Autor Tema: Amplificador de audio stereo clase ab con tda2050 y control de tonos-Finalizado  (Leído 28451 veces)
Desconectado AKENAFAB
Hola amigos
Aqui les posteo este proyectito , solo segui las especificaciones de los fabricantes y realice los pcbs,asi como las respectivas pruebas.
Tengo funcionando desde hace varias semanas el ampli y a mi gusto tiene muy buen sonido.
Se trata de un amplificador con ci tda2050 ,incluyolas caracteristicas :
The TDA 2050 is a monolithic integrated circuit in Pentawatt package, intended for use as an audio class AB audio amplifier. Thanks to its high powercapability the TDA2050 is able to provide up to 35W true rms power into 4 ohm load @ THD =10%, VS = ±18V, f = 1KHz and up to 32W into 8ohm load @ THD = 10%, VS = ±22V, f = 1KHz.
Moreover, the TDA 2050 delivers typically 50W music power into 4 ohm load over 1 sec at VS=22.5V, f = 1KHz.The high power and very low harmonic and cross-over distortion (THD = 0.05% typ, @ VS = ±22V,PO = 0.1 to 15W, RL=8ohm, f = 100Hz to 15KHz)
make the device most suitable for both HiFi  andhigh class TV sets.
El diagrama
http://img20.imageshack.us/img20/8388/tdaesquema.jpg
Al ser stereo solo se duplica el circuito , uno por cada canal.Si desean conectar más de una bocina(speaker,parlante,etc..)agregan otro.
Circuito impreso
http://img231.imageshack.us/img231/7098/tda2050pcb.png
Control de Tonos LM1036
The LM1036 is a DC controlled tone (bass/treble), volume and balance circuit for stereo applications in car radio, TV and audio systems. An additional control input allows loudness compensation to be simply effected.Four control inputs provide control of the bass, treble, balance and volume functions through application of DC voltages from a remote control system or, alternatively, from four potentiometers which may be biased from a zener regulated supply provided on the circuit.
Each tone response is defined by a single capacitor chosen to give the desired characteristic.
Features
■ Wide supply voltage range, 9V to 16V
■ Large volume control range, 75 dB typical
■ Tone control, ±15 dB typical
■ Channel separation, 75 dB typical
■ Low distortion, 0.06% typical for an input level of 0.3 Vrms
■ High signal to noise, 80 dB typical for an input level of 0.3
Vrms
■ Few external components required
Diagrama
El circuito enmarcado despues de la salida es opcional , agregue esta otra etapa amplificadora para exprimir la potencia de los tda2050.No recominedo ganancia mayor a 3.Solo cambien R10 y R15 por 10K ,22K o 33K
http://img205.imageshack.us/img205/9084/tonecontrol.jpg
Para alimentar el circuito  necesitaran una fuente que entregue +-22v  maximo y 5Amperes minimo (TDA2050)
Colocar unos buenos disipadores xD
Minimo un capacitor 4700uF por rama.Filtren bien su fuentecita
Para el control de tonos necesitan alimentardo de +9v a +15v
todos los capacitores no polarizados son de polyester,pueden usar cerámicos solo para el control de tonos pero en el ampli los veo remplazables
adjunto los archivos de eagle.
Más tarde seguire completando el hilo.
Saludos y buen sonido xD
« Última modificación: 25 de Julio de 2010, 01:28:20 por AKENAFAB »
Desconectado Menta
Gracias por compartirlo!!!
Si puedes pon alguna foto de la placa terminada
En eso ando xD busco unas baterias :P
Dejo un link para las imagenes
Webplayer de las imágenes
« Última modificación: 25 de Julio de 2010, 02:22:00 por AKENAFAB »
Quedaron bien Akena  :mrgreen:
Se ve bien el control de tonos ya en CI  :D ;-)
xD
ME gusto como quedaron y funciona muy bien.Agarre de hobbye el rollo de los amplis
Eso si , con esos integradito sXD mueve sabroso las bocinas xD pero chabroOOoOOoocho xD
Todavia no termino las otras placas ;-)
AkENAFAB  :-/ :-/ me alegro que te funcione  :-/ :-/ Guao  :mrgreen:
xD
Vas a dejar sordos a los niños del museo  :D
xD
Leve leve xD
Solo que consiga los drivers de 100W xD ahi si hasta que se les salgan los ojos :P
Leve leve xD
 :D :D :D :D
Muy bien Akena, da gusto cuando las cosas funcionan.
¿Has probado algún ampli clase-D?
Re: Amplificador de audio stereo clase ab con tda2050 y control de tonos-Finalizado
« Respuesta #10 en: 26 de Julio de 2010, 11:22:42 »
Todavia no lo pruebo , pero los estoy estudiando.
Hay unas notas de Bruno Putzey y phillips UM10155
Muy interesante la clase D además de compacta y eficiente.
« Respuesta #11 en: 06 de Diciembre de 2010, 00:31:30 »
Subo fotos de la nueva plaquita del amplificador. :-/ :-/
Saludos!!
« Última modificación: 05 de Marzo de 2011, 03:30:54 por AKENAFAB »
« Respuesta #12 en: 06 de Diciembre de 2010, 02:56:58 »
Te quedo de padre Akena :P
« Respuesta #13 en: 06 de Diciembre de 2010, 03:42:19 »
Gracias!!
Ya lo he probado a bajo volumen y por ahora todo bien.Me esperare a mañana xD para darle caña  :mrgreen: .
« Respuesta #14 en: 06 de Diciembre de 2010, 11:40:34 »
Quedaron bien. Pruébalas con una resistencia de 16 ohms, o lo que vayas a conectar. Así le subes al 100% la potencia sin quedarte sordo.
