Autor Tema: Módulo GSM/GPRS SIM800L  (Leído 56712 veces)
« en: 22 de Noviembre de 2015, 13:13:37 »
Creo que este módulo GSM/PRS de SIMCOM, se merece un hilo esclusivamente dedicado a él.
Características Generales
•Quad-band 850/900/1800/1900MHz
•GPRS multi-slot class 12/10
•GPRS mobile station class B
•Compliant to GSM phase 2/2+
– Class 4 (2 W @ 850/900 MHz)
– Class 1 (1 W @ 1800/1900MHz)
•FM: 76~109MHz worldwide bands with 50KHz tuning step
•Dimensions: 15.8*17.8*2.4 mm
•Weight: 1.35g
•Control via AT commands (3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands)
•Supply voltage range 3.4 ~ 4.4V
•Low power consumption
•Operation temperature:-40°C~85°C
Especificaciones para Datos GPRS
•GPRS class 12: max. 85.6 kbps (downlink/uplink)
•PBCCH support
•Coding schemes CS 1, 2, 3, 4
•PPP-stack
•CSD up to 14.4 kbps
•USSD
•Non transparent mode
Specifications for SMS via GSM/GPRS
•Point to point MO and MT
•SMS cell broadcast
•Text and PDU mode
Características Software
•0710 MUX protocol
•Embedded TCP/UDP protocol
•FTP/HTTP
•MMS
•E-MAIL
•DTMF
•Jamming Detection
Especificaciones para voz
•Tricodec
– Half rate (HR)
– Full rate (FR)
– Enhanced Full rate (EFR)
•AMR
– Half rate (HR)
– Full rate (FR)
•Hands-free operation
(Echo suppression)
Interfaces
88 LGA pads including:
•Analog audio interface
•PCM interface
•RTC backup
•Serial interface
•USB interface
•Interface to external SIM 3V/1.8V
•Keypad interface
•GPIO
•ADC
•GSM Antenna pad
•FM Antenna pad
Compatibility
•AT cellular command
Certificaciones (Plan):
•CE
•GCF
•FCC
•ROHS
•REACH
Documentación archivos PDF.
Datasheet SIM800L https://mega.nz/#!cBt3UBxS!t4ZBUn3rmoWxlEEHg4QprUcxAMm167ExxUa6WhWDctc
Schematic and PCB Reference Design https://mega.nz/#!wV1ETLra!PSWrR3JihqHDggomK4brhX8G1k-x6AdWTcXE0_vePdI
Hardware design https://mega.nz/#!QQlxFRBZ!zD2JXErkHBn4yMXRo9T1-nrqgx928pGBlJCu9_Sr7Bg
Comandos AT Serie SIM800   https://mega.nz/#!gV91QLIA!QscPHpiUc0VOZnZip7jAUTphVac3gl7TgdftdVkbcPU
TCP/IP Application https://mega.nz/#!oI0wzLqQ!63_xfV0Yq5eQHdixeNfBSEaE28chUWbinGC5bmaH_lU
MMS Application https://mega.nz/#!MZcxiQAb!N-S_p_AXF36XnnTz3KftRtS86-xoI-wCln-uspeNltI
IP Application https://mega.nz/#!FU0yCKQL!-9AMSS3BnbF6_ucqjkN3UXhpYPqLYUTDePmI3hTnp4w
FM Application https://mega.nz/#!0EMnlRJL!BX39Xk0r9ATbH3Uiyg50fRduv5xlHGPOXatArNqG9nc
Email Application https://mega.nz/#!UR0FTSaQ!T7XaBPd5Tl43al6UXWBeqxIGiNjjB1qJi83bw1AyHSQ
SSL Application https://mega.nz/#!wZ80mQAS!LCdenDm43U9_wdwvwqZjSQ5ShRei9J0y45pe2lO_NcA
Software Upgrade https://mega.nz/#!FBFSyIwA!sYZYC_Q1so9mMZJ8PZm7AqhISBRNdp82razJUQjEq6w
Software
SIM800 entorno desarrollo App https://mega.nz/#!AdcXEKSI!e_1RORN9FvqLZq0YXPPVJlz31re6iqBW4sWYa00h5QA
Footprint PCB
Símbolo y Footprint Eagle https://mega.nz/#!ZdMXxCaZ!ZZQiJ2hhyyU3bNRljdKx6OO8sP3OKySs595JH9-v6oE
Enlaces de interés relacionados
Adafruit FONA basado en SIM800L: https://learn.adafruit.com/adafruit-fona-mini-gsm-gprs-cellular-phone-module/overview
Librerías Arduino para FONA: https://github.com/adafruit/Adafruit_FONA_Library
Librería Arduino Microduino: https://github.com/Microduino/Microduino_Tutorials/tree/master/Microduino_Libraries/_03_Microduino_GSM_SIM800L
Esquemas aplicativos
Esquema aplicativo SIM800H (compatible con el SIM800L): http://www.libstock.com/img/projects/21707/1212/1425051944_schemati.jpg
Esquema aplicativo SIM800L http://www.electrodragon.com/w/images/4/4a/Sim800L_schematic.jpg
Esquema Seedstudio SIM800L http://www.seeedstudio.com/wiki/images/c/c4/SIM800L_Schematic.pdf
Proyectos
Comunicación HTTP/GPRS http://arduinodev.com/arduino-library-for-gprshttp-communication-with-sim800/
Localizador de Ubicación GSM http://www.instructables.com/id/How-to-make-a-Mobile-Cellular-Location-Logger-with/?ALLSTEPS
El SIM800L es realmente diminuto, casi tanto como la propia tarjeta SIM.
Pinout del SIM800L
Asignación de pines por bloques
Dimensiones del SIM800L
Footprint recomendado.
El SIM800L tiene consumos de pico importantes de 2 a 3 amperios, así que recomendable usar un buen estabilizador conmutado. Yo uso el LM2596 para cargas que requieren consumos de hasta 3 amperios, y también aparece recomendado en el datasheet del SIM800L
« Última modificación: 07 de Diciembre de 2015, 14:58:28 por planeta9999 »
Re:Módulo GSM/GPRS SIM800L
« Respuesta #1 en: 22 de Noviembre de 2015, 16:35:21 »
 ((:-)) ((:-)) Genial Planeta tu gran Tutorial
Saludo
« Respuesta #2 en: 22 de Noviembre de 2015, 17:15:48 »
Saludo
Gracias,  :P
Desconectado PalitroqueZ
    • Electrónica Didacta
« Respuesta #3 en: 22 de Noviembre de 2015, 17:58:09 »
excelente tuto planeta9999, te felicito.
Recuerdo cuando hice las primeras practicas con esos bichos, que al configurarlo para recibir por serial, me causaba risa leer el RING en el monitor al repicar la llamada de el modulo gsm :mrgreen:
Friedrich August von Hayek
« Respuesta #4 en: 12 de Diciembre de 2015, 00:10:39 »
Hoy he probado el módulo prefabricado de los chinos con el SIM800L, ha funcionado a la primera.
Para las pruebas usé el software SIM900AT de rfcandy, tiene la ventaja de que tienes unos cuantos comandos AT ya configurados en botones, así no hay que escribirlos a mano. Hace unos días probe mi tarjeta SIM con el SIM900 para el tema del Pin secreto y conexión al operador de telefonía que en mi caso es Vodafone, y funcionó a la perfección, con el SIM800L no lo he probado porque me daba pereza tener que sacar de nuevo el SIM del móvil, meterlo en un adaptador de micro a mini y ponerlo en el zócalo SIM del SIM800L.
Los comandos AT que he mandado al SIM800L, como se ve en la captura de pantalla, es el de estado, el de nivel de señal y el de voltaje de la pila, tambien probé el comando AT para apagar el módulo. El resto como no estaba puesto el SIM, responden con error, pero es normal.
El software SIM900AT de rfcandy es gratuito, y muy útil para probar los módulos SIM de Simcom.
Al módulo de los chinos le he conectado alimentación de 4 voltios, TX, RX, Masa y un cable al pin de Reset que reinicia el módulo cuando se pone a masa. Desafortunadamente en este módulo no está accesible la señal PWRKEY para poder encender/apagar el módulo desde un microcontrolador, pero se puede hacer lo mismo apagando con un comando AT y encendiendo poniendo a masa la patilla de RESET.
He puesto la antena de alambre que va incluida con el módulo, soldada directamente al pasante del pin de antena.
Desconectado Snaut
« Respuesta #5 en: 19 de Enero de 2016, 16:45:41 »
No había visto este hilo aún, muy buena información planeta9999. Buscando por internet he quedado sorprendido por el precio que tiene este módulo. Con tanta información que has dejado aquí y estos precios no he podido resistirme, acabo de comprar uno por 6€. Cuando me llegue dentro de un mes más o menos comento el resultado.
Desconectado ADOLFO BUSTILLO
« Respuesta #6 en: 02 de Julio de 2016, 11:50:44 »
Saludos mi nombre es Adolfo Bustillos tengo 50 años de edad y soy de Venezuela  ya estoy retirado, soy Ing. Agronomo y desde hace casi un año descubri el maravilloso mundo de la electronica y los microcontroladores apenas estoy dando mis primeros pasos en PIC BASIC PRO, de computadoras no se nada de redes sociales menos, pero comprendo que esto de la electronica me gusta enormemente lastima no haberla conocido antes, pido disculpas por la introduccion pero debia presentarme y no se si ya hice mi primera falta al foro en hacerlo en este hilo de ser asi pido disculpas y con mucha humildal un poco de paciencia.
La razon de haberme inscrito en este foro es porque NAUFRAGANDO, por internet he buscado material sobre el modulo Sim800 y dentro de mi torpeza en manejar las pc y el internet y mi nulo conocimiento del ingles no he hallado nada sin embargo en este foro está ésta informacion tan detallada que me gustaria conocer, por el momento tengo un gran problema ni siquiera logro que el S800 reconozca operadora alguna, le puse un regulador de 3.3v a 500 mA, el cual alimento con un cable de USB a serial y solo paparpadea de vez en cuando pero no logra conectarse a la red de movistar, digitel o movilnet que son las operadoras de mi pais.
debo entender que quizas me falta voltaje y hasta amperaje pero es que solo hace eso parpadear de vez en cuando y ni siquiera obedece a los comandos AT, supongo que aun sin tener el SIMCARD de la operadora deberia responde algo al darle AT y enter pero no hace nada., las conexiones estan bien ya he probado todo he revisado todo pero no he logrado conectarlo al pc, ya he jugado con otros modulos y se conectan bien pero ese no se que pasa.
mi pregunta es: sera porque solo tiene 3.3 voltios? y el trabaja con 3.4 en adelante?, y si de ser eso como hago para obtener 4.7 voltios a 2 amp? mil gracias y espero puedan ayudarme saludos
Desconectado AG1
« Respuesta #7 en: 02 de Julio de 2016, 17:57:18 »
Hola Adolfo:
Con 3.3V no funciona adecuadamente, el mismo módulo te lo indicará:
Con 5 voltios (obtenidos del puerto USB)  y 2 diodos 1N4007 en serie te debe funcionar.
Respecto a la intensidad, con los 500mA que puede suministrar el puerto USB es suficiente siempre que pongas  un condensador electrolítico de capacidad >= 1000uF para  garantizar la alimentación del módulo durante los picos.
Presta atención a la adaptación de  niveles en la comunicación.
En este hilo puedes ver como probé por primera vez este módulo:
http://www.todopic.com.ar/foros/index.php?topic=45136.msg379693#msg379693
Salu2.
