Autor Tema: error al simular en isis  (Leído 25071 veces)
Desconectado pandarojo
« en: 17 de Mayo de 2007, 08:31:09 »
Hola a todos, pues estoy intentando probar un código basic hecho con microcode studio y me sale el siguiente log en el isis:
SIMULATION LOG
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [4568DF5F]...
PROSPICE Release 6.9 SP4 (C) Labcenter Electronics 1993-2006.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Loaded SPICE model '2N3904' from library 'FAIRCHLD'
Building circuit...
Instantiating SPICE models...
[U1] PIC16 model release 6.9 SP0 simulating PIC16876 device.
[U1] Loaded 256 bytes of persistent EEPROM data.
[U1] Loading HEX file 'contador 3 digitos.hex'.
[U1] Read total of 770 bytes from file 'contador 3 digitos.hex'.
[U1] Loaded 383 program words and 0 data bytes.
[SPICE] DELMIN increased to 8.88178e-16 due to lack of time precision
[SPICE] transient GMIN stepping at time=4.68062
[SPICE] transient GMIN stepping at time=26.2888
[SPICE] transient GMIN stepping at time=29.136
[SPICE] transient GMIN stepping at time=29.1867
[SPICE] transient GMIN stepping at time=29.2886
[SPICE] DELMIN increased to 3.55271e-15 due to lack of time precision
[SPICE] Error 106 - TRAN:  Timestep too small; time = 29.2886, timestep = 4.44089e-16: trouble with node "#00025"
Totaliters=272112, Totalsteps=68726, Goodsteps=58267, Badsteps=10459
Real Time Simulation FAILED.
¿que puede estar pasando?, soy novato en estos temas, pero con vuestra ayuda seguro que podré avanzar.
el codigo sería este:
define OSC 4
ADCON1 = 7    'PORTA entradas digitales
TRISB = %00000000
TRISC = %00000000
clear
cont var word
i    var byte
unid var byte
dece var byte
cent var byte
auxconteo var bit
detector var porta.0
reset var porta.5
motorbaja var porta.1
motorsube var porta.2
cont = 1000
auxconteo = 0
principal:
gosub contar
gosub visualizar
gosub error
goto principal
contar:
      if detector = 0 then auxconteo = 0
   if detector = 0 or auxconteo = 1 then return
    gosub visualizar 'aprovechamos para usar el ciclo de visu para antirrebote
    if motorsube = 0 and motorbaja = 1 then cont = cont + 1
    if motorbaja = 0 and motorsube = 1 then cont = cont - 1
    if cont < 1000 then cont = 1000
    auxconteo = 1
   return
visualizar:
        unid = cont dig 0
        PORTB = unid + 16
        PAUSE 50  ' valor de 50 para visualizar bien en proteus
        dece = cont dig 1
        PORTB = dece + 32
        PAUSE 50
        cent = cont dig 2
        PORTB = cent + 64
        PAUSE 50
    RETURN
error:
   if motorsube + motorbaja < 2 then return
   visuerror:
        PORTB = 8 + 16
        PAUSE 50
        PORTB = 8 + 32
        PAUSE 50
        PORTB = 8 + 64
        PAUSE 50
   if reset=0 then goto visuerror
   cont=1000
   goto principal
end
el circuito sería este, si tiene errores las sugerencias son bienvenidas:
Desconectado vszener
Re: error al simular en isis
« Respuesta #1 en: 19 de Mayo de 2007, 15:25:38 »
Entre activación de un diaplay a otro de 7-SEG deja un tiempo de espera, el ojo humano no percive el parpadeo entorno a las esperas de 10-20ms.
Suerte!!! ;)
· Nos vemos en los bares!!!!!
· Mi Blog: Aqueronte
Desconectado BrunoF
« Respuesta #2 en: 20 de Mayo de 2007, 02:11:44 »
A mi ese error me ha sucedido muchas veces. Algunas veces por algo mal en el circuito o bien completamente al azar. Tal vez si cambias de version de Proteus por una mas nueva, se solucione.
Desconectado lord_micro
« Respuesta #3 en: 20 de Mayo de 2007, 20:07:20 »
hola q tal pandarojo, de que manera has conectado los display 7 segmentos?
« Respuesta #4 en: 26 de Mayo de 2007, 05:09:19 »
Gracias por las respuestas. Ya lo he solucionado. Entiendo que era un fallo del Isis, el circuito funciona ok en la realidad.
Suerte!!! ;)
Si miras el comentario del programa, verás que le había puesto 50 ms de retardo para que se visualice bien en la simulación con mi pc, en el circuito real lo he dejado en 5ms, y va OK
Pues los he conectado sacando lo que quiero visualizar en bcd por el portB y a traves de un 4511 (conversor bcd a 7 segm) a los displays y unos bc547 para activar cada dígito con los pines portb4, 5 y 6. No sé si te referías a esto.
Ahora me propongo activar 6 dígitos con un 4511 y seleccionar cada uno con un 74ls42 (conversor de bcd a decimal), a ver si va ok.
Desconectado PalitroqueZ
    • Electrónica Didacta
« Respuesta #5 en: 26 de Mayo de 2007, 15:42:52 »
si a mi también me sucede ese fallo con mucha frecuencia, y si puedo concluir que cuando salen errores de este tipo:
es seguro que el circuito está muy sobrecargado, o no se le da tiempo suficiente para ejecutar la simulación, este error me ha salido con poner por ejemplo un operacional adicional alimentado con otra fuente, le quito el I.C. y salva el error.
Friedrich August von Hayek
