Autor Tema: enviar datos de pc a pic.ERR  (Leído 4965 veces)
Desconectado Mind-field
« en: 20 de Mayo de 2009, 15:46:07 »
Hola buenas tardes foro ! tengo un .err y no lo se interpretar , de mas esta decir que soy pichón en assembler ! , alguien me puede dar una mano ?
Bueno esto es lo que me esta pasando
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 52 : Symbol not previously defined (RS232_LeeDatos)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 76 : Symbol not previously defined (TeclaPulsada)
Warning[207] C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 78 : Found label after column 1. (btfcs)
Error[122]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 78 : Illegal opcode (STATUS)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 81 : Symbol not previously defined (TeclaPulsada)
Warning[207] C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 83 : Found label after column 1. (btfse)
Error[122]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 83 : Illegal opcode (STATUS)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 86 : Symbol not previously defined (TeclaPulsada)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 89 : Symbol not previously defined (IZQUIERDA)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 91 : Symbol not previously defined (TeclaPulsada)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 94 : Symbol not previously defined (DERECHA)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 96 : Symbol not previously defined (TeclaPulsada)
Warning[203] C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 100 : Found opcode in column 1. (goto)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 100 : Symbol not previously defined (FIN)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 107 : Symbol not previously defined (Visualiza)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 114 : Symbol not previously defined (Visualiza)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 121 : Symbol not previously defined (Visualiza)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 127 : Symbol not previously defined (mensajeIzquierda)
Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 128 : Symbol not previously defined (Visualiza)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 64 : Symbol not previously defined (Retardo_100micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 65 : Symbol not previously defined (Retardo_50micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 71 : Symbol not previously defined (Retardo_100micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 74 : Symbol not previously defined (Retardo_200micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 99 : Symbol not previously defined (Retardo_100micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 110 : Symbol not previously defined (Retardo_100micros)
Error[113]   C:\X\MOTOR(PAP)\1\RS232.INC 114 : Symbol not previously defined (Retardo_200micros)
Error[105]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 151 : Cannot open file (Include File "RS232MEN.INC" not found)
Error[105]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 154 : Cannot open file (Include File "RETARDOS_INC.ASM" not
found)
          Que tengo que hacer ? y donde ? , estoy con un dolor de cabeza tremendo jeje  :x
Re: enviar datos de pc a pic.ERR
« Respuesta #1 en: 20 de Mayo de 2009, 16:01:56 »
Esos son los errores, pero debes publicar el archivo asm para que los podamos encontrar.
« Respuesta #2 en: 20 de Mayo de 2009, 16:08:15 »
bueno !
;SISTEMA DE GOBIERNO DESDE ORDENADOR Desde el teclado de un ordenador se desea comandar
;el movimiento de una estructura mavil, segun la siguiente tabla:
;      TECLA (Por ejemplo)       MOVIMIENTO
;              t                 Adelante
;              b                 Atrás
;              a                 Izquierda
;              l                 Derecha
;            Espacio             Parada
;El programa debe permitir modificar facilmente en posteriores revisiones en el harware de
;la salida, Es decir, para activar las salidas conviene utilizar el direccionamiento por bit
;en lugar de por byte(utilizar instrucciones "bsf" y "bcf", en lugar de "mov")
;ZONA DE DATOS***********************************************************************************
      LIST    p=16f84A
      INCLUDE <P16f84A.INC>
 __config _CP_OFF &_WDT_OFF &_PWRTE_ON &_XT_OSC
      CBLOCK 0x0c
      Teclapulsada                  ;va a guardar el contenido de la tecla pulsada.
      MensajeApuntado                  ;Va a guardar la dirección del mensaje apuntado.
      ENDC
#DEFINE SalidaAdelante         PORTB,3            ;Define dómde se situan las salidas.
#DEFINE SalidaAtras         PORTB,2
#DEFINE SalidaIzquierda         PORTB,1
#DEFINE SalidaDerecha         PORTB,0
TeclaAdelante   EQU   't'                  ;Código de las teclas utilizadas
TeclaAtras   EQU   'b'
TeclaIzquierda   EQU   'a'
TeclaDerecha   EQU   'l'
TeclaParada   EQU   ' '                  ;Código de la tecla espaciadora, (hay un espacio,
                           ;tener cuidado al teclear el programa).
;ZONA DE cÓDIGOS*************************************************************************
      ORG   0
Inicio
      ;call   LCD_Inicializa
      call   RS232_Inicializa
      bsf   STATUS,RP0               ;Configura como salida las 4 lineas del
      bcf   SalidaAdelante               ;puerto B respetando la configuracion del
      bcf   SalidaAtras               ;resto de las líneas.
      bcf   SalidaIzquierda
      bcf   SalidaDerecha
      bcf   STATUS,RP0
      call   Parado                  ;En principio todas las salidas deben estar
Principal                        ;apagadas.
      call   RS232_LeeDatos               ;Espera a recibir un carácter.
      call   TesteaTeclado
      goto   Principal
;"Mensajes"------------------------------------------------------
Mensajes
      addwf   PCL,F
MensajeParado
      DT"Sistema PARADO",0x00
MensajeAdelante
      DT"Marcha ADELANTE",0x00
MensajeAtras
      DT"Marcha ATRAS",0x00
MensajeIzquierda
      DT"Hacia IZQUIERDA",0x00
MensajeDerecha
      DT"Hacia DERECHA",0x00
;Subrutina"TesteaTeclado"----------------------------------------------
;Testea el teclado y actúa en consecuencia.
