Autor Tema: LCD 4x20  (Leído 2713 veces)
Desconectado Algec
LCD 4x20
« en: 20 de Febrero de 2006, 07:20:00 »
Necesito saber como inicializar una lcd 4x20
Y como direccionar la 3 y 4 linea, ya que uso una libreria para 2x20
Desconectado Sispic
    • winpic800
RE: LCD 4x20
« Respuesta #1 en: 28 de Febrero de 2006, 10:01:00 »
Quiza te sirva  , `puedes adaptar a CCS o hacerte una idea .
Codigo:
  // LCD HD44780U 4 bit mode.
  // LCD tipos:   1x8, 2x8, 1x16, 2x16, 2x20, 4x16, 4x20
  // Modificado para DsPic 30Fxxxx
         //  USER"S ROUTINES DESCRIPTION:
  LCD_INIT()                ---> initilalize the LCD.
  LCD_CLEAR()               ---> Clears and Home LCD.
  LCD_CMD("char")           ---> Send a command to the LCD.   See LCD datasheet for the complete list of commands.
  LCD_GOTO(line,pos)        ---> Set the Cursor to a specified Line and position. Lines available are from 1 to 4. Pos available starts from 1 to max available on your LCD.
  LCD_PUTCH("char")         ---> Write a character on LCD (ASCII representation).
  LCD_PUTS("string"Giño        ---> Write a string on LCD.
  LCD_PUTC("constant"Giño      ---> Write a const string on LCD.
  LCD_PUTUN(unsigned long)  ---> Write an Unsigned Number on LCD. It works both with INT (16bit) and CHAR (8bit). y (32bit) maximo 9 digitos
  Set_CGRAM_address(char addr) --->
    Ejemplo . escribe 2 caracteres predefinidos en direccion 0 y 1
    LCD_INIT();
    Set_CGRAM_address(0);
    LCD_PUTCH(1);LCD_PUTCH(2);LCD_PUTCH(4);LCD_PUTCH(8);LCD_PUTCH(16);LCD_PUTCH(32);LCD_PUTCH(1);LCD_PUTCH(1);
    LCD_PUTCH(9);LCD_PUTCH(10);LCD_PUTCH(1);LCD_PUTCH(1);LCD_PUTCH(1);LCD_PUTCH(1);LCD_PUTCH(1);LCD_PUTCH(1);
    LCD_CLEAR();
    LCD_PUTCH(0); LCD_PUTCH(1);
/* Use the following defines to set the lines as your hardware requires   */
/* ...you can use ANY output line of the MCU, even on several ports Sonrisa   */
  #define LCD_ROWS   2   // valid numbers are: 1,2
  #define LCD_COLS   20   // valid numbers are: 8,16,20   // (set to 2 for 2 or more rows)
  /*  PUERTOS */
  #define   LCD_RS        PORTEbits.RE4          // Register select
  #define   LCD_EN        PORTEbits.RE5          // Enable
  #define   LCD_D4        PORTEbits.RE0          // LCD data 4
  #define   LCD_D5        PORTEbits.RE1          // LCD data 5
  #define   LCD_D6        PORTEbits.RE2          // LCD data 6
  #define   LCD_D7        PORTEbits.RE3          // LCD data 7
  /*  TRIS */
  #define   LCD_RS_TRIS   TRISEbits.TRISE4      // Register select
  #define   LCD_EN_TRIS   TRISEbits.TRISE5      // Enable
  #define   LCD_D4_TRIS   TRISEbits.TRISE0      // LCD data 4
  #define   LCD_D5_TRIS   TRISEbits.TRISE1      // LCD data 5
  #define   LCD_D6_TRIS   TRISEbits.TRISE2      // LCD data 6
  #define   LCD_D7_TRIS   TRISEbits.TRISE3      // LCD data 7
  #define LCD_CLR      0x01                // Clear Display
  #define LCD_HOME      0x02                // Cursor to Home position
                                            // Entry mode set
                                            // ejemplo: LCD_CMD( CURSOR_DIRECCTION_Decrement | NO_Accompanies_display_shift );
  #define  CURSOR_DIRECCTION_Increment 0x6
  #define  CURSOR_DIRECCTION_Decrement 0x4
  #define  Accompanies_display_shift  0x5
  #define  No_Accompanies_display_shift 0x4
                                           // Display on/off control
                                           // ejemplo: LCD_CMD( DISPLAY_ON | CURSOR_ON | CURSOR_BLINKING_OFF );
  #define DISPLAY_ON 0x0C
  #define DISPLAY_OFF 0x08
  #define CURSOR_ON 0x0A
  #define CURSOR_OFF 0x08
  #define CURSOR_BLINKING_ON 0x09
  #define CURSOR_BLINKING_OFF 0x08
                                           // Cursor or display shift
                                           // ejemplo: LCD_CMD( Cursor_move |  Shift_to_the_left );
  #define Display_shift 0x18
  #define Cursor_move 0x10
  #define Shift_to_the_right 0x14
  #define Shift_to_the_left 0x10
  #if (LCD_COLS==20)
   #define LCD_line1   0x80 // Line 1 position 1
