Autor Tema: Ayuda con Bootloader serial (RS232) usando módulo Bluetooth y TinyBootloader  (Leído 14915 veces)
Re: Ayuda con Bootloader serial (RS232) usando módulo Bluetooth y TinyBootloader
« Respuesta #30 en: 18 de Diciembre de 2012, 19:45:07 »
Es verdad  :oops:
Creía que te referías al bootloader.
Los fuses en ese programa pueden ser los mismos que para el bootloader con oscilador interno:
; FUSE OPTIONS (SOURCE: P18F2550.INC)
; PLL Prescaler Selection bits:
;    CONFIG   PLLDIV = 1          ;No prescale (4 MHz oscillator input drives PLL directly)
;    CONFIG   PLLDIV = 2          ;Divide by 2 (8 MHz oscillator input)
;    CONFIG   PLLDIV = 3          ;Divide by 3 (12 MHz oscillator input)
;    CONFIG   PLLDIV = 4          ;Divide by 4 (16 MHz oscillator input)
    CONFIG   PLLDIV = 5          ;Divide by 5 (20 MHz oscillator input)
;    CONFIG   PLLDIV = 6          ;Divide by 6 (24 MHz oscillator input)
;    CONFIG   PLLDIV = 10         ;Divide by 10 (40 MHz oscillator input)
;    CONFIG   PLLDIV = 12         ;Divide by 12 (48 MHz oscillator input)
; CPU System Clock Postscaler:
    CONFIG   CPUDIV = OSC1_PLL2  ;[OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
;    CONFIG   CPUDIV = OSC2_PLL3  ;[OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
;    CONFIG   CPUDIV = OSC3_PLL4  ;[OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
;    CONFIG   CPUDIV = OSC4_PLL6  ;[OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
; USB Clock Selection bit (used in Full Speed USB mode only; UCFG:FSEN = 1):
;    CONFIG   USBDIV = 1          ;USB clock source comes directly from the primary oscillator block with no postscale
    CONFIG   USBDIV = 2          ;USB clock source comes from the 96 MHz PLL divided by 2
; Oscillator Selection bits:
;    CONFIG   FOSC = XT_XT        ;XT oscillator, XT used by USB
;    CONFIG   FOSC = XTPLL_XT     ;XT oscillator, PLL enabled, XT used by USB
;    CONFIG   FOSC = ECIO_EC      ;External clock, port function on RA6, EC used by USB
;    CONFIG   FOSC = EC_EC        ;External clock, CLKOUT on RA6, EC used by USB
;    CONFIG   FOSC = ECPLLIO_EC   ;External clock, PLL enabled, port function on RA6, EC used by USB
;    CONFIG   FOSC = ECPLL_EC     ;External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    CONFIG   FOSC = INTOSCIO_EC  ;Internal oscillator, port function on RA6, EC used by USB
;    CONFIG   FOSC = INTOSC_EC    ;Internal oscillator, CLKOUT on RA6, EC used by USB
;    CONFIG   FOSC = INTOSC_XT    ;Internal oscillator, XT used by USB
;    CONFIG   FOSC = INTOSC_HS    ;Internal oscillator, HS used by USB
;    CONFIG   FOSC = HS           ;HS oscillator, HS used by USB
;    CONFIG   FOSC = HSPLL_HS     ;HS oscillator, PLL enabled, HS used by USB
; Fail-Safe Clock Monitor Enable bit:
    CONFIG   FCMEN = OFF         ;Fail-Safe Clock Monitor disabled
;    CONFIG   FCMEN = ON          ;Fail-Safe Clock Monitor enabled
; Internal/External Oscillator Switchover bit:
    CONFIG   IESO = OFF          ;Oscillator Switchover mode disabled
;    CONFIG   IESO = ON           ;Oscillator Switchover mode enabled
; Power-up Timer Enable bit:
    CONFIG   PWRT = ON           ;PWRT enabled
;    CONFIG   PWRT = OFF          ;PWRT disabled
; Brown-out Reset Enable bits:
    CONFIG   BOR = OFF           ;Brown-out Reset disabled in hardware and software
;    CONFIG   BOR = SOFT          ;Brown-out Reset enabled and controlled by software (SBOREN is enabled)
;    CONFIG   BOR = ON_ACTIVE     ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
