. Solo he puesto una selección.  :mrgreen:
El invento completo, que incluye cuatro cables de conexión, dos serie y dos ethernet, cruzados y directos, mas una fuente de alimentación para La Bestia y los portes desde Taiwan hasta España por un total de 150€
Me ponen los pelos de punta los 88 MIPs, las cuatro USART de hasta ¡¡¡1.382.400bps!!!, los 512Kbytes para programas ... de La Bestia  :twisted:
Mi Güeb : Picmania
Desconectado psykhon
« Respuesta #7 en: 01 de Febrero de 2007, 22:49:14 »
se me hace agua el soldador
No, no se lo que estoy haciendo. Nadie sabe que estoy haciendo. Por eso se llama "Investigacion".
Desconectado RedPic
« Respuesta #8 en: 02 de Febrero de 2007, 02:11:34 »
ja ja ja  :D :D :D
Querras decir que se te hace flux el soldador y desliza como sobre nieve
ja ja ja  :D :D :D
Mi Güeb : Picmania
« Respuesta #9 en: 02 de Febrero de 2007, 08:09:05 »
y todavia no esta a la venta, SUERTUDO!!!
Desconectado rparerar
    • El rincon del pic
« Respuesta #10 en: 03 de Febrero de 2007, 16:42:22 »
VAYA PASADA,Y YO QUE QUIERO INICIARME CON EL SIMPLE EM100...
Desconectado LordLafebre
    • Micros & micros
« Respuesta #11 en: 09 de Febrero de 2007, 12:50:16 »
Hola:
Bueno, primero felicitar a Diego por su adquisición, y no quise abrir otro hilo sino más bien me parecería bueno que aqui podamos publicar nuestros "juguetes nuevos"  :D :D, yo tambén tendré juguete nuevo, aún no lo tengo en mis manos, pero ya esta adquirido, y aunque no es un tibbo, lo publico aqui como decía para no abrir otro hilo de juguete nuevo, no se Diego si te parece bien, o si mejor Creo otro hilo, cualquier cosa comentala por favor.
UBICACIÓN: Canadá, oficina de mi papá, no se graduó de fotógrafo  :D pero aqui les dejo unas fotos de lo que en menos de un mes llegara a mis manos y me ponré a experimentar  :D :D :mrgreen:
« Última modificación: 09 de Febrero de 2007, 12:54:41 por LordLafebre »
Desconectado RedPic
« Respuesta #12 en: 09 de Febrero de 2007, 14:54:39 »
Querido Gio, tiene usted el derecho y mi permiso para usar o abusar de este hilo tanto como le venga en gana, le parezca a usted oportuno o lo crea usted conveniente.
Y si desean los demás amigos usar este hilo para publicar sus personales jugetitos no se corten un pelo y publiquen, publiquen, que seran todos bienvenidos.
Solo recordarles una cosa que me dice siempre mi esposa: La unica cosa que diferencia un niño de un hombre es el precio del juguete. Ja, ja, ja  :D :D :D
Mi Güeb : Picmania
    • Micros & micros
« Respuesta #13 en: 09 de Febrero de 2007, 17:37:26 »
Hola:
Muchas gracias mi estimado amigo Diego  :mrgreen:
Desconectado vszener
« Respuesta #14 en: 09 de Febrero de 2007, 21:15:10 »
Lo bonito que lo ponen con su cajita y todo jeje que te diviertas con el cacharro!!! ;)
· Nos vemos en los bares!!!!!
· Mi Blog: Aqueronte
