Autor Tema: joystic playstation  (Leído 3911 veces)
Desconectado gizer20
joystic playstation
« en: 30 de Octubre de 2005, 16:35:00 »
ei chicos una kosa alguien tiene el datasheet de los mini-joystick de los mandos de la play o el patillaje?
Desconectado RaDoN
RE: joystic playstation
« Respuesta #1 en: 31 de Octubre de 2005, 04:57:00 »
HeladoHeladoHeladoHeladoHeladoloco
Desconectado Nomademc
« Respuesta #2 en: 31 de Octubre de 2005, 06:46:00 »
   1  2  3   4  5  6   7  8  9
 | o  o  o | o  o  o | o  o  o |  (at the Controller)
 \___________________/
Pin     Name     Description
1    DATA    Data
2    CMD    Command
3    N/C (9 V unused)    Not connected
4    GND    Ground
5    VCC    Vcc
6    ATT    ATT select
7    CLK    Clock
8    N/C    Not connected
9    ACK    Acknowledge
Signals description:
DATA
Signal from Controller to PSX. This signal is an 8 bit serial transmission synchronous to the falling edge of clock (That is both the incoming and outgoing signals change on a high to low transition of clock. All the reading of signals is done on the leading edge to allow settling time.)
COMMAND
Signal from PSX to Controller. This signal is the counter part of DATA. It is again an 8 bit serial transmission on the falling edge of clock.
VCC can vary from 5V down to 3V and the official SONY Controllers will still operate. The controllers outlined here really want 5V. The main board in the PSX also has a surface mount 750mA fuse that will blow if you try to draw to much current through the plug (750mA is for both left, right and memory cards).
ATT is used to get the attention of the controller. This signal will go low for the duration of a transmission. I have also seen this pin called Select, DTR and Command.
CLOCK
Signal from PSX to Controller. Used to keep units in sync.
Acknowledge signal from Controller to PSX. This signal should go low for at least one clock period after each 8 bits are sent and ATT is still held low. If the ACK signal does not go low within about 60 us the PSX will then start interogating other devices.
Desconectado Milkiell
Re:joystic playstation
« Respuesta #3 en: 10 de Marzo de 2021, 22:15:24 »
Como cambian las cosas con el tiempo... no me puedo imaginar como era Internet en ese entonces xD
Y mientras aquí este hecho sigue guardado mientras el foro exista jaja. Para ahora con un simple emulador poder lograr casi lo mismo pero más fácil.
Desconectado vapj9609
    • https://tech2app.xyz/
« Respuesta #4 en: 20 de Agosto de 2021, 17:39:37 »
Ufff... al fin encontré información que realmente me sirvió jaja
Muchas gracias, aprovecho para registrarte y comenzar en esta comunidad
Gracias por el aporte  :mrgreen:
