Autor Tema: Puerto série: Mando una INS y no recibo la respuesta.  (Leído 2117 veces)
Desconectado fardao
« en: 14 de Junio de 2008, 16:18:05 »
'################# CONEXION PUERTO SERIE #################
Private Sub Form_Load()
    With MSComm1
        .CommPort = 1
        .RThreshold = 1
        .RTSEnable = True
        .Settings = "9600,e,8,2"
        .PortOpen = True
    End With
    '################# TIPO DE INS A MANDAR #################
    Text1.Text = "XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX"
End Sub
Private Sub Command1_Click()
    MSComm1.Output = Hex2asc(Text1.Text)
End Sub
Function Hex2asc(SHex)
    Dim Y As Integer, Num As String, VAscii As String
    SHex = Replace(SHex, " ", "")
    For Y = 1 To Len(SHex)
        Num = Mid(SHex, Y, 2)
        VAscii = VAscii & Chr(Val("&h" & Num))
        Y = Y + 1
    Next Y
    Hex2asc = VAscii
End Function
Function Asc2hex(SAscii)
    Dim I As Integer, VHex As String
    For I = 1 To Len(SAscii)
        VHex = VHex & Right("0" & Hex((Asc(Mid(SAscii, I, 2)))), 2) & " "
    Next I
    Asc2hex = VHex
End Function
Private Sub Form_Unload(Cancel As Integer)
    MSComm1.PortOpen = False
End Sub
Private Sub MSComm1_OnComm()
    Dim InBuff As String
    Select Case MSComm1.CommEvent
        Case comEventBreak
        Case comEventCDTO
        Case comEventCTSTO
        Case comEventDSRTO
        Case comEventFrame
        Case comEventOverrun
        Case comEventRxOver
        Case comEventRxParity
        Case comEventTxFull
        Case comEventDCB
        Case comEvCD
        Case comEvCTS
        Case comEvDSR
        Case comEvRing
        Case comEvReceive
            InBuff = MSComm1.Input
            Text2.SelText = Asc2hex(InBuff)
            '################# COMO RESPUESTA SOLO RECIBO LO QUE MANDO #################
            '################# DEBERIA RECIBIR LO QUE MANDO MAS EL ESTADO ( XX XX ) #################
        Case comEvSend
        Case comEvEOF
    End Select
End Sub