;    CONFIG   BOR = ON            ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
; Brown-Out Voltage bits:
;    CONFIG   BORV = 0            ; 4.59 v
;    CONFIG   BORV = 1            ; 4.33 v
    CONFIG   BORV = 2            ; 2.79 v
;    CONFIG   BORV = 3            ; 2.05 v
; USB Voltage Regulator Enable bit:
;    CONFIG   VREGEN = OFF        ;USB voltage regulator disabled
    CONFIG   VREGEN = ON         ;USB voltage regulator enabled
; Watchdog Timer Enable bit:
    CONFIG   WDT = OFF           ;HW Disabled - SW Controlled
;    CONFIG   WDT = ON            ;HW Enabled - SW Disabled
; Watchdog Timer Postscale Select bits:
;    CONFIG   WDTPS = 1           ;1:1
;    CONFIG   WDTPS = 2           ;1:2
;    CONFIG   WDTPS = 4           ;1:4
;    CONFIG   WDTPS = 8           ;1:8
;    CONFIG   WDTPS = 16          ;1:16
;    CONFIG   WDTPS = 32          ;1:32
;    CONFIG   WDTPS = 64          ;1:64
;    CONFIG   WDTPS = 128         ;1:128
;    CONFIG   WDTPS = 256         ;1:256
;    CONFIG   WDTPS = 512         ;1:512
;    CONFIG   WDTPS = 1024        ;1:1024
;    CONFIG   WDTPS = 2048        ;1:2048
;    CONFIG   WDTPS = 4096        ;1:4096
;    CONFIG   WDTPS = 8192        ;1:8192
;    CONFIG   WDTPS = 16384       ;1:16384
    CONFIG   WDTPS = 32768       ;1:32768
; MCLR Pin Enable bit:
;    CONFIG   MCLRE = OFF         ;RE3 input pin enabled; MCLR disabled
    CONFIG   MCLRE = ON          ;MCLR pin enabled; RE3 input pin disabled
; Low-Power Timer 1 Oscillator Enable bit:
;    CONFIG   LPT1OSC = OFF       ;Timer1 configured for higher power operation
    CONFIG   LPT1OSC = ON        ;Timer1 configured for low-power operation
; PORTB A/D Enable bit:
    CONFIG   PBADEN = OFF        ;PORTB<4:0> pins are configured as digital I/O on Reset
;    CONFIG   PBADEN = ON         ;PORTB<4:0> pins are configured as analog input channels on Reset
; CCP2 MUX bit:
;    CONFIG   CCP2MX = OFF        ;CCP2 input/output is multiplexed with RB3
    CONFIG   CCP2MX = ON         ;CCP2 input/output is multiplexed with RC1
; Stack Full/Underflow Reset Enable bit:
    CONFIG   STVREN = OFF        ;Stack full/underflow will not cause Reset
;    CONFIG   STVREN = ON         ;Stack full/underflow will cause Reset
; Single-Supply ICSP Enable bit:
    CONFIG   LVP = OFF           ;Single-Supply ICSP disabled
;    CONFIG   LVP = ON            ;Single-Supply ICSP enabled
; Extended Instruction Set Enable bit:
    CONFIG   XINST = OFF         ;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
;    CONFIG   XINST = ON          ;Instruction set extension and Indexed Addressing mode enabled
; Background Debugger Enable bit:
;    CONFIG   DEBUG = ON          ;Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    CONFIG   DEBUG = OFF         ;Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
; Code Protection bit Block 0:
;    CONFIG   CP0 = ON            ;Block 0 (000800-001FFFh) code-protected
    CONFIG   CP0 = OFF           ;Block 0 (000800-001FFFh) not code-protected
; Code Protection bit Block 1:
;    CONFIG   CP1 = ON            ;Block 1 (002000-003FFFh) code-protected
    CONFIG   CP1 = OFF           ;Block 1 (002000-003FFFh) not code-protected
; Code Protection bit Block 2:
;    CONFIG   CP2 = ON            ;Block 2 (004000-005FFFh) code-protected
    CONFIG   CP2 = OFF           ;Block 2 (004000-005FFFh) not code-protected
; Code Protection bit Block 3:
;    CONFIG   CP3 = ON            ;Block 3 (006000-007FFFh) code-protected
    CONFIG   CP3 = OFF           ;Block 3 (006000-007FFFh) not code-protected
; Boot Block Code Protection bit:
;    CONFIG   CPB = ON            ;Boot block (000000-0007FFh) code-protected
    CONFIG   CPB = OFF           ;Boot block (000000-0007FFh) not code-protected
; Data EEPROM Code Protection bit:
;    CONFIG   CPD = ON            ;Data EEPROM code-protected
    CONFIG   CPD = OFF           ;Data EEPROM not code-protected
; Write Protection bit Block 0:
;    CONFIG   WRT0 = ON           ;Block 0 (000800-001FFFh) write-protected
    CONFIG   WRT0 = OFF          ;Block 0 (000800-001FFFh) not write-protected
; Write Protection bit Block 1:
;    CONFIG   WRT1 = ON           ;Block 1 (002000-003FFFh) write-protected
;    CONFIG   WRT1 = OFF          ;Block 1 (002000-003FFFh) not write-protected
; Write Protection bit Block 2:
;    CONFIG   WRT2 = ON           ;Block 2 (004000-005FFFh) write-protected
    CONFIG   WRT2 = OFF          ;Block 2 (004000-005FFFh) not write-protected
; Write Protection bit Block 3:
;    CONFIG   WRT3 = ON           ;Block 3 (006000-007FFFh) write-protected
    CONFIG   WRT3 = OFF          ;Block 3 (006000-007FFFh) not write-protected
; Boot Block Write Protection bit:
;    CONFIG   WRTB = ON           ;Boot block (000000-0007FFh) write-protected
    CONFIG   WRTB = OFF          ;Boot block (000000-0007FFh) not write-protected
; Configuration Register;Write Protection bit:
;    CONFIG   WRTC = ON           ;Configuration registers (300000-3000FFh) write-protected
    CONFIG   WRTC = OFF          ;Configuration registers (300000-3000FFh) not write-protected
; Data EEPROM Write Protection bit:
;    CONFIG   WRTD = ON           ;Data EEPROM write-protected
    CONFIG   WRTD = OFF          ;Data EEPROM not write-protected
; Table Read Protection bit Block 0:
;    CONFIG   EBTR0 = ON          ;Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    CONFIG   EBTR0 = OFF         ;Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 1:
;    CONFIG   EBTR1 = ON          ;Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    CONFIG   EBTR1 = OFF         ;Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 2:
;    CONFIG   EBTR2 = ON          ;Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    CONFIG   EBTR2 = OFF         ;Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
; Table Read Protection bit Block 3:
;    CONFIG   EBTR3 = ON          ;Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    CONFIG   EBTR3 = OFF         ;Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
; Boot Block Table Read Protection:
;    CONFIG   EBTRB = ON          ;Boot block (000000-0007FFh) protected from table reads executed in other blocks
    CONFIG   EBTRB = OFF         ;Boot block (000000-0007FFh) not protected from table reads executed in other blocks
« Respuesta #31 en: 18 de Diciembre de 2012, 19:49:26 »
Adjunto programa con fuses.
Desconectado lecsdexter
« Respuesta #32 en: 18 de Diciembre de 2012, 20:19:34 »
Al parecer tengo un problema de recepción de datos. Estoy checando porqué. Me di cuenta de que le tengo qué poner un reloj de 20MHz, ya se lo puse.
« Respuesta #33 en: 19 de Diciembre de 2012, 13:14:44 »
El reloj de 20Mhz no es necesario mientras el PIC funcione con el oscilador interno.
El programita es muy sencillo, simplemente une los terminales RX y TX. La señal que recibe en RX la copia en TX.
Es equivalente a:
   #define PORT_RX   PORTCbits.RC7
   #define PORT_TX   PORTCbits.RC6
   TRISCbits.TRISC7 = 1;
   TRISCbits.TRISC6 = 0;
   while(1)
      PORT_TX = PORT_RX;
También debería funcionar si unes físicamente los terminales RX y TX del módulo Bluetooth.
« Respuesta #34 en: 19 de Diciembre de 2012, 19:37:07 »
Entiendo.
