Autor Tema: Cargar imagen libreria grafica microchip  (Leído 3078 veces)
Desconectado jnavarro
« en: 16 de Febrero de 2009, 15:54:44 »
Hola,
Estoy trabajando con la libreria grafica de microchip, y basandome en el ejemplo "Graphics Object Layer Demo" pretendo mostrar una imagen mia en la pantalla. He visto que microchip proporciona un programita apra convertir las imagenes a codigo hexadecimal pero no acabo de comprender bien su funcionamiento.
En el ejemplo que os digo, lo hacen de la siguiente manera:
asm(".section .const,psv");
extern char L1185835973[] __attribute__ ((space(prog),aligned(2)));
//BITMAP STRUCTURE. BITMAP NAME CAN BE CHANGED HERE.
const struct{short mem; char __prog__* ptr;} arrowDown =
{0,L1185835973};
asm(".section *,code");
asm(".global _L1185835973");
asm(".align 2");
asm("_L1185835973:");
asm(".byte 0x00"); //Compression
asm(".byte 0x04"); //Color depth
asm(".word 0x001A"); //Height
asm(".word 0x0012"); //Width
//COLOR TABLE
asm(".word 0x0000");
asm(".word 0x8000");
asm(".word 0x0400");
asm(".word 0x8400");
asm(".word 0x0010");
asm(".word 0x8010");
asm(".word 0x0410");
asm(".word 0x8410");
asm(".word 0xC618");
asm(".word 0xF800");
asm(".word 0x07E0");
asm(".word 0xFFE0");
asm(".word 0x001F");
asm(".word 0xF81F");
asm(".word 0x07FF");
asm(".word 0xFFFF");
//BMP IMAGE
asm(".byte 0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA");
asm(".byte 0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF");
asm(".byte 0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA");
asm(".byte 0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0x00,0x00,0xA0,0xAA,0xAA,0xAA,0x0A,0x00,0x00,0xA0,0xAA");
asm(".byte 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0x0A,0x0F,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xF0,0x0F,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xF0,0xFF,0xA0,0xAA,0xAA,0xAA,0xAA,0xAA");
asm(".byte 0x0A,0xFF,0xFF,0x0F,0xAA,0xAA,0xAA,0xAA,0xAA,0xF0,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0xAA,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0x0F");
asm(".byte 0xAA,0xAA,0xAA,0xF0,0xFF,0xFF,0xFF,0xFF,0xFF,0xA0,0xAA,0x0A,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xAA,0xF0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xAA,0xF0,0xFF,0xFF");
asm(".byte 0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF");
Con el programa de microchip no se obtiene esta estructura de codigo con esa informacion para esa imagen.
¿Alguien sabe como crear este tipo de imagenes?
__El conocimiento humano pertenece al mundo__
Desconectado ema
Re: Cargar imagen libreria grafica microchip
« Respuesta #1 en: 16 de Febrero de 2009, 16:57:42 »
Sino me equivoco se llama BITMAP2LCD y hay una version de evaluacion.
