Autor Tema: Otro analizador lógico  (Leído 1670 veces)
Desconectado jfh900
« en: 08 de Agosto de 2012, 15:03:11 »
Aquí tenemos otro analizador lógico. Tal vez sería interesante hacer una comparativa. El precio $50.
Datos de este analizador:
    Capture 50MHz+ waveforms on 32 channels
        200Msps captures up to 100MHz waveforms on 16 channels
        100Msps captures up to 50MHz waveforms on 32 channels
    16 buffered channels, 5volt tolerant
        M74LCX16245DTR2G transceiver tolerates voltages from -0.5V to +7V.
    216K Block RAM supports following memory configurations*
        8 channels with 24K sample depth
        16 channels with 12K sample depth
        32 channels with 6K sample depth
    External clock and trigger input
        Allows interfacing with external test equipment and daisy chaining OLS's for additional channels.
    Internal clock and trigger output
    16bit wing expansion header
    USB interface, USB powered
    USB upgradable everything
    Designed for the SUMP logic analyzer client
    Open source
    Low price
Memory depth is the maximum supported by the hardware, the current firmware implements the following memory depths:
    8 channels with 16K sample depth
    16 channels with 8K sample depth
    32 channels with 4K sample depth
Future firmware upgrades will support the maximum memory configurations.
La página: http://www.seeedstudio.com/depot/preorder-open-workbench-logic-sniffer-p-612.html?cPath=75
Desde España Jesús