« Respuesta #8 en: 02 de Julio de 2016, 21:46:46 »
Buenas tardes AG1, mil gracias por tu ayuda efectivamente ahora funciona muy bien, ya hice algunas pruebas enviar y recibir SMS y hacer y responder llamadas con este modulo, debo confesar que eso ya lo habia hecho antes pero con otro modulo que no manejaba conexiones web este SIM800 si permite casi todo tipo de conexiones pero la que mas me interesa es la coneccion HTTP, estuve haciendo una pruebas y lamentablemente no pude comunicarme pero hoy es el primer dia, voy a seguir intentando y luego coloco el mini proyecto que a decir verdad es una sencilles pero me apasiona esto de las comunicaciones, lo que estoy haciendo es enviar una cadena de texto a una direccion web y que me muestre lo enviado, como dije aun no lo logro pero voy a seguir intentando de seguro estare por aca preguntando nuevamente, mil gracias de verdad amigo AG1
Desconectado farenheitcv
PRoblemas al ingresar comandos regresa mensaje ERROR
« Respuesta #9 en: 08 de Julio de 2016, 17:49:38 »
Hola que tal conseguí este modulo sim800l pero e tenido algunos problemas al usarlo ya que cuando escribo los comandos como AT+CMGF? AT+CMGF=1 me sale ERROR y asi con otros mas. Pero con los comandos AT, AT+CBC si me arroja OK y me da e voltade de 0,100,4261.
Alguien a tenido el mismo problema, temo que se descompuso el modulo ya que solo una vez me funciono todo bien(aun que me costo conseguir una fuente adecuada ), mande mensajes, realice llamadas, obtuve las coordenadas de latitud y longitud, pero después volví a conectar todo y ya no me volvio a funcionar .
Alguien a tenido el mismo problema algún consejo sobre como hacerlo funcionar
Desconectado electrik77
Re:PRoblemas al ingresar comandos regresa mensaje ERROR
« Respuesta #10 en: 20 de Septiembre de 2016, 07:49:07 »
Buenas, no se si me estoy equivocando pero por lo que tengo entendido el módulo sim800L no trae incorporado gps, si el sim808.  Farenheitcv por ahí te estas confundiendo de módulo por eso no te toma algunos comando.
Desconectado armandoyamir
    • www.microcontrolador.net
« Respuesta #11 en: 18 de Octubre de 2016, 10:28:39 »
Estimados.
Que tal?
Yo estoy trabajando con algunos de sim de esta serie, como el sim900 y sim800C, conjuntamente con la tarjeta ABMasterSW de ABServo System. Funciona de maravilla.
Aqui les envío la dirección en ebay.
http://www.ebay.com/itm/PIC-SmartPhone-Home-Control-Board-Development-Kit-with-Sim900-GSM-GPRS-RS232-/282219280461?hash=item41b594784d:g:T~gAAOSw8gVX32Ra
Seguimos en contacto.
Armando.
Ing Armando Blanco C.
Desconectado Gatorey75
« Respuesta #12 en: 06 de Noviembre de 2016, 09:51:29 »
hola Farenheitcv has solucionado el problema que indicas más abajo? Que solo una vez te funciono el sim800 y luego de volver a conectar No, me pasa lo mismo, puedes ayudarme????
Alguien a tenido el mismo fuente problema mande mensajes, realice llamadas, obtuve las coordenadas de latitud y longitud, pero después volví a conectar todo y ya no me volvio a funcionar .
[/quote]
Desconectado ingeniero18
« Respuesta #13 en: 05 de Junio de 2017, 13:14:15 »
Gente, tengo una consulta muy simple para la cual no estoy encontrando respuesta en la web y parece que está influyendo mucho en mi proyecto: Utilizo un módulo SIM800L para control a distancia por SMS.
Alguien sabe si la posición de la antena influye en la transmisión y, si es así, cuál sería la posición ideal???
Gracias!!!!
Desconectado kylobeetle
« Respuesta #14 en: 12 de Septiembre de 2017, 14:16:22 »
Hola planeta, una pregunta, de que forma conectaste el sim800L al puerto COM de la pc ? es que estoy teniendo problemas con esa parte, muchas gracias
pd: tengo el mismo sim800l presentado aqui