TesteaTeclado
      movwf   TeclaPulsada      ;Guarda el contenido de la tecla pulsada
      xorlw   TeclaAdelante      ;¿Es la tecla de movimiento hacia adelante?
      btfcs   STATUS,Z
      goto   Adelante      ;Si, se desea movimiento hacia adelante
      movf   TeclaPulsada,w      ;Recupera el contenido de la tecla pulsada
      xorlw   TeclaAtras      ;¿Es la tecla de movimiento hacia atras?
      btfse   STATUS,Z
      goto   Atras         ;Sí, se decea movimiento hacia atras
      movf   TeclaPulsada,W      ;Recupera el contenido de la tecla pulsada
      xorlw   TeclaIzquierda      ;¿Es la tecla del movimiento hacia la Izquierda
      btfsc   STATUS,Z
      goto   IZQUIERDA      ;Sí, se decea movimiento hacia atras
      xorlw   TeclaDerecha      ;¿Es la tecla del movimiento hacia la Derecha?
      btfsc   STATUS,Z
      goto   DERECHA         ;Sí, se decea movimiento hacia la derecha
      xorlw   TeclaParada      ;¿Es la tecla de parada?
      btfss   STATUS,Z
goto   FIN         ;No es ninguna tecla de movimiento sale
Parado
      bcf   SalidaAdelante      ;Como se a pulsado la tecla de parada se
      bcf   SalidaAtras      ;desactivan todas las salidas
      bcf   SalidaIzquierda
      bcf   SalidaDerecha
      movlw   MensajeParado
      goto   Visualiza
Adelante
      bcf   SalidaAtras
      bsf   SalidaAdelante
      bcf   SalidaIzquierda
      bcf   SalidaDerecha
      movlw   MensajeAdelante
      goto   Visualiza
Atras
      bcf   SalidaAdelante
      bsf   SalidaAtras
      bcf   SalidaIzquierda
      bcf   SalidaDerecha
      movlw   MensajeAtras
      goto   Visualiza
Izquierda
      bcf   SalidaAdelante
      bcf   SalidaAtras
      bsf   SalidaIzquierda
      bcf   SalidaDerecha
      movlw   mensajeIzquierda
      goto   Visualiza
Derecha
      bcf   SalidaAdelante
      bcf   SalidaAtras
      bcf   SalidaIzquierda
      bsf   SalidaDerecha
      movlw   MensajeDerecha
;Según el estado de las salidas visualiza el estado del sistema en el visualizador LCD y en
;el monitor del ordenador.
;Visualiza
;      movwf   MensajeApuntado      ;Guarda la posición del mensaje.
;      call   LCD_Borra      ;Borra la pantalla del modulo LCD.
;      movf   MensajeApuntado,W   ;Visualiza el mensaje en la pantalla
;      call   LCD_Mensaje      ;del visualizador LCD.
;      call   RS232_LineasBlanco   ;Borra la pantalla del modulo LCD.
;      call   RS232_Mensaje      ;Lo visualiza en el hiperTerminal
Fin   return
      INCLUDE <RS232.INC>
      INCLUDE <RS232MEN.INC>
;      INCLUDE <LCD_4BIT.INC>
;      INCLUDE <LCD_MENS_INC>
      INCLUDE <RETARDOS_INC>
      END
« Respuesta #3 en: 20 de Mayo de 2009, 17:14:10 »
Al hacer doble click sobre el error Mplab te posiciona sobre el error. La mayoría son errores de escritura. Por ejemplo, esta definida la variable Teclapulsada y tu llamas a TeclaPulsada.
O llamas a IZQUIERDA, y la etiqueta es Izquierda. Así que anda revisando eso.
« Respuesta #4 en: 20 de Mayo de 2009, 18:44:53 »
pero que pasaria con esta linea ? Error[113]   C:\X\MOTOR(PAP)\1\MOTOR(PAP).ASM 52 : Symbol not previously defined (RS232_LeeDatos) , estoy revisando lo demas ! Gracias !
« Respuesta #5 en: 20 de Mayo de 2009, 19:06:33 »
Para incluir la librería se hace #include<P16f84A.INC>, #include<RS232.INC>...
Desconectado CONFORMOTICA
« Respuesta #6 en: 20 de Mayo de 2009, 19:41:48 »
Al parecer estas llamando a la subrutina RS232_LeeDatos y no esta definida esa subrutina, por lo que el compilador no la encuentra y te salta error de Symbol not previously defined.
« Respuesta #7 en: 21 de Mayo de 2009, 13:16:07 »
como puedo solucionarlo ?? , perdón por la tardanza es que seguia intentando con el codigo ! , y gracias por responder !!.
« Respuesta #8 en: 21 de Mayo de 2009, 15:16:09 »
Ya te lo respondí en un mensaje anterior. Para incluir librerias se hace asi: #include<>
« Respuesta #9 en: 22 de Mayo de 2009, 10:28:14 »
Al parecer falta una parte del codigo, donde se define esa subrutina. Si no lo tenes, podrias eliminar todas las partes del codigo donde dice "call rs232_leedatos;" y de esa forma vas a evitar que te aparezca el error, pero tu programa, muy probablemente, no funcione(ya que falta una parte del codigo).
Se entiende?  cualquier cosa volve a consultar