He checado la continuidad en los pines del BT y he descubierto que el GND y el TX tienen continuidad   :oops:  :cry: Conseguiré lo más pronto otro módulo para seguir haciendo las pruebas.
« Respuesta #35 en: 19 de Diciembre de 2012, 19:56:47 »
Sin embargo, he descubierto el pin de RESET en el módulo:
« Respuesta #36 en: 20 de Diciembre de 2012, 20:39:01 »
Bueno, espero no me vuelva a suceder eso...
Picuino, ya probé con el módulo BT el programa "echo", sí funciona. Ahora probaré el Bootloader.
« Respuesta #37 en: 20 de Diciembre de 2012, 21:39:46 »
Ya funciona!!!!
Lo que siempre me estaba fallando era que el Tx del módulo BT ya no funcionaba (nunca enviaba nada al micro).
Aquí pongo unas imágenes que quiero compartir:
Gracias Picuino!!!
« Última modificación: 20 de Diciembre de 2012, 21:53:13 por lecsdexter »
« Respuesta #38 en: 20 de Diciembre de 2012, 21:41:58 »
De todos modos, confirma el correcto funcionamiento por favor:
-->Cargando el programa de Test (la primera vez no presioné el botón Reset del micro; tampoco fue necesario resetear el módulo Bluetooth).
« Última modificación: 20 de Diciembre de 2012, 21:45:49 por lecsdexter »
« Respuesta #39 en: 20 de Diciembre de 2012, 21:47:59 »
Parte del test que hace la comunicación serial enviando 1's y 0's.
Lo revisé en dos programas: el mismo "TinyBootloader" y en el "USART de MikroC".
« Última modificación: 20 de Diciembre de 2012, 21:58:35 por lecsdexter »
« Respuesta #40 en: 20 de Diciembre de 2012, 21:51:36 »
Protoboard armado.
*Le puse un regulador de 5V, ya que la batería me daba 6V y prefiero irme a lo seguro.
*En la imagen, se observa el Tx del BT y el Tx del micro. El Tx del BT va al Rx del micro, y el Tx del micro, va al Rx del BT.
« Respuesta #41 en: 20 de Diciembre de 2012, 21:52:33 »
Parte del test donde enciende (parpadean) los leds del puerto B (sólo puse 2 leds  :oops: ).
« Última modificación: 21 de Diciembre de 2012, 13:48:15 por lecsdexter »
« Respuesta #42 en: 21 de Diciembre de 2012, 13:06:03 »
Enhorabuena.
Yo ya he pedido un módulo bluetooth por e-bay para hacer el mismo montaje.
A propósito ¿Qué módulo utilizar para conectar al PC?
« Respuesta #43 en: 21 de Diciembre de 2012, 13:09:32 »
Protoboard armado.
Si pones un regulador LM7805 te dará problemas porque necesita mucha caída de tensión entre la entrada y la salida.
Para evitar problemas con baterías yo utilizo un regulador LDO:  LM2940-5.0
Cuesta un poco más, pero aprovecha la tensión de las baterías al máximo.
Si las baterías bajan a 5v, con un 7805 vas a conseguir menos de 4 voltios en el micro. Con el LM2940 puedes conseguir 4.8v en el micro.
« Respuesta #44 en: 21 de Diciembre de 2012, 13:36:26 »
Ah, muchas gracias por esa información!!! (Y sí, utilizaba el 7805)
Para "el módulo BT que le conecto a la computadora", uso el que tiene internamente la laptop. Aunque te comento que cuando trabajé con el módulo BT para comunicación serial con un micro Cypress, mi laptop antigua no tenía BT interno, y usé uno idéntico a este:
http://articulo.mercadolibre.com.mx/MLM-411310899-bluetooth-para-laptop-o-computadora-de-escritorio-_JM
Por cierto, hoy probé con otro programita para verificar su funcionamiento, y sí lo hizo de manera correcta.
P.D.: El modelo del BT que utilicé en el proto es HC05.
Está genial la programación de pics TOTALMENTE INALÁMBRICA!!!
« Última modificación: 21 de Diciembre de 2012, 13:49:04 por lecsdexter »
