Autor Tema: problema con mpusbapi.dll al cargarla a MATLAB  (Leído 3969 veces)
Desconectado saveuc_siul
« en: 21 de Abril de 2012, 00:10:52 »
hola de nuevo amigos, nuevamente vengo con un problema en la comunicación PIC-MATLAB por USB, lo que pasa es que cuando quiero cargar la libreria mpusbapi.dll me arroja errores como se muestra a continuación:
> In loadlibrary at 399
Error loading library intermediate output follows.
The actual error is at the end of this output.
Type 'PCHAR' was not found.  Defaulting to type error.
Found on line 93 of input from line 92 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Type 'HANDLE' was not found.  Defaulting to type error.
Found on line 186 of input from line 185 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Found on line 217 of input from line 216 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Type 'PVOID' was not found.  Defaulting to type error.
Type 'PDWORD' was not found.  Defaulting to type error.
Found on line 249 of input from line 248 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Found on line 280 of input from line 279 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Type 'BOOL' was not found.  Defaulting to type error.
Found on line 290 of input from line 289 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Found on line 311 of input from line 310 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Found on line 335 of input from line 334 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Type 'UCHAR' was not found.  Defaulting to type error.
Found on line 361 of input from line 360 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
Type 'USHORT' was not found.  Defaulting to type error.
Found on line 381 of input from line 380 of file C:\\Users\\LUIS ANGEL\\Documents\\MATLAB\\_mpusbapi.h
??? Error using ==> loadlibrary at 428
Building mpusbapi_thunk_pcwin64 failed.  Compiler output is:
mpusbapi_thunk_pcwin64.c
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(81) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(91) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(180) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(211) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(243) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(274) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(288) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(306) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(329) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(354) : error C2059: syntax
error : 'string'
C:\Users\LUIS ANGEL\Documents\MATLAB\_mpusbapi.h(378) : error C2059: syntax
error : 'string'
mpusbapi_thunk_pcwin64.c(59) : error C2065: 'PCHAR' : undeclared identifier
mpusbapi_thunk_pcwin64.c(59) : error C2146: syntax error : missing ';' before
identifier 'p0'
mpusbapi_thunk_pcwin64.c(59) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(60) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(60) : error C2146: syntax error : missing ')' before
identifier 'PCHAR'
mpusbapi_thunk_pcwin64.c(60) : error C2065: 'PCHAR' : undeclared identifier
mpusbapi_thunk_pcwin64.c(60) : error C2100: illegal indirection
mpusbapi_thunk_pcwin64.c(60) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(60) : error C2297: '*' : illegal, right operand has
type 'const char *'
mpusbapi_thunk_pcwin64.c(61) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(62) : error C2146: syntax error : missing ')' before
identifier 'PCHAR'
identifier 'PCHAR'
mpusbapi_thunk_pcwin64.c(62) : error C2065: 'PCHAR' : undeclared identifier
mpusbapi_thunk_pcwin64.c(62) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(62) : error C2146: syntax error : missing ';' before
identifier 'fcn'
mpusbapi_thunk_pcwin64.c(62) : warning C4047: 'return' : 'uint32' differs in
levels of indirection from 'uint32 (__cdecl *)()'
mpusbapi_thunk_pcwin64.c(62) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(66) : error C2061: syntax error : identifier
'HANDLEuint32PCHARPCHARuint32uint32Thunk'
mpusbapi_thunk_pcwin64.c(66) : error C2059: syntax error : ';'
mpusbapi_thunk_pcwin64.c(66) : error C2059: syntax error : 'type'
mpusbapi_thunk_pcwin64.c(89) : error C2065: 'HANDLE' : undeclared identifier
mpusbapi_thunk_pcwin64.c(89) : error C2146: syntax error : missing ';' before
identifier 'p0'
