Autor Tema: Capturar coordenadas joystick  (Leído 5173 veces)
Desconectado antoniojdobarro
« en: 17 de Febrero de 2011, 12:45:48 »
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Microsoft.DirectX.DirectInput;
namespace WindowsFormsApplication2
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        //iAdd Code for init Joystick
        private Device joystick;
        private void iJoy_Load(object sender, EventArgs e) //iAdd
            this.InitDevices();
        private void InitDevices()
            //create joystick device.
            foreach (
            DeviceInstance di in
            Manager.GetDevices(
            DeviceClass.GameControl,
            EnumDevicesFlags.AttachedOnly))
                joystick = new Device(di.InstanceGuid);
                break;
            if (joystick == null)
                //Throw exception if joystick not found.
                throw new Exception("Joystick no encontrado.");
            //Set joystick axis ranges.
            foreach (DeviceObjectInstance doi in joystick.Objects)
                if ((doi.ObjectId & (int)DeviceObjectTypeFlags.Axis) != 0)
                    joystick.Properties.SetRange(
                    ParameterHow.ById,
                    doi.ObjectId,
                    new InputRange(-5000, 5000));
            //Set joystick axis mode absolute.
            joystick.Properties.AxisModeAbsolute = true;
            //set cooperative level.
            joystick.SetCooperativeLevel(
            this,
            CooperativeLevelFlags.NonExclusive |
            CooperativeLevelFlags.Background);
            //Acquire devices for capturing.
            joystick.Acquire();
        private void UpdateJoystick()
            string info = "Joystick: ";
            //Get Mouse State.
            JoystickState state = joystick.CurrentJoystickState;
            //Capture Position.
            info += "X:" + state.X + " ";
            info += "Y:" + state.Y + " ";
            info += "Z:" + state.Z + " ";
            //Capture Buttons.
            byte[] buttons = state.GetButtons();
            for (int i = 0; i < buttons.Length; i++)
                if (buttons != 0)
                    info += "Boton:" + i + " ";
            lbJoystick.Text = info;
        private void timer1_Tick(object sender, EventArgs e)
            UpdateJoystick();
Este es el código en c# para capturar un joystick, pero por que no me imprime sus coordenadas en pantallla.
En pantalla tengo la etiqueta lbJoystick, y el timer, todo compila bien, sin problema, pero...
Desconectado tannke
Re: Capturar coordenadas joystick
« Respuesta #1 en: 17 de Febrero de 2011, 17:15:49 »
has provado ponieno en las variables "int/long" convertirlas esplicitamente a string, es deciar algo asi:
            //Get Mouse State.
            //Capture Position.
            info += "X:" + state.X.ToString() + " ";
            info += "Y:" + state.Y.ToString()  + " ";
            info += "Z:" + state.Z.ToString()  + " ";
            //Capture Buttons.
                if (buttons != 0)
                    info += "Boton:" + i.ToString()  + " ";
es que no recuerdo ahora mismo si se podia omitir el ToString(), pero alomejor puede venirte por ahi el fallo
« Respuesta #2 en: 17 de Febrero de 2011, 19:13:50 »
using System;
using System.Data;
using System.Linq;
using System.Text;
namespace WindowsFormsApplication3
        public Form1()
        //Codigo para iniciar el Joystick
        private void carga_panzer(object sender, EventArgs e)
            this.InitDevices();
       // Iniciando el Joystick
            //Cargando todos los joysticks posibles
            foreach (
                Manager.GetDevices(
                break;
                //Si no encontramos ningún Joystrick
                throw new Exception("No joystick found.");
            ////Configurando los dispositivos
            //Configurando los ejes del Joystick
                        ParameterHow.ById,
                        doi.ObjectId,
                        new InputRange(-75000, 75000));
            //Nivel cooperativo
                this,
            //Adquiriendo datos del joystick
            joystick.Acquire();
            //Estado del joystick
            //Posición
            //Botones
                if (buttons != 0)
                    info += "Button:" + i + " ";
            label1.Text = info;
            UpdateJoystick();
Funciona perfecto, compilado con Visual 2010.
