Autor Tema: News: EAGLE VERSION 6.00 OCT 13 2011 with 3D Visualization  (Leído 8498 veces)
Desconectado cdrpo
« en: 13 de Octubre de 2011, 16:50:43 »
:-/ News: EAGLE VERSION 6.0 OCT 13 2011 con muchas mejoras
http://www.cadsoftusa.com/eagle-pcb-design-software/new-in-v6/?language=en
with 3D Visualization, aunque el realismo de EAGLE3D es muy superior
http://www.cadsoftusa.com/services/3d-visualization/?language=en
:( lo malo es que no hay link de descarga, hay que comprarlo y recibes esta ultima versión
Novedades
WHAT’S NEW IN VERSION 6?
XML database structure redesign
    Read, edit and parse the data outside of the EAGLE tool
    The new XML database structure provides the ability to write scripts that manipulate designs in the EAGLE format which will give users huge productivity benefits. You can make design changes, import information from other designs, and even translate from other formats. EAGLE is one of the first Commercial CAD Programs that adopts a ASCII XML data structure as their native file. This makes EAGLE the most flexible, user friendly and productive PCB tool on the market.
Design Reuse
    Merge board/schematic pairs using the PASTE function with full consistency
    You can copy an already finished design consisting of a consistent pair of Schematic and Layout into another project. Enumeration of components and signals will be exactly the same in board and schematic, so that consistency between schematic and board will be maintained. This supports easy design, for example, of multi-channel devices. You only have to design schematic and layout for one channel and can copy it easily.
Routing capability enhancement
    Optimize your work-flow with Undo/Redo log
    The UNDO/REDO log shows the history of each step you have made. You have full control of the steps going back or forward.
    Work with flawless conversions between mm and inches through increased internal resolution (allows grids of 1/4, 1/8, 1/16,1/32 and 1/64 mil)
    If you have to work with both systems, metric and imperial, you know about problems that can arise in converting the usual imperial grid values (always divided by 2) and the resulting mm values. Increasing the internal resolution up to 1/64 mil will allow a proper conversion in all situations.
Library editor optimization
    Connect a pin to multiple pads
    You can now connect one pin in the schematic symbol to any number of pads of the package. With this function EAGLE can handle components internal connected pins. Compared to previous versions schematic symbols look nicer and you save time in defining them.
    Draw arbitrary pad shapes easily
    Take a pad or an SMD as basis and draw the final contour with the help of the WIRE or POLYGON command. These objects will be considered as part of the pad/smd. No more problems with Design Rules Check for such objects.
    Benefit from unlimited number of technologies and package variants
    Until now the maximum number of technologies and package variants was limited. In some cases one could reach the limits and had to split a library into two parts. No more limitation in EAGLE 6.
Layout editor add-ons
    Dimension your layout automatically
    A dimensioning tool where you decide by a few mouse clicks the objects to be dimensioned.
    Create restricted areas with Cutout polygons
    Outer and inner layers can now have individual restricted areas that will be avoided by signal polygons. Simply draw a polygon and define it as cutout.
File description functionality
    Individualize your schematics, sheets, boards and symbols with descriptions
    The file description can inform you about the content of a board or schematic. It is shown in the Control Panel without loading the file in the editor windows. This makes your project management clearer. See what this file contains without loading it in an editor window. This also works with sheets of multi-sheet schematics.
ADDITIONAL FEATURES PLANNED FOR VERSION 6:
    Benefit from differential pair routing and automatic meanders
    Special signals can be routed with exactly the same length. Differential pair routing is used for pairs of differential (equal and opposite) signals across the board to create a balanced transmission system. Creating meanders helps users automatically give a signal a certain length in the PCB. Meanders in traces are used to increase delay times in high speed digital circuits.
    Improve your efficiency through BGA escape routing (ULP)
    BGA devices can have a 1000 connections or more. Packages are getting smaller and smaller. It is a hard and tedious work to connect all the pins, set vias, decide about the layers to use, and come out from the BGA area. This ULP helps you in escaping from the BGA in a proper way.
    Be flexible with assembly variants
    One schematic but a number of different assembly variants can be handled now.
    Justify your text to left, top, right, bottom, middle or center with one mouse click
    This allows you to adjust texts as you know it from text editors. Gives a neat look and makes writing, for example, comments more comfortable.