   #define LCD_line2   0xC0 // Line 2 position 1
   #define LCD_line3   0x94 // Line 3 position 1 (20 char LCD)
   #define LCD_line4   0xD4 // Line 4 position 1 (20 char LCD)
  #else
   #define LCD_line3   0x90 // Line 3 position 1 (16 char LCD)
   #define LCD_line4   0xD0 // Line 4 position 1 (16 char LCD)
  #endif
  // const Font_3x6_0[8] = { 0,0,0,0,0x38,0x44,0x38,0}; /* 0   0x30 */
  /*     Enable LCD to read data   */
  void LCD_STROBE (void)
  LCD_EN = 1;
  DelayUs(1);
  LCD_EN = 0;
/*    Write a nibble to the LCD           */
  void LCD_NIBBLE_OUT (unsigned char c )  {
   LCD_D4=c ; c >>= 1;
   LCD_D5=c;  c >>= 1;
   LCD_D6=c;  c >>= 1;
   LCD_D7=c;
   LCD_STROBE();
/* Write a byte to the LCD (4 bit mode) */
 void LCD_WRITE (unsigned char c)
  LCD_NIBBLE_OUT(c >> 4);
  LCD_NIBBLE_OUT(c);
  DelayUs(50);
 /*       send a command to the LCD      */
  void LCD_CMD (char c)  {
  LCD_RS = 0;   // write command
  LCD_WRITE(c);
/*  GoTO specified line and position    */
  void LCD_GOTO (char line,char pos)   // Set DDRAM address
  switch(line)
   case 1: LCD_CMD((LCD_line1-1)+pos);
          break;
   case 2: LCD_CMD((LCD_line2-1)+pos);
        break;
   case 3: LCD_CMD((LCD_line3-1)+pos);
          break;
   case 4: LCD_CMD((LCD_line4-1)+pos);
  /*           Clear and Home LCD         */
  void LCD_CLEAR (void)
  LCD_CMD(LCD_CLR);
  DelayMs(3);
  /*     Write one character to the LCD   */
  void LCD_PUTCH (unsigned char c)
  LCD_RS = 1;   // write characters
  LCD_WRITE(c);
 /*       Write a string to the LCD      */
 void LCD_PUTS ( char  * s)
  while(*s)
    LCD_WRITE(*s++);
 /*       Write a const to the LCD      */
 void LCD_PUTC ( const  * s)
  while(*s)
    LCD_WRITE(*s++);
/*  Set CGRAM address                   */
  void Set_CGRAM_address(unsigned char addr){
     addr = addr & 0x3F;
     LCD_CMD(0x40 | addr );
 /*  escribe un caracter predefinido en cgram    */
 void LCD_SetCaracter (unsigned  char posicion , const  * s)
 { unsigned char a; a=8;
 Set_CGRAM_address(posicion);
  while(a != 0){
    LCD_WRITE(*s++); a--;}
/*  Escribe Valor numerico al LCD       */
/*  Max 1 a 9 digitos                   */
/*  ceros a la izquierda blancos        */
/*  puno de miles y millones            */
/*  ejemplo :  341.000.780   1.886  23  */
  void LCD_PUTUN (unsigned char Digitos , unsigned long valor)
   unsigned char t1,i,wrote;
   unsigned long k;
  wrote=0;
  for (i=Digitos-1; i>=1; i--)
     switch(i){
     case 8: k=100000000;
        break;
    case 7: k=10000000;
        break;
     case 6: k=1000000;
        break;
   case 5: k=100000;  if (Digitos > 6){ if (wrote==1){ LCD_PUTCH(".");} else { LCD_PUTCH(" ");}} // millones
        break;
    case 4: k=10000;
        break;
     case 3: k=1000;
        break;
   case 2: k=100;     if (Digitos > 3){ if (wrote==1){ LCD_PUTCH(".");} else { LCD_PUTCH(" ");}} // miles
       break;
   case 1: k=10;
    t1=valor/k;
   if((wrote)||(t1!=0)){LCD_PUTCH(t1+"0"); wrote=1;}
    else LCD_PUTCH(" ");                               // Ceros izquierda blanco
    valor-=(t1*k);
   LCD_PUTCH( valor +"0");
/*             Initialize LCD           */
  void LCD_INIT (void)
  /* Configura los TRIS como salidas */
   LCD_RS_TRIS  = 0;      // Register select
   LCD_EN_TRIS  = 0;       // Enable
   LCD_D4_TRIS  = 0;       // LCD data 4
   LCD_D5_TRIS  = 0;       // LCD data 5
   LCD_D6_TRIS  = 0;        // LCD data 6
   LCD_D7_TRIS  = 0;       // LCD data 7
   LCD_RS = 0;              // write control bytes
   DelayMs(20);              // power on delay
   LCD_NIBBLE_OUT(0x04);    // set 4 bit mode
   DelayUs(100);
   #if (LCD_ROWS==1)
    LCD_CMD(0x20);   // 4 bit mode, 1 line, 5x8 font          (0b00100000);
   #else
    LCD_CMD(0x28);   // 4 bit mode, 2 or more lines, 5x8 font (0b00101000);
   #endif
   LCD_CMD(DISPLAY_OFF);
   LCD_CMD(DISPLAY_ON | CURSOR_OFF | CURSOR_BLINKING_OFF);
   LCD_CMD( CURSOR_DIRECCTION_Increment | No_Accompanies_display_shift );
   LCD_CLEAR();