mpusbapi_thunk_pcwin64.c(89) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(90) : error C2065: 'PVOID' : undeclared identifier
mpusbapi_thunk_pcwin64.c(90) : error C2146: syntax error : missing ';' before
identifier 'p1'
mpusbapi_thunk_pcwin64.c(90) : error C2065: 'p1' : undeclared identifier
mpusbapi_thunk_pcwin64.c(91) : error C2275: 'uint32' : illegal use of this type
as an expression
        mpusbapi_thunk_pcwin64.c(45) : see declaration of 'uint32'
mpusbapi_thunk_pcwin64.c(91) : error C2146: syntax error : missing ';' before
identifier 'p2'
mpusbapi_thunk_pcwin64.c(91) : error C2065: 'p2' : undeclared identifier
mpusbapi_thunk_pcwin64.c(92) : error C2065: 'PDWORD' : undeclared identifier
mpusbapi_thunk_pcwin64.c(92) : error C2146: syntax error : missing ';' before
identifier 'p3'
mpusbapi_thunk_pcwin64.c(92) : error C2065: 'p3' : undeclared identifier
mpusbapi_thunk_pcwin64.c(93) : error C2275: 'uint32' : illegal use of this type
as an expression
mpusbapi_thunk_pcwin64.c(93) : error C2146: syntax error : missing ';' before
identifier 'p4'
mpusbapi_thunk_pcwin64.c(93) : error C2065: 'p4' : undeclared identifier
mpusbapi_thunk_pcwin64.c(94) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(94) : error C2146: syntax error : missing ')' before
identifier 'HANDLE'
mpusbapi_thunk_pcwin64.c(94) : error C2065: 'HANDLE' : undeclared identifier
mpusbapi_thunk_pcwin64.c(94) : error C2100: illegal indirection
mpusbapi_thunk_pcwin64.c(94) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(94) : error C2297: '*' : illegal, right operand has
type 'const char *'
mpusbapi_thunk_pcwin64.c(95) : error C2065: 'p0' : undeclared identifier
mpusbapi_thunk_pcwin64.c(96) : error C2065: 'p1' : undeclared identifier
mpusbapi_thunk_pcwin64.c(96) : error C2146: syntax error : missing ')' before
identifier 'PVOID'
mpusbapi_thunk_pcwin64.c(96) : error C2065: 'PVOID' : undeclared identifier
mpusbapi_thunk_pcwin64.c(96) : error C2100: illegal indirection
mpusbapi_thunk_pcwin64.c(96) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(96) : error C2297: '*' : illegal, right operand has
type 'const char *'
mpusbapi_thunk_pcwin64.c(97) : error C2065: 'p1' : undeclared identifier
mpusbapi_thunk_pcwin64.c(98) : error C2065: 'p2' : undeclared identifier
mpusbapi_thunk_pcwin64.c(99) : error C2065: 'p2' : undeclared identifier
mpusbapi_thunk_pcwin64.c(100) : error C2065: 'p3' : undeclared identifier
mpusbapi_thunk_pcwin64.c(100) : error C2146: syntax error : missing ')' before
identifier 'PDWORD'
mpusbapi_thunk_pcwin64.c(100) : error C2065: 'PDWORD' : undeclared identifier
mpusbapi_thunk_pcwin64.c(100) : error C2100: illegal indirection
mpusbapi_thunk_pcwin64.c(100) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(100) : error C2297: '*' : illegal, right operand has
type 'const char *'
mpusbapi_thunk_pcwin64.c(101) : error C2065: 'p3' : undeclared identifier
mpusbapi_thunk_pcwin64.c(102) : error C2065: 'p4' : undeclared identifier
mpusbapi_thunk_pcwin64.c(103) : error C2065: 'p4' : undeclared identifier
mpusbapi_thunk_pcwin64.c(104) : error C2146: syntax error : missing ')' before
identifier 'HANDLE'
identifier 'HANDLE'
mpusbapi_thunk_pcwin64.c(104) : error C2065: 'HANDLE' : undeclared identifier
mpusbapi_thunk_pcwin64.c(104) : error C2065: 'PVOID' : undeclared identifier
mpusbapi_thunk_pcwin64.c(104) : error C2275: 'uint32' : illegal use of this
type as an expression
mpusbapi_thunk_pcwin64.c(104) : error C2065: 'PDWORD' : undeclared identifier
mpusbapi_thunk_pcwin64.c(104) : error C2059: syntax error : ')'
mpusbapi_thunk_pcwin64.c(104) : error C2146: syntax error : missing ';' before
identifier 'fcn'
mpusbapi_thunk_pcwin64.c(104) : warning C4033:
'uint32HANDLEPVOIDuint32PDWORDuint32Thunk' must return a value
mpusbapi_thunk_pcwin64.c(104) : error C2065: 'p0' : undeclared i
ESPERO QUE ME PUEDAN AYUDAR, NO ENTIENDO PORQUE ARROJA ESTE ERROR....
Re: problema con mpusbapi.dll al cargarla a MATLAB
« Respuesta #1 en: 21 de Abril de 2012, 21:53:17 »
Hola de nuevo a todos, ya encontre el problema, este se debia a que un virus corrompio los compiladores de C y C++ de mi máquina, por lo tanto matlab no odia cargar la librería, ya está solucionado  :lol:
Desconectado luiskjuarez
« Respuesta #2 en: 11 de Abril de 2018, 18:22:57 »
Hola como solucionaste el problema, actualizaste los ompiladores o modificaste la ruta de los compiladores o que fue lo que hicite por que tengo el mismo problema :(