GUI improvement
    Define your own context menu
    Speed up your work-flow with self-defined content in the context menu. Frequently used commands or combinations of commands can be integrated into the context menu. This minimizes mouse-clicks and increases working speed.
« Última modificación: 16 de Octubre de 2011, 13:45:06 por cdrpo »
Desconectado manwenwe
Re: News: EAGLE VERSION 6.00 OCT 13 2011 with 3D Visualization
« Respuesta #1 en: 13 de Octubre de 2011, 17:24:10 »
X favor: que alguien asesine al que eligió la música!!!! jejeje
Desconectado cdrpo
« Respuesta #2 en: 20 de Octubre de 2011, 13:35:42 »
Por medio del software B2 Spice v.5 puede simular el PCB creado en EAGLE V6.0
http://www.beigebag.com/v5_features
Desconectado cdrpo
« Respuesta #3 en: 04 de Noviembre de 2011, 15:07:05 »
Aunque ya esta a la venta EAGLE VERSION 6.00
Cadsoft nos ofrece gratuitamente version mejoradas de la 5.00
Ultimo lanzamiento hoy eagle-win-5.91.1-beta.exe
http://www.cadsoftusa.com/betatest/?language=en
Release notes for EAGLE 5.91.1
* DISPLAY command:
  - The DISPLAY command can now also delete internal layers, as long as they
    are empty.
* LAYER command:
  - The LAYER command can now also delete internal layers, as long as they
    are empty.
* Miscellaneous:
  - Dialog CHANGE package/technology: Support of external links and representation
    of images.
  - ULP function dlgTextView: Proper support for links to local files (open application).
* Bugfixes:
  - Group selection by polygon: Avoid selecting too much in special case.
  - PRINT command: Transfer options to print dialog if not ended with ';'.
  - CAM processor dialog: Avoid settings getting overridden from previously opened
    CAM file; Avoid crash after save and opening recent file.
  - ULP functions setgroup/ingroup: Bugfix if called for other editor window and no
    group defined yet.
  - ULP function dlgListView: No sorting for parameter sort=0.
  - ULP function dlgComboBox: Avoid jumping combobox size in special case (dlgRedisplay
    called).
  - Fix for wrong REPLACE with package and technology in special constellations.
  - Info dialog for arcs/wires: Correct handling of cap style while changing
    curve to 0/from 0.
Desconectado nZeta
« Respuesta #4 en: 04 de Noviembre de 2011, 15:32:36 »
Eagle actualmente tiene una promocion de si complas la version 5 ahora tienes upgrade a la v6 gratis.
Yo uso eagle, pero estoy considerando otras opciones. Lo malo de eagle light son los limites para 1 sola pagina de esquematicos, seguro les ha pasado que cuando tienen un proyecto complicado, el esquematico en una sola pagina se vuelve todo un volondron. El precio de la version "Hobista" es aceptable aunque si por ahi haces alguna plaquita que le guste a la gente con esa version de eagle, no lo puedes vender. u_U
Desconectado cdrpo
« Respuesta #5 en: 06 de Noviembre de 2011, 14:38:52 »
con esa version de eagle (5/6), no lo puedes vender. u_U no te endiento :?
Desconectado rivale
« Respuesta #6 en: 06 de Noviembre de 2011, 23:51:27 »
 :D :D
Desconectado Geo
    • Mexchip
« Respuesta #7 en: 10 de Noviembre de 2011, 01:23:07 »
La versión gratuita (freeware) tiene entre sus condiciones que no puedes utilizarla con fines comerciales.
La imaginación es el límite.
Desconectado cdrpo
« Respuesta #8 en: 19 de Noviembre de 2011, 08:59:56 »
La version 5.91.1 ha sido la misma 6.0  :-/
EAGLE v6 beta – XML export, some example files and screenshots…
esto puede ser ideal para mejorar EAGLE3D
http://www.adafruit.com/blog/2011/11/04/eagle-v6-beta-xml-export-some-example-files-and-screenshots/
hackaday.com/2011/11/05/cadsofts-eagle-6-hits-beta-and-packs-goodies
Desconectado nZeta
« Respuesta #9 en: 19 de Noviembre de 2011, 14:30:35 »
me referia a la version "hobista" que trae todas las caracteristicas de la version standard y cuesta solo $125, pero tiene la limitacion de "no comercial"
