Autor Tema: problema display 7 segmentos (ql200)  (Leído 3091 veces)
Desconectado fife89
« en: 19 de Diciembre de 2012, 17:54:12 »
Buenas Gente del Foro
me he comprado una pic trainer ql200
esta me trajo varios programas examples. estoy usando un pic 16f877a
 bueno cargue unprograma de display 7 segmentos pero aun no entiendo como logran mostrar del 1 al 6. paso esquema y el programa.
me gustaria aprender a hacerlo pero en pic basic pro
;experiment purpose: familiar some LED dynamic scan display
;six LED display 0123456 six numbers from left to right
;hardware request:SW S5,S6 all set ON,the other SW all set OFF
 #include<p16f877A.inc>       ;include MCU head file
__CONFIG _DEBUG_OFF&_CP_ALL&_WRT_HALF&_CPD_ON&_LVP_OFF&_BODEN_OFF&_PWRTE_ON&_WDT_OFF&_HS_OSC
;THE configure of MCU,watchdog OFF,electrify delay OPEN,power down check OFF,
;LOW power programme OFF,encrypt,4M crystal HS surge.
ORG     00H                  ;reset entrance address
 NOP                          ;the nop instruction of ICD require
 MOVLW   0FFH
 MOVWF   PORTA
 MOVWF   PORTD                ;clear all display
 BSF     STATUS,RP0           ;select BANK1
 CLRF    TRISA                ;set A PORT OUTPUT
 CLRF    TRISD                ;set D PORT OUTPUT
 MOVLW   06H
 MOVWF   ADCON1               ;set A PORT general I/O PORT
 BCF     STATUS,RP0           ;BANK0
LOOP
 MOVLW   0                    ;display 0
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,0
 CALL    DELAY
 BSF     PORTA,0
 MOVLW   1                    ;display 1
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,1
 CALL    DELAY
 BSF     PORTA,1
 MOVLW   2                    ;display 2
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,2
 CALL    DELAY
 BSF     PORTA,2
 MOVLW   3                    ;display 3
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,3
 CALL    DELAY
 BSF     PORTA,3
 MOVLW   4                    ;display 4
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,4
 CALL    DELAY
 BSF     PORTA,4
 MOVLW   5                    ;display 5
 CALL    TABLE
 MOVWF   PORTD
 BCF     PORTA,5
 CALL    DELAY
 BSF     PORTA,5
 GOTO    LOOP                 ;circle display
;**************check table subprogram*******************
TABLE
 ADDWF   PCL,1                ;instruction register add excursion address
 RETLW   0C0H                 ;the code of 0( the common LED is anode)
 RETLW   0F9H                 ;the code of 1
 RETLW   0A4H                 ;the code of 2
 RETLW   0B0H                 ;the code of 3
 RETLW   99H                  ;the code of 4
 RETLW   92H                  ;the code of 5
;**************delay subprogram*****************************
DELAY
 MOVLW   0FFH
 MOVWF   20H
 DECFSZ  20H,1
 GOTO    $-1
 RETURN
 END                          ;program end
aqui una foto de como se ve
aqui el esquema
muchas gracias de antemano
