Autor Tema: Ayuda!!! Contador en Display 7 Seg  (Leído 2731 veces)
Desconectado LUCHO512
« en: 07 de Noviembre de 2009, 23:48:48 »
Estimados tengo un peuqeño problema seguro es una pavada pero no doy con al tecla, intento hacer un contador con 4 display de 7 segmentos, el terma es que no se incrementa la variable number alguna sugerencia!!!
Codigo en Mikrobasic...
program Display7seg
dim shifter, digit, portd_index as byte
dim number as word
dim por as byte[4]
sub function Mask(dim num as byte) as byte    ' this function returns masks
  select case num                             ' for common cathode 7-seg. display
    case 0  result = $3F
    case 1  result = $06
    case 2  result = $5B
    case 3  result = $4F
    case 4  result = $66
    case 5  result = $6D
    case 6  result = $7D
    case 7  result = $07
    case 8  result = $7F
    case 9  result = $6F
  end select                                  'case end
end sub
sub procedure interrupt
  PORTA  = shifter             ' turn on appropriate 7seg. display
  PORTB  = por[portd_index]
  Inc(portd_index)             ' increment value of variable portd_index
  shifter = shifter << 1
  if shifter > 8 then
    shifter = 1                ' prepare mask for digit
  end if
  if portd_index > 3 then
    portd_index = 0            ' turn on 1st, turn off 2nd 7seg.
  end if
  TMR0   =   96
  INTCON = $20
end sub
main:
  OPTION_REG = $80
  digit      =   0
  portd_index =  0
  shifter    =   1
  TMR0       =   96
  INTCON     = $A0             ' Disable PEIE,INTE,RBIE,T0IE
  TRISA      =   0
  TRISB      =   0
  PORTB      =   0
  PORTA      =   0
  number     =   0
conta:
    number=number+1
     'number=1
    digit = number div 1000             ' prepare digits for diplays
    por[3] = Mask(digit)
    digit = number div 100 mod 10
    por[2] = Mask(digit)
    digit = number div 10 mod 10
    por[1] = Mask(digit)
    digit = number mod 10
    por[0] = Mask(digit)
    Delay_ms(1000)
goto conta
end.
